Lift the scanner cover using the plastic tabs, located on the left and right side of the machine until it locks securely into the open position.
Slide the print head to the middle.
Check for any pieces of paper or staple , paper clip...
or
Slide the print head over to the right side under the cover to make sure you clean the entire encoder strip.
With the lint free cloth, firmly grab the encoder strip on both sides and rub the cloth down the strip from one end to the other (left to right then right to left) at least three times.
actually I always encounter these problem, as of now I have no solution here, but I think this problem are mechanical problem or there are problem on the main board, and if you remove the connection of the switch beside or under of the motor of the belt of printer head, the error is unable to print50, OR try to clean your encoder strip, and the sensor also,.
