Question about Sony Handycam DCR-DVD205 DVD Camcorder
Error message + disc opened acidentally + recording disabled
Hello, I have been facing this problem with my DCR-DVD205. When recording, all of a sudden it gives and error message "disc error". When I restart the camcorder, at some point of time "disc cover opened accidentally, please power on" is popped up. When I restart, it accesses the disc and says "recording on the disc is disabled". If i try try to finalize the disc, it won't let me, and so disc becomes useless, I have wasted a lot of discs by now. I called Sony and they say they are going to charge some hefty amount. Truly speaking, being a student I wont be able to afford another 200 bux for the repairs. I am hoping to get a solution here. Please, if possible give me your feedbacks/solutions regarding the matter. Thanks
    President:
  • 4,402 Answers
1. cleaning the laser lens with isopropilic alcohol and q-tip
2. Try the reset button on the bottom of the camera. Tilt your camera and look below the LCD Display Backlight button on the bottom edge of the curved portion of the camera. You will need a paperclip or tip of a ball point pen to push the recessed little button. Place the camera on a level surface and try again. We find that the camera is very sensitive to tilting, as it gets older.
3. Make sure you format format at was FAT not fat32
4. All you need to do is "Quick format" the disk with the CAMERA rather than the memry stick plugged into the computer drive.
5. For sony error c:1301 using mini cd's: there is a program that recovers data from cd's that works with disk that have this error. It called "cdroller" Homepage is : www.cdroller.com
6. just take the memory stick off and re-insert it lot of times.. just keep doing it.
Posted on Feb 11, 2008
How do I transfer video to PC
The DCR-DVD205 does not support a direct connection to a PC. You have to record to a disc on the camcorder and then play the disc on the PC. Please see the instructions beginning on page 61 of the manual.
May 24, 2012 | Sony Handycam DCR-DVD205 DVD Camcorder
My camera is displaying a message that states "movie recording disabled" when I try t record something. I have no idea how it got there so I have no idea how to inable it again. Any suggestions?
Follow this procedure to troubleshoot when Recording disabled is displayed by the camcorder.
  1. Verify the disc being used has not been finalized. It is not possible to record additional video on a finalized disc.
  2. Attempt to record on a different disc.
NOTE: If the error is still displayed after performing these troubleshooting steps, service will be required .
Jul 31, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
My Sony cancorder keeps saying "no disc" when there is one??
    The optical lens needs cleaning or replacement.
Thanks for using FixYa!
Apr 28, 2009 | Sony Handycam DCR-DVD205 DVD Camcorder
"MOVIE RECORDING DISABLED"
Breanna,
Unfortunately, it looks like it is a problem with the disc you have in the camera. If you have another disc, put it in and see if the error message remains. Obviously, the new disc won't have your original video on it, but it will help determine if the cause is the disc.
Please also see this post on FixYa: http://www.fixya.com/support/t413486-dcr_dvd108_problem
Mar 21, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
I have a HANDYCAM SONY DCR-DVD 106, and I keep getting the following message error - "Disc error. Unsupported format - 13:023, with regard to a mini MEMOREX DVD-R.
Disc error. Unsupported format means that ur camera does not support the format of this disc it might not support DVD-R or DVD-RW and supports the DVD+R and +RW try the other format disc and let me know if it resolved , check the manual it is stated on the box or manual which format it supports, if it does not solve ur problem try some other brand instead of MEMOREX try sony,hp,fuji,philips and see actually these sony cameras they are sometimes locked by the manufacturer to only use the original discs for monopoly sony acts like that in every product
pls do rate me if i fixya problem
regards
Zohail
Feb 23, 2009 | Sony Handycam DCR-DVD205 DVD Camcorder
C:13:02, Disc error. Remove disc. Recording disabled.
I'm sorry to say, that all disk manufactures are not the same. If you used a "no name" disk, then the quality may not be what you want, although in rare cases, even good companys like Memorex can make a bad batch or two. Just try another disk. Let me know if that works by leaving a comment. If this works for you, rate my solution a fixya!
Rob
Jan 29, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
Disc error! remove disc
actually ur lens got weak and it is unable to prepare the disc for writing if u can see ur lens u can try cleaning it with soft cloth very soft or u can buy a dvd cleaning kit for ur camera it will help other wise u have to change ur lens
pls rate me if it helps
Dec 16, 2008 | Sony Handycam DCR-DVD205 DVD Camcorder
Sony handycam DCR-DVD205: use new ac adapter or reinsert
Remove the battery insert your AC adaptor turn on your DVD CAM if it work fine reinstall the battery set CAM to off position the amber light should be on to indicate battery is charging
You got that msg depend what function you use if the CAM calculated the battery not enough to run or finish this task it display that msg for you to use AC adaptor to ensure no power corrupted such in formating the disc
Some time system control is faulty even you use AC adaptor it still display this msg I hope that is not in your case
Let me kown how you go with this problem
Nov 30, 2008 | Sony Handycam DCR-DVD205 DVD Camcorder
I want to connect my DCR-DVD205 to my imac
Correct me if I am wrong, but isn't this a DVD camcoder, as in records directly to 3" DVD's?
If so, just put your mini DVD into the tray as you would a normal DVD. There is a smaller inner ring on the dvd tray made for 3" discs to sit in.
From there you can edit it directly from the DVD to the computer, and burn it back out onto a normal blank DVD.
Hope that all makes sense =)
Apr 11, 2008 | Sony Handycam DCR-DVD205 DVD Camcorder
Problem useing tdk dvd-rw
Jun 05, 2007 | Sony Handycam DCR-DVD205 DVD Camcorder
Sony Handycam DCR-DVD205 DVD Camcorder Logo
401 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
