Question about Honeywell Programmable Thermostat Heater
Heil DC90 gas furnace need to find reset or limit switch
I have a heat exchanger problem and no money for repairs until Jan. Short term solution is to hit rest(limit) switch. Cannot locate switch.
3 Suggested Answers
Therinnaiguy
  • 1420 Answers
SOURCE: i have an older model heil quaker natural gas
Test to make sure the limit switch is still working prior to the rewire. Use an Ohm meter and test for continuity. If good, use some good quality 14 or 12 guage wire to rewire. If the unit has an in-line fuse, you will need to replace that as well.
Posted on Mar 27, 2010
  • 3328 Answers
SOURCE: I have a heil dc90 furnace wondering what the
lpg is 12 to 14 inches wc nat gas is 4 inches wc ,
Posted on Feb 02, 2011
My good man furnace model gmh80903bnca will not get to temp fan shuts off and burners keep burning then kicks off on high limit then starts process over but never gets to temp set at 655
If you have a switch that can manually turn on the fan, try it to verify the fan works. This is what I think is happening. The normal operation should be thermostat calls for heat, inducer fan comes on, pressure switch closes, igniter glows, main burner ignites and then in 30 or so seconds the fan comes on and stays on until the thermostat is satisfied. Once the thermostat is satisfied the burner shuts off and the fan runs for approx 120 seconds then shuts off. I think the control board that automatically turns your fan on is faulty. On most modern furnaces if the auto fan control fails and the furnace gets to hot and limits, when the limit opens and shuts off the burner it also energizes the fan motor to cool the heat exchanger.
Jan 13, 2018 | Heating & Cooling
Tempstar DC90 pilot light or burner keeps going out. The furnace will run continuously. Even if I turn heat off at the thermostat. I have to kill power at the panel box to get it to shut off. Then I've...
The reset button near the ignitor is a high temperature limit safety switch. When the furnace gets too hot and the manual reset limit switch is tripped, it most likely goes into a 'safe' mode where the gas control is locked out electronically and the blower is made to run continuously to rid the heat exchanger of the excessive heat. This will continue until the reset is pushed and the power is cycled off. It will remain an endless cycle unless the reason for the overtemperature condition is not corrected.
Your furnace 'temperature rise' is getting too high due to a lack of air across the heat exchanger for whatever reason. Some of those reasons could be a restricted air filter or a blower motor that's cycling improperly on its internal winding thermostat. You could also have a dirty air conditioner 'A' coil (evaporator) on top of the furnace restricting the air flow. Nevertheless, you are going to have to have it serviced by a reputable service company's technician to correct what's wrong.
Nov 13, 2014 | Heating & Cooling
Can you install class-A cotton foil-backed insulation in a furnace heat exchanger duct
HVAC Insulation Cotton thermo acoustic duct wrap reduces noise and increases HVAC...
None of these products are used INSIDE the heat exchanger. If the problem is a cracked heat exchanger, you may be able tp purchase replacement parts to repair it
How to Fix Cracked Furnace Heat Exchanger DoItYourself com
The heat exchanger must be free of cracks and holes due to the potential of carbon monoxide leakage. You can probably make a short term repair with sheet metal and high heat furnace refractory cement, but that is a quick fix only.
Please be aware of the potential for a lethal situation due to carbon monoxide poisoning.
May 26, 2014 | Cozy (W352E) Heater
Furnace wont run until i pull a hose from the pressure switch
ok that switch is called proving switch and if it runs when you pull hose off that means switch is stuck-, normal ops- call for heat power fan inducer start and closes proving switch normally two are a dual switch positive connects to fan discharge and negative connects to heat exchanger (fan suction )this is to insure air movement threw heat exchanger( pressure differential )then and only then a trial for ignition starts check for clog in other end of tubes
If you need further help, I’m available over the phone at https://www.6ya.com/expert/mike_9693b5ad75773352
Feb 21, 2014 | Honeywell Furnace Air Pressure Switch...
Janitrol gmp gas furnace ignitor troubleshooting 125 blink
if it is shutting off abruptly the limit is either wired wrong or set wrong. If the fan comes on and blows the flame out there is a hole in your heat exchanger which can result in fire or carbon monoxide poisoning. Have an experienced tech take a look at it to be safe.
Nov 25, 2017 | Heating & Cooling
Furnace lights blows heat in cycle, pops sensor on blower and continuosly blows air until button on sensor is pushed back in
If the sensor knocks the unit off and the the fan keeps blowing without a flame ,the limit (the sensor is a limit comptroller that turns off flame @ a set temp and allows the fan to run until the heat exchanger cools to @ set temp) has out lived its lifetime and needs to be replaced.the button is a manual reset that once reset would allow the unit to continue to run flame and blower at the same time after having been set once, if it is an ongoing problem and needs to be reset more than once then replace the limit control (sensor) in kind. (With the same mode and set-points for the limits)
Oct 25, 2012 | Intertherm 56000 Btu Gas Furnace
Unit does not stay lit
A few questions for you. If the thermostat is satisfied as in turned below room temp, does the blower shut off. Are the filters clean? Furnaces have a limit control that governs how hot the heat exchanger runs. If the limit switch opens for some reason the fan or blower will continue to run until the limit switch closes. So dirty filters? A very dirty blower wheel? A blower motor that is not coming up to speed, Could just be a bad limit switch that is opening up at a lower temperature than it should. I would also check the pressure switch sensing tube. The end could be blocked with deposits
Sep 06, 2017 | Heating & Cooling
Flame comes on, fan runs after a few minutes then unit will shut down, will sit a few minutes then sart back up, seems to be short cycling all happens within 8 minutes. \r\nmodel QVB-2505 PS. What...
there are limit sensors around fire box.you need to remove front cover.if flames are coming out of fire box there's a restriction in air flow. on older furnace could be fan belt . air cond. coil could be pluged up are all the vents open and have good air flow?you check limits by pulling one wire and check with ohm meter.there normally closed and open when too hot.most limits around fire box don't reset them selves.on some draft inducers there's a limit if it is tripping then theres a vent problem.theres also a limit on the fire box (heat exchanger) that may or may not self reset.
Jan 12, 2011 | General Heating & Cooling
I have a Lennox Whisper Heat that when a call for heat comes, the pilot lights as it should, then after about 30 seconds the blower fan comes on, then its about another minute before the burners light....
Yes it should go in this sequence, first exhaust fan, after establishing air flow you get a pilot, after signal from pilot is established you get main burners, then they have to reach a set temperature on the high limit and then the blower comes in. Now you have several over heat safety sensors one of them could be tripped check by powering the furnace down and see if they have a reset button on them, some do some do not. If not it should be the sensors closest to the heat exchanger and blower assembly use a volt ohm meter and check them should be normally open until temp is established then closed. This is easier done than it is to describe, now locate the high limit switch and bulb and see if it is open across the contacts it should be until it hits temp then it closes to start the blower. Hope this helps instead of confusing the hell out of you. Take your time locate the items then test.
Dec 19, 2010 | Heating & Cooling
Heating & Cooling Logo
1,241 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
