Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
Bosch diswasher detergent dispenser doesn't open during wash cycl
The dispenser doesn't open and release detergent during normal washing cycles.  The dishes appear to be clean, but there is detergent remaining in the compartment after cycle completion.  This is anew problem.  I can open the lid manually with no problem so nothing appears to be in the way. The model number is SHV66A and is the premium dispenser.
  • 1 more comment
  • Anonymous Jan 02, 2009
    same
  • yuckydishes Mar 30, 2009
    I have the exact same problem. Ideas? Can I replace the dispenser myself?
  • Anonymous Mar 15, 2014
    My k4 premium does not dispense detergent
I've been told we can replace the dispenser. See AppliancePartsPro.com. Part AP2834000
Posted on Mar 31, 2009
I own a Bosch home Dishwasher - Model SGV53E03GB-74 - where the wash tablet discharge cavity opens in the wash cycle but doesn't allow the tablet to drop, so the wash is ineffective and needs
Sounds like the dispenser door isn't opening. If it isn't being blocked by dishes, the dispenser door spring might be broken, the dispenser release solenoid could be faulty, or not getting power from the control panel. While you're waiting for it to get fixed, you can just put the detergent in the bottom of the dishwasher and run it on normal cycle. It also possible the dispenser door isn't opening wide enough for the puck to fall out. Make sure the door opens freely under it's own spring assist.
Nov 26, 2014 | Bosch Dishwashers
I have a front loading Kenmore washer and when i put liquid detergent and fabric softener, the liquid flows into the machine - should the detergent and fabric softerner remain in their compartements until...
Yes the detergent and softener will stay in the dispenser drawer until the correct time for them to be dispensed. The detergent is dispensed during the main wash cycle and the softener will not dispense until the rinse cycle
Jul 26, 2011 | Kenmore Washing Machines
Fills with water then does not rotate, also does not spin
Check for large items of clothes being tangled if the Bosch washing machine doesn't spin. The weight could not be evenly distributed in the drum and the spin cycle will have been disabled to prevent damage to the clothes..
Load the drum with large and small clothes together and run the entire washing cycle and spin cycle again.
Add more powder and run the entire washing and spin cycle again if you haven't found tangled large items, but the spin cycle still failed. This indicates the amount of cloths was too small.
Add 1 tablespoon of fabric softener to 1 pint of water and pour it into the main detergent dispenser if there's no tangling and the load was a normal size. The cause would have been excessive suds because of too much, or the wrong kind, of detergent. Use HE (High Efficiency) detergent in Bosch washing machines.
Nov 01, 2010 | Bosch Washing Machines
Detergent dispenser on SMEG DWF 44SS1 doesn't open during cycle - any ideas?
this is Usually caused by a tablet sticking in the Detergent Dispenser. This will stop the Detergent Dispenser from opening at the correct time on the wash cycle.
Oct 18, 2009 | Smeg 24 in. DWI612 Built-in Dishwasher
Bosch Slimline dishwasher Exxcel. Detergent dispenser does not open during the wash
take door outer panel off and dispenser is exposed. start cycle and with a multimeter, check power comes to the dispensor during the cycle. if you get power, then the dispensor is faulty. if no power, then the module is faulty
Aug 05, 2008 | Dishwashers
Bosch Aquasensor Detergent Dispenser door wont open during cycle
Behind the dispensor door there is a small selanoid you will need to replace this, test to see if its open circuit, alternatively you can just place the detergent in side the machine before you put it on a wash cycle is this would have the same effect. the only cycle you can not do this on is the one with the prewash, I think its number 1.
Nov 17, 2007 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Detergent dispenser
As far as I am aware, there IS NO dispenser for bleach, you have to put bleach in drum before adding clothes and starting cycle. The far right compartment is only for "pre-wash" cycles, and if no pre-wash is selected, water will run through ALL compartments at the rinse stage..... Oshie
Feb 28, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
1,136 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
