Question about Mitsubishi HC1600 Projector
How do I mount the HC1600 projector
Do I unscrew the level adjusters (3) ? I do not see anything on the bottom that says "ceiling mounting screws here"
  • 5 Answers
There are three screw holes on the bottom of the projector, 2 in the back by the feet and one in the front. they take a standard size, I think it is a 6x4....
I had a infocus projector mounted to the ceiling and took it down this weekend and put the hc1600 in using the same screw and same adjustable ceiling mount.
Posted on Jan 05, 2009
What size are the mounting screws?
The brass mounting holes on the bottom of Hitachi data projectors require a 4mm bolt.
Typicall 4mm x 10 is the shortest bolt I will use if when installing a projector on a ceiling mount, and 4mm x 20 will be the longest. I also recommend picking up 3 washers and spacers of varying sizes if you want to insure the projector is mounted level without warping whatever it is you are attaching it to.
BMS makes great locking mounts that come with all the mounting hardware you'd need to attach a projector to it.
Jan 03, 2010 | Hitachi CP-S240 Multimedia Projector
How to mount using a universal ceiling mount
first, find out the distance range on your projector for the best fitting image on your wall. next, what type of ceiling? if it's a drop ceiling, use a plate to span the 2 feet between braces and clamp it to them. and it's always safe to attach a safety cable from the mount to something sturdy, like wood or heavier metal. if you are putting it on a drywall ceiling, find a stud to screw it in to. do not use drywall anchors to hold it. if you can get above the drywall, use a backer board (2x4 or plywood, 1/2" or thicker) and screw the mount through the drywall into that. the other end of the mount screw into the bottom of the projector (3 or 4 m4 holes should be already on the bottom of the projector. use the screws provided. you'll have to adjust the mount so it matches the projector holes. once it's mounted, you'll have to adjust the image. go into the menu and select ceiling image, and adjust the keystone. pop in a movie and enjoy!
Dec 22, 2009 | Acer P3250 DLP Projector
I have a oracle protechnik hd-800 projector that doesnt have option in menu to image revolve. how can I ceiling mount. pls help rick
if the projector has places for mounting screws on the bottom of the case, it has an option for ceiling. go into settings for image. right now it may be set to front. select that and change to ceiling. if there are no places for mounting on the bottom case, it has no settings for ceiling mounting.
Oct 10, 2009 | Office Equipment & Supplies
How do i mount my hopper projector sv 10 to the ceiling
Yes it should be mounted upside down as you would not want to see the bottom of the projector all the time, unless the bottom is as good looking as the top, which I doubt. I wonder if you bought or got a ceiling mount rack with it. First mount the rack on the ceiling and then fasten the projector to it. And before that its picture has to be turned upside down too.
Aug 11, 2009 | Philips Hopper SV20 Replacement Lamp -...
Replcing bulb
There is lamp cover at bottom of projector, unscrew it, take it off, you will see Lamp inside that also fixed with screw, unscrew it and take it out, place new lamp and put thing in same way.
Jun 09, 2009 | NEC MultiSync LT280 LCD Projector
Image on screen is upside down
The orientation of your projector can be setup from the "Option" menu. You may need to select the "FRONT" and "CEILING" options to display the correct orientation of the image.
Jan 19, 2009 | Panasonic PT-L785U Multimedia Projector
Dell 2200mp mounting screw
Hi wspy
If the look right next to the holes there should be a screw size written on the casing itself.
Apr 29, 2008 | Dell 2200MP Multimedia Projector
Hitachi CP-S225 projector - spec for screws
Hi Brian
The $18 footpiece you will unfortunatelly have to pay if you want the right thing.
As for the screws to mount the bracket onto the Projector , simply look right beside the hole at the bottom. Normally the size screws that you require is printed in the plastic.
Apr 15, 2008 | Office Equipment & Supplies
Ceiling mounting
I unscrewed the two rubber stands on the bottom and used those to screw it to the ceiling mount. Seems to work pretty well!
HTH!
Dec 19, 2007 | Toshiba TDP-S8 Multimedia Projector
Mitsubishi HC1600 Projector Logo
398 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
