To help you understand and troubleshoot the error E000-000 for Canon ir2202 printer, please follow step-by-step instructions given below:
This error occurs due to high temperature readings on the printer. Occasionally, the fuser will run too hot. First thing is to perform factory reset on your canon printer but if it still show error code E000-000 again, then try to reset it in Service Mode. To do these, follow the steps below:
- Press ADDITIONAL FUNCTIONS, #
- Go to #7 Printer and Press OK.
- Go to #4 Printer Reset and Press OK.
- Yes = ( * )
- Power cycle unit.
Now check it the error is resolved. If issue persists, please try definitive reset. To do these, follow the steps below:
- Press Additional Functions key.
- Press #
- Press > to #7 Printer Function.
- Press Set.
- Press > to #4 Printer Reset.
- Press Set.
- Press <
Now restart the printer and check if it resolves the error. If issue persists, it is recommended to contact Cannon Support Center from the link given below:
https://www.usa.canon.com/internet/portal/us/home/contactus
GuruAid.com
