Question about Mitsubishi HC1600 Projector
Where does mounting screws go on the bottom of the HC1600 project
HC1600 projector ceiling installation:where are the mounts for the ceiling installation on the HC1600? Is it the three rubber adjustment screws?Paul Fullerps- trying to get it up before guest arrive for Christmas Eve.
  • 155 Answers
SOURCE: Benq 6110 - mounting projector onto ceiling
You need to navigate to the 'advance' menu and under the 'mirror' setting select 'ceiling front' or 'ceiling rear' depending on whether you are front or rear projecting. It should all be on page 29 of the manual.
Hope this helps
Matt.
Posted on Apr 01, 2008
  • 5 Answers
SOURCE: How do I mount the HC1600 projector
there are three screw holes on the bottom of the projector, 2 in the back by the feet and one in the front. they take a standard size, I think it is a 6x4....
I had a infocus projector mounted to the ceiling and took it down this weekend and put the hc1600 in using the same screw and same adjustable ceiling mount.
Posted on Jan 05, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: Settings on ViewSonic PJ513D Ceiling Mounting
The user's guide says for ceiling mounting,
"Set Front Ceiling in the System Setup: Basic > Projector Position menu after you turn the projector on."
The user's guide is on the CD included with the projector as a pdf file. You can also download the user's guide here:
http://www.viewsonic.com/assets/006/5619.pdf
If you find this solution gives you what you needed, please take a moment to rate it. Thanks for asking here!
Posted on Feb 22, 2009
  • 269 Answers
SOURCE: ceiling mounted projector image upside down. how
download the manual from infocus
Posted on May 13, 2010
heathgr
  • 442 Answers
SOURCE: projector is mounted on ceiling mount. Projector
try it without the ups unit, just in case the ups unit is dodgy
Posted on Jun 09, 2011
I want to attach a Vivitek 650HD projector to a ceiling mount, but am not sure if I mount it upside down. There doesn't seem to be a "flip" function to flip the picture.
I am 99% sure most projectors are mounted upside down. There should be a way to simply flip the image electronically via the option menu.
In most projector OCD menu (keep in mind you may want to do this before mounting), under the "Installation" or "Initial Installation" section should be an option about Projection mode/method. The options should allow you to pick front, rear, ceiling, or ceiling+rear. This sets the project to know when it will be in front of the screen, behind it, and/or attached to the ceiling (which it knows will be upside down). Then you simply set it to ceiling, mount the projector, and finish your other adjustments as needed.
Apr 27, 2011 | Televison & Video
What size are the mounting screws?
The brass mounting holes on the bottom of Hitachi data projectors require a 4mm bolt.
Typicall 4mm x 10 is the shortest bolt I will use if when installing a projector on a ceiling mount, and 4mm x 20 will be the longest. I also recommend picking up 3 washers and spacers of varying sizes if you want to insure the projector is mounted level without warping whatever it is you are attaching it to.
BMS makes great locking mounts that come with all the mounting hardware you'd need to attach a projector to it.
Jan 03, 2010 | Hitachi CP-S240 Multimedia Projector
How to mount using a universal ceiling mount
first, find out the distance range on your projector for the best fitting image on your wall. next, what type of ceiling? if it's a drop ceiling, use a plate to span the 2 feet between braces and clamp it to them. and it's always safe to attach a safety cable from the mount to something sturdy, like wood or heavier metal. if you are putting it on a drywall ceiling, find a stud to screw it in to. do not use drywall anchors to hold it. if you can get above the drywall, use a backer board (2x4 or plywood, 1/2" or thicker) and screw the mount through the drywall into that. the other end of the mount screw into the bottom of the projector (3 or 4 m4 holes should be already on the bottom of the projector. use the screws provided. you'll have to adjust the mount so it matches the projector holes. once it's mounted, you'll have to adjust the image. go into the menu and select ceiling image, and adjust the keystone. pop in a movie and enjoy!
Dec 22, 2009 | Acer P3250 DLP Projector
I have a oracle protechnik hd-800 projector that doesnt have option in menu to image revolve. how can I ceiling mount. pls help rick
if the projector has places for mounting screws on the bottom of the case, it has an option for ceiling. go into settings for image. right now it may be set to front. select that and change to ceiling. if there are no places for mounting on the bottom case, it has no settings for ceiling mounting.
Oct 10, 2009 | Office Equipment & Supplies
Image on screen is upside down
The orientation of your projector can be setup from the "Option" menu. You may need to select the "FRONT" and "CEILING" options to display the correct orientation of the image.
Jan 19, 2009 | Panasonic PT-L785U Multimedia Projector
Dec 24, 2008 | Mitsubishi HC1600 Projector
Hitachi XGA cp-x275
Yes, this unit is made for either or solution. If you look at the under side, you will see three screw holes, these are for your mount kit which you can get form http://www.mountsandmore.com/Projector-Ceiling-Mounts-C13810.html?refid=G6435.%22projector+ceiling+mount%22&gclid=CIyfl7G_2pgCFQEoGgodXmajdw
There are other sites as well.
Hope this is not too late.
Oct 02, 2008 | Hitachi CP-X275 Multimedia Projector
Hitachi CP-S225 projector - spec for screws
Hi Brian
The $18 footpiece you will unfortunatelly have to pay if you want the right thing.
As for the screws to mount the bracket onto the Projector , simply look right beside the hole at the bottom. Normally the size screws that you require is printed in the plastic.
Apr 15, 2008 | Office Equipment & Supplies
Ceiling mounting
I unscrewed the two rubber stands on the bottom and used those to screw it to the ceiling mount. Seems to work pretty well!
HTH!
Dec 19, 2007 | Toshiba TDP-S8 Multimedia Projector
Mitsubishi HC1600 Projector Logo
46 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
