Question about Whirlpool GEW9250 Electric Dryer
Overheats and sets clothes on FIRE
Back of drum gets RED HOT inside of dryer
    President:
  • Whirlpool Master
  • 2,651 Answers
Sounds as if your experiencing an air flow issue, check your venting.. it would be normal to see a red glow from the right side vents with in the drum( its heating up after all, and its merely a reflection form the heater located on bottom of frame, no way its gonna heat entire drum to "red hot")
Posted on Dec 24, 2008
Condenser dryer getting too hot
It looks like from what you are saying that the heat sensing thermostat has stuck in the on position and is not switching off when up to temperature!
I would obviously advise you not to use it because There is a serious risk of fire!
The thermostat is most likely mounted on the rear or top of the drum inside it is not an hard job to replace it, but I would advise you replace with exactly the same part and get a competent person to do the repair for you.
If you decide to repair it yourself first make sure it is disconnected from the mains supply and cannot be plugged in while you work on it!
You can perhaps find the part number in the user manual , but failing that remove the part and take to an appliance repair shop for advice
The following link may be of help in identifying the part and may also stock your part?
http://www.ebay.co.uk/itm/THERMOSTAT-CUT-OUT-HOTPOINT-CREDA-INDESIT-TUMBLE-DRYER-KIT-RED-SPOT-/161012863189?pt=UK_Irons_Presses&hash=item257d1d50d5
I hope this was of some help?
Regards
Apr 17, 2014 | Hotpoint Dryers
LG DLE5977s electric dryer drum not turning when warm
Could be one of the "overheat thermostat switches" has failed, or is failing.
Could also be a big buildup of lint inside the machine (where you cannot see it) causing the switches to trip.
In the back or the bottom of the machine are from 3 to 7 "overheat thermostat switches" that are put there to prevent fire.
When the get hot, if they are bad, they will shut off the dryer until they cool off.
Kinda sounds like one is "trippin' ". If you choose to fix it yourself, you'll need a good electrical test instrument and several tools to take it all apart.
A question to "fixya" might get someone to tell you how step-by-step.
Be blessed.
Mar 27, 2013 | LG DLE5977 Stainless Steel Electric Dryer
My dryer run all day and night if I would let it.And it takes one day to dry my clothes what is wrong with it
If it gets hot or warm in the drum but the clothes do not dry---the most common cause is a blockage between the drum, lint tube in the unit to the vent that flows the air to the exhaust outside.
If the drum gets much hotter than the air exiting the vent----clean all the from the drum to OUTSIDE.
Note: if there is not proper airflow and a lint build up exists there is the potential for a fire---Hundreds of fires are reported each year cause by this kind of trouble.
If the drum does not get hot inside you may have a bad igniter that heats the air (fires the burner uo inside the unit.)
Dec 07, 2012 | Roper RGX4634KQ Gas Dryer
Dryer not drying
Not a major appliance expert--but if the situation is as described with hot air out vent but not in the drum where the clothing is it seems to me you have a blockage between the drum and lint filter to where it reaches the vent tube---they do make long flexible brushes for this-----a suggestion: if you have a compressor try forcing air down from the lint filter with the vent tube removed to see if the blockage is there and will clear or not.
A blockage can be a fire hazard so if you do not find it have a tech out.
Dec 04, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Hotpoint Dryer has burning smell, checked vent--ok,checked screen just inside--ok. Drum turns. Four screws on back with depression space are extremely hot.
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Jun 27, 2011 | Hotpoint TDC32 Electric Dryer
I have a Hotpoint CTD00G. My wife reported to me the drum was not turning on the dryer and there was a smell of burning and when she stopped the dryer and opened it she said it was glowing red hot at the...
this would be the heating element, and as long as the thermal fuse is not bypassed it is all good. You might want to clean all the lint inside(taking the dryer apart) and outside(vent tube) of the dryer, this should be done at least once a year if not twice depending on the usage. The thermal fuse is a safety feature which senses temperature and blows(one time use) thus preventing a fire. Hope this helped Tim
May 15, 2011 | Dryers
My tumble dryer is overheating. it has burned the fuse in the plug . it worked fine again with new plug . but then it happened again a few days later. I noticed yesterday tha the clothes were extremely hot...
BE SURE TO UNPLUG YOU MACHINE FROM THE WALL BEFORE YOU START ANY WORK.
Your problem could be a Thermostats/Thermistors malfunction.
But this overheat condition also could be caused by a buildup of lint in the duct work, or a faulty blower motor/fan blade.
This will cause an overheat condition that you describe.
You will have to locate the air tube that is going to the dryer drum. Some general area the heater is located.
Is also where you will find most of them.
They normally are round/oval shaped and have two wires connected to them. Take off the wires and with an Ohm meter set to "continuity" check your thermostat/thermistor.
If you have continuity across the terminal it is not faulty.
Be sure to check all of the thermostats/Thermistors.
If this is not your problem then it will be the Control board if you have one on your machine.
Look for the fan blade to be in the air tube going to the dryer drum.
This is a FREE answer, Please Rate Me
Apr 14, 2011 | Dryers
New dryer looks like never been used (got in purchase of home), pulled lint trap to see for lint (clean) flashed light inside trap (clean), drum turns when on and clothes become warm/hot but not...
it is either the coil is going bad or the thermo safety is bad, there should be a wiring diagram(usually located in the back of the dryer behind the knobs, just unscrew the back plate) and you will see the safety limit. You can bypass and see if that is the problem, if it is make sure to get a new one as if you leave it bypassed and use it down the road it may cause a fire. Hope this helps tim
Sep 02, 2010 | Dryers
I just bought a gas dryer - takes forever to dry clothes
check the high limit switch/thermostat on the burner housing and if they are weak they will cycle the heat off too soon and it wont build the heat you have it set for,just bypass it with a jumper wire to test it,if this is the problem,dont leave it bypassed,replace it as it is a safety feature to prevent a fire
May 09, 2010 | Kenmore 95087 Gas Dryer
Whirlpool GEW9250 Electric Dryer Logo
141 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
