Question about LG WFT1071TP Top Load Washer
Washer wing has come off.... LG652A Front loader maching
One of the washer wings has come off my lg front loader and it seems that part of it is sitting underneath the bowl. Can anybody advise how I can fix this.....
    Guru:
  • 449 Answers
The washers and wing nuts go on the bolts of the STA. The cut through twisted bolts are called lock washers, and they are used for added security. Once you tighten the wing nuts, the lock washer compresses and keeps the wing nut from loosening by itself. I believe that the two caps protect the threads of the bolts, not needed.
Posted on Dec 24, 2008
Can't secure agitator wingnut on 7.5kg Fisher & Paykel top loader.
try rotating the agitator some and see if it drops into place on the shaft .
Oct 26, 2015 | Fisher and Paykel Washing Machines
Remove windwasher resvoir 02 exterra
most modern vehicles require either the inner wing removed or the inner wing and the front bumper to get to the washer bottle
Apr 07, 2012 | Cars & Trucks
I have an LG front loader washing maching, model# WM2277H* I have changed both the hot/cold water value and the washer is still leaking.
if leaking on front unit : check rubber seal front glass door. if it ripped you should change it.
If leaking behind unit : check water hose , is it placed properly ?
If leaking under unit : call technician to repair it.
good luck.
Mar 25, 2011 | LG WM-2277HW Front Load Washer
Common causes
door gasket damaged(torn)
Dispenser fault
Lint filter door not fully closed
It sounds like you might have a damaged outer bowl, broken by a foreign object(coin, wire,screw)
I am trying to change a headlight. I can't can not
The headlight assembly (1993 Grand Caravan) is held in place with three plastic "wing nuts" that rotate on the ball-end (front end) of the adjusting screws. One "adjusting screw" (the one on the bottom, inboard side) is not for adjusting, just for mounting. The other two adjusting screws take a torx T15 in the front end of the screw.
Removing the headlight assembly is somewhat of a trick - it seems like it takes a special tool to reach the "wing nut" and turm it 1/4 turn (90 degrees) CLOCKWISE (so the "wings" are vertical). When all three of these mounting "wing nuts" have the wings vertical, the headlight assembly just pulls forward and off these mounting nuts. Place the new assembly back over the "nuts", turn the 3 "wing nuts" another quarter turn, and the new unit is mounted. Probably not even a need to re-adjust the headlights, but you should check.
The PROBLEM, is that it appears to take a special tool to reach and turn these wing nuts without breaking them (yes, the old ones get brittle). I tried a socket (did not work), and then long needle-nose pliers (broke one wing nut), then a 1/2" open-end wrench (which at least worked). However, pushing the new assembly back over the wing nuts, I broke another wing nut. So, I broke 2 of the 6, and one was broken when I started.
Now I need to find replacements for these "wing nuts" ... any ideas where to get them?
Of course I can use some washers, some nuts to fit the fine-threaded adjustment screw, and some sort of bushing (maybe cut a short piece of rubber tubing to fit over the adjustment screw). Place double nuts (second nut to lock the first in place) and a washer, then the bushing onto the adjusting screw, then the headlamp assembly onto the bushing, then add another washer, and two more nuts (not too tight) to lock it onto the adjusting screw (which must still be free to rotate). Repeat for each of the 6 mounting points. I have not tried this yet, but ... it should work.
Fabricate a tool to turn the "wing nuts" using a piece of 3/8 inch ID tubing which you file or cut 1/8 inch by 1/8 inch notches on each side of a diameter line.
Apr 22, 2010 | 1993 Dodge Caravan
How do you get access to the washer bottle on a 2005 peugeot 307 hatchback?
it is mounted behind the front wing side panel on driver side. Either you can dismount the front driver side wheel plastic wheel arch flap to access it or complete dismount of front wing panel to see it in light.
Mar 28, 2010 | 2005 Peugeot 405
My front wipers washer and rear wipper wont work
change the motor ,its under the front wing
Jan 11, 2010 | 2000 Ford Focus
Suburban windshield wiper fluid not working for both front and rear. There is washer fluid in the tank; the lines are not frozen; but no fluid comes out both front and rear.
the pump has packed up its under the inner wing on the washer bottle and its one pump that does both by reversing the motor ,its a job to get too without removing the plastic inner wing
Dec 24, 2009 | Chevrolet Suburban 1500 Cars & Trucks
We removed the front wheel and need to get it back. On either side of the fork it has a wing nut and a locking washer. We do not know whether the washer goes next to the wheel hub on right behind the...
The washer goes between the wing nut and the fork. The fork will lock against the locknuts and cones that hold the wheel together. Just make sure that it is tight and the wheel does not wobble when done.
May 07, 2009 | Cycling
Kenmore front loader
the drain pump on this unit has a clean out. There is probably debris in the pump. remove the lower front cabinets. There are three screws almost at floor level that hold it in place and open the drain pump it has a handle on the drain pump that you can twist to remove.
Nov 04, 2007 | Kenmore Elite 45986 Front Load Washer
LG WFT1071TP Top Load Washer Logo
32 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
