Question about Mitsubishi WS-55809 55" Rear Projection Television
Screen turning pink
When I turn my Mitsubishi WS-55809 on the screen will turn have a pink overlay. You can see the picture but it has a pink color to it. After it stays on for a while it goes away. Any help would be greatly appreciated.
  • Tim Adams Apr 12, 2007
    "If the color jumps in after warming up, it could be a bad solder connection." This is exactly what happens. It's been on for about 5 hrs and it hasn't happened since. Is this something that I can possible fix or/and will it just get worst?
    Thanks alot
    Sergeant:
  • 308 Answers
If the pink overlay goes away gradually, you could have weak picture tubes (CRT's) If the color jumps in after warming up, it could be a bad solder connection. If you haven't had a good picture to watch for a long time, I would be tempted to put the money towards a new HDTV set as those older Mitsubishi Rear Projection TV's had a Lot of bad solder connections in the past, and by fixing one problem another could crop up in the near future.
Posted on Apr 12, 2007
My Mitsubishi ws-55809 works fine although the screen turn pink but the picture is still visible. After a while it goes back to perfect color. Then it repeats this back and forth. Sometimes it will fl
Problem is likely on the small circuit board that plugs onto the bottom of the red picture tube---be careful as dangerous voltages in and around that board---each of the three picture tubes has a small board that plugs on the end of the tube.
Oct 21, 2012 | Mitsubishi WS-55809 55" Rear Projection...
My mitsubishi ws-55809 works fine but the screen turns pink and after a while it goes back to perfect color. Does this back and forth
Someone with moderate experience would have to examine the red crt printed circuit board--I have seen some of these that develop a cracked ground path on that board but usually it is pink except on the sides depending which ground path is bad.
Ws 55809 with a 2,1 error code. machine has been flickering green screen more frequenly. not you turn it on get white screen then it shuts off. is this nachine repairable? please help.
2,1 IS x-ray protection, problem is either in the High Voltage circuit or with one of the three picture tubes.
It should be repairable but most likely a shop job.
SD TECH
Oct 01, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi ws-55809 goes to white foggy screen occasionally
It will cost between 30.00 - 70.00 dollars to do it yourself depending on if you buy the parts seperate or as kit.
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 25, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Black and white picture
you have the cables hooked up the wrong way
Nov 09, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809
can you post a picture of what the picture looks like? If so I should be able to diagnose the problem
Apr 30, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Blue Screen/Waviness
sounds like convergance ic's mits is also know for bad caps
1000uf @ 16v check for bulges on top of the cap
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 05, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809
1)Check for coolant leak from CRT onto signal board
2)Possible convergence problem ..................T.
Oct 26, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
316 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
