Question about Maytag Atlantis MAV6451 Top Load Washer
Stopped working My washer stopped turning on when the knob is pulled out
  • 1 more comment
  • john freeman Apr 12, 2007
    It does not turn on when I pull out the dial.
  • john freeman Apr 13, 2007
    A few months ago I noticed the following:
    I would load the washer, start it by pulling the knob walk away then after I thought the load was done I would open the lid and the washer would still be full of water, so I would have to hit the lid for the cycle to complete itself it would fill but not do the cycle. Now the washer is not doing anything at all, it's not filling, or anything. When I load it and select the cycle nothing happens. No noise, no water nothing.
  • niners805200 Dec 04, 2008
    when i pull the knob to fill the washer nothing happens. i replaced the fuse on the lid switch still nothing
  • 87 Answers
You have an intermittant lid switch.
Posted on Jun 08, 2007
I pull the knob to do a regular wash and nothing happens, no water no agitation. However, when I turn the knob to rinse it that works. This suddenly happened, was working before. Is it the knob?
Rinse on most washers is cold water your wash cycles can be cold hot and even warm. Problem You may have is a bad water feed valve Or Timer and possible bad wire harness at motor to timer
check water valve Turn washer to regular wash cycle pull knob on will washer fill ?
if water starts to fill then change washer temp if washer has this.
if water comes out on all settings water valve is fine.
Check the water both hot and cold that it is turned on;at faucet.
Your Kenmore Most likely has a bad water valve check for hot water side clog or not working.
Apr 25, 2015 | Kenmore 2982 800 3.5 cu. ft. Top Load...
Maytag stacked unit LSE7806ACE. dryer is fine , the washer will not fill or run, if I manually turn the timer to drain the tub spins and the lid switch works fine. But the unit won't do anything f
You have a timer problem, the contacts are welded in spin mode.
This is almost always caused by advancing the timer by hand when the dial is pulled out in the "ON" position, causing arcing of the contacts.
Sep 22, 2017 | Maytag LSE7806A Top Load Stacked...
The timer on the washer of my Kenmore laundry center model 98702 is not working. After putting clothes in and turningthe knob to the size load needed and pulling the knob out the washer will fill and then...
YES IT IS A FAIRLY EASY FIX AND SOUNDS LIKE you have diagnosed correctly... go to a site called
www.sears.com then click the parts direct link up top as they sale everything...
once on the parts direct link type in your model number in the upper left box and pull down the menu in the right box and click model numer if you got the correct model number a part diagram will come up and click on the box that has your timer and scroll down to timer it will give you availabilty as well as a price to order online.... good luck to you
Jan 06, 2011 | Kenmore 98702 Stacked Washer/Dryer
Washer Knob broke
You can use the knob to turn the washer to the correct cycle, and then use a pair of long nose pliers to gently pull the center hub out to start the washer. This is of course only a work around. I'll post more if I figure out how to fix this as well.
Jan 21, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Kenmore Washer, Loose Timer Knob
There should be a spring clip that holds the timer knob on. It or the timer knob may need replaced. Here is a picture of the timer knob and the spring clip. Sure hope this helps and best wishes.
Jul 23, 2009 | GE WBSR3140DW Top Load Washer
The main knob that you push in to stop and pull out to start works but won't turn the second part to choose cycle
Hi, Behind the knob there is a U shaped keeper. Pull that out and remove the knob. There should be teeth on both the knob and the inner dial. I have seen one or the other or both have the teeth ware away. See if this is the case. Part # WH01X10061 for the knob &Part # WH11X10033 for the dial. i hope this helps you. Please let me know if I can assist you further.
Vic
Jul 11, 2009 | GE WBSR3140DW Top Load Washer
GE washer timer knob
I can not set the timer on my GE washer. The knob just turns with out stopping.
Mar 04, 2008 | GE WDSR2080D Top Load Washer
Maytag Atlantis MAV6451 Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
