Question about Vivitar ViviCam 5385 Digital Camera
Black screen I don´t know why the screen gone black, when I take a picture is all I get. I don´t know what to do, is annoying. I´ve tried eveything from cleaning the lens but nothing is happening. Please help me to find a solution!
I have the same problem. Fine one day and a black screen the next. I called Vivtar and they were no help. They wanted me to send it in and let them repair it at my expense. don't think so. everything works perfect on the camera...but the screen is black and so are the pictures. Good Luck!
Posted on Apr 30, 2007
Temporary black screen on Vizio XVT553SV
Please try to turn off the closed caption function by access the TV set up manual
Oct 25, 2017 | Vizio VO47L 47 in. LCD TV
46in Vizio LCD HDTV distorted black picture when tv is turned on
Hi There are three things that can cause this problem. Your lcd screen, t-con board or the signal board. Most likelly in your case since you say it's only half the screen it's going to be your t-con board. You can try removing it and cleaning all the contacts and replacing it see if that helps. If that doesn't help then replace it. If that does not solve it then it's going to be your screen.
You can get parts at www.interliquidparts.com
Nov 28, 2011 | Vizio VW46LFHDTV10A 46 in. LCD TV
My clothes do not seem as fresh as usual and some even smell damp rather than washed (some feel a bit dry too). The soap unit has gone really black from the back and the pipe underneath it is black from...
Mine does this too. I've also noticed that no water is visable through the door window and I'm sure the bottom of the drum should be submerged. I've been adding a bowl of water after the m/c has taken water in, which seems to help, but I don't know what the long term solution is. But definitely get a cloth out and clean the soap unit and housing!
Jul 15, 2011 | Hotpoint WMA46 Front Load Washer
I have a Cannon PowerShot S2 IS digital camera, about 5 years old. The LCD Monitor and Viewfinder both only show a black screen with some of the Dispay Icons across the top and bottom, and after a few...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 06, 2011 | Canon Cameras
After taking pictures with bright colors, image in the viewer blink black/white over brightly lit objects...Help, it's making me crazy!
You're seeing blown-out highlights. These are the portions of your picture that have been so overexposed that they've gone pure white, losing all detail. This is generally considered a bad thing so the camera is warning you about it. But the camera doesn't know what you're taking a picture of, things like the sun reflecting off polished chrome should go pure white, so it's just a warning.
Usually the proper fix is to reduce exposure, bringing back the lost details. This risks losing details in the shadows as they go pure black, but that's generally considered not as bad. After all, we don't expect to see things in the dark.
That was the long answer. The short answer is to press up/down on the multiselector to cycle through the different views of your picture.
May 18, 2011 | Nikon D80 Digital Camera with 18-55mm Lens
My Sony Vaio VGN-NS110D Laptop computer won’t boot up, it cycles through to a black screen with the mouse pointer there which I can move. Apparently this is called the ‘black screen of death’! I can’t do...
Try these 1) Shut down the system 2) Remove the battery 3) Hold down the power button for say 2 minutes 4)Put the battery back 5) Boot the system
If you still hit the black screen with a cursor: 1) Wait for 2 mins at the black screen 2) Just type in your windows password (if you don't have one hit enter) and press enter 3) Wait for another 2-3 mins 4) Hit Alt Ctrl Delete and go to task manager (this time it should take you to the task manager) - fingers crossed LOL 5) Now do new task - explorer.exe
Hopefully you should be back in action.
Note, this is a work around and for a permanent fix either try and clean your system (check for viruses) or reinstall the system. Hope this helps.
Oct 07, 2010 | Sony Computers & Internet
It only shows a black screen
I was having the black screen problem intermittently (of course when you really want to take a picture quickly). I downloaded v1.1 of the firmware from olympus (via the Olympus Master 2 program) and the black screen problem has not reoccurred yet. Hasn't been tested over a long period of time yet, but that seemed to fix it.
Jul 12, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
My Vivitar 5386
have u checked battery? and otherwise i duno
Apr 01, 2007 | Vivitar ViviCam 5385 Digital Camera
Vivitar ViviCam 5385 Digital Camera Logo
181 people viewed this question
Top Vivitar Cameras Experts
Steve
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
