Question about Hitachi DZ-MV550 DVD Camcorder
Cannot get disk door to open
Have tried everything in the book, battery removal and so on. Door will not open, unit will not turn off by itself. Only way to stop is to disconnect battery.
    Guru:
  • 449 Answers
move your recorder close to your PC then connect the recorders DVD drive to your PC turn one the PC and eject the disk remove the draw front then retest it. if this doesn't work The machine may have a mechanical issue in the door mechanism that you cannot fix yourself. You will need to take it to a service technician. Don't try to pry the door open. Doing so will void any warranty and also possibly expose you to dangerous laser emissions.good luck happy holiday
Posted on Dec 24, 2008
    Top Expert:
  • Hitachi Master
  • 78,257 Answers
When u press the door button the signal is sent to a circuit board that sends the signal to open the door, the switch is just a ground signal, this circuit board is defective, if the unit is old u might contemplate replacing it, the repair cost will be very high, most likely $100's.
  • 3,037 Answers
Hello derjuice
You need to take off the outer panel and then manually open the door by moving the mechanisms once the outer panel is off. Sounds like the main circuit board may be fried. Does anything work on it still?
bestdarngood
How do i rove the clock spring 2012 nissian par\th finder
remove clock spring in steering wheel.
step 1 , disconnect battery minus lug.
then defeat air bags as the FSM book directs,(or great danger waits)
BOOM
Battery disonn.folly 110. "under collateral damage"
quote
Whenever the negative battery cable is disconnected the following components will require resetting. The Idle Air Volume Learning, Steering Angle Sensor Neutral Position, Sunroof Memory Reset/Initialization, Automatic Drive Positioner System, Audio presets and Navigation. Use the CONSULT-III diagnostic tool, or equivalent to perform the required resets. As necessary, refer to Battery Reconnect/Relearn Procedures.
he automatic back door system, if equipped, must be initialized anytime the battery has been disconnected. Close the back door. Open the back door with the automatic open feature. Do not stop the process until the back door opens completely.
end .
begin:
  1. Disconnect the negative battery cable. (wait 30min)
  2. Disconnect the positive battery cable.
  3. Set the front wheels in the straight-ahead position.
  4. Remove the air bag module.
  1. Remove the steering wheel.
  2. Remove the column cover upper and lower.
  3. Disconnect wiper and washer switch connector. Then while pressing tabs, pull wiper and washer switch away from spiral cable to remove.
Disconnect lighting and turn signal switch connector. Then while pressing tabs, pull lighting and turn signal switch toward driver door to remove.
  1. Remove the screws. Then while pressing the tab, pull the spiral cable away from steering column assembly. CAUTION Do not disassemble spiral cable. Do not apply lubricant to the spiral cable.
  2. Disconnect the spiral cable connectors.
With the steering linkage disconnected, the spiral cable may snap by turning the steering wheel beyond the limited number of turns. The spiral cable can be turned counterclockwise about 2.5 turns from the neutral position.
end remove.
to install, read the FSM book
or login to alldata.com
the cars steering angle is lost in the process.
so.....?????
steering angle sensor calibration after installing spiral cable.
Jun 25, 2014 | 2002 Nissan Pathfinder
I have a Samsung DVD R160 recorder. A few days ago the recorder was not on and it was making a noise like it was trying to read a disk. This went on for quite a while. I then turned it on and it would...
Try this, look for a small hole on the front of the unit.Use a pin and press in to see if it opens,ejects the disk .If no hole try seeing if you can press ,lift,pull at the door/slot while pressing the open door/eject either on the unit or with the remote control.It sounds like you may have a bad CD/DVD (copy) that the unit is trying to read/load but can't. keep trying to eject CD/DVD if this doesn't work unplug unit for 5 minutes,try open door again do press and hold open repeatedly I know it's frustrating but it just may eject.Don't use this recorder for playback of DVD buy a $30 DVD player the cheaper the better they play anything.GOOD LUCK
Jan 04, 2011 | Samsung DVD-R160 DVD Recorder
Craftsman 3/4 hp Chain opener.....Door opens and closes by itself. No blinking light, looks like everything is clear with sensors. Half opens then closes, then door completely closes and 5 seconds later...
You most likely have a bad wall control or the wiring to it. An easy way to check this is to remove the connection at terminal #1 on the rear of the motor unit. Just remember that your wall control will not work with this wire off. Your remotes will still work though.
Dec 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door opens by itself in storm
Here are some things you can check.
Look at the LED light next to the SMART/LEARN button on rear of the motor unit. You may need to remove a light lens cover in order to see it. If the light is flashing rapidly this means you have a stuck button on one of your remote controls. Take the batteries out of each remote control. When you remove the batteries from the bad remote, the light will stop flashing. This remote needs to be replaced.
If one of your neighbors remote controls is inadvertently programmed into your receiver, you door will open when their remote is activated. If this happens you will need to clear out your receiver and reprogram your remote controls. Press and hold the smart/learn button for 6 seconds or until you see the small LED light near the button turn itself off. If the above steps have been followed and the symptoms continue, there may be an electronic short in either the wall control button or the receiver logic board. In this case, remove the wall control wires from terminals 1 and 2 on the motor unit. Should the symptoms persist after the wires are removed, replace the receiver logic board. If the symptoms stop with the wall control wires removed from the motor unit, replace the wall control button, and the wires leading to the wall control button.
Aug 25, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Champion garage door opener opens by itself and the light does not come on
May 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a Craftsman 13953919 door opener. My garage door opens during the day when I am not home. The alarm company calls me to let me know, and the police have been by twice. Nothing is stolen, so I can...
Here are some things to check.
Apr 14, 2010 | Sears Craftsman LiftMaster Chamberlain...
My garage door opens by itself, what makes it do that, it leaves my house open for burglars
Feb 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
Can't open the DVD door. Wen I turn on the DVD Player, it starts reading a DVD that's stuck inside, and after a while e turns off alone. The door doesn't open and it seems to have some process runing that...
you'll have to remove the top and remove the disk that way. there's a top bracket on the dvd drive to remove before you can get to the disk. and unplug the unit first!!
Aug 12, 2009 | Philips DVDR3330H DVD Player/HDD Recorder
Sony Mavica MCD250 -"Door Open" error message
have that opened up in a service center and tell them that you dropped it. they will tell you that the sensor is busted. that will have to be replaced. hope this helps.
fixya!
Jan 29, 2008 | Sony Mavica MVC-CD250 Digital Camera
The ice flap in the door does not open when ice falls down the chute
The door is opened by a electrical solonoid, not by the ice itself. This solonid gets corroded due to moisture, To axcess the solonoid remove water tray remove three torx screws removing trim panel, remove 3 more torx screw holding dispenser module to freezer door two on either sides and one by paddle. Maytag has a kit called a fountain door kit that has everything to rebuild the ice door system,
Jan 10, 2008 | Maytag MSD2454G Side by Side Refrigerator
Hitachi DZ-MV550 DVD Camcorder Logo
Top Hitachi Video Cameras Experts
Mohamed Ismail
Mohamed Ismail
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
