Question about RCA P52940 52" Rear Projection Television
Rca 52 inch rear projection
My sound turns off on every channel except ch. 3. if i unplug for 5 min or so and plug it back in the sound works fine ..help plz...ty
Tv turns on then off
Posted on Feb 17, 2010
    Sergeant:
  • 308 Answers
This is a problem common with some RCA/GE TV's. The fix in the past was to install a capacitor between ground and pin 15 of the microprocessor which keeps a data signal riding on the video stream from muting the sound on most stations. By installing this capacitor, you would be disabling the closed caption feature so that feature would no longer work. An authorized RCA TV repair shop may be able to give you more information.
Posted on Apr 12, 2007
SOURCE:
50 or 52 inch RCA HDTV about 10 yrs old the power light blinks 9 times then 5 times then 9 times and won't go off unless unplugged, won't turn back on
i have seen this before and sorryy to say if unplugging for 5 or more min and that dose not fix it may need to be replaced not many people fix them these days but not impossable
Aug 25, 2015 | RCA HD52W56 52" Rear Projection HDTV
52" RCA Rear Projection TV- When turn on the screen seems to be split in 3 horizontal bars all scrolling. The color doesn't seem to be there either, but hard to tell. When I put up the menu
Good Morning
if you remove the signal either being HDMI or Av Cables from the source are the bars still there ? if they are id suspect a signal board problem . if there not try unplugging your signal source for 5 min's and then do a restart if problem still exists then contact your service provider for further assistance .
Oct 15, 2014 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA d52w25 52 inch blinks 3 times off...turns on...off
Most likely Capacitors cp150, CP120 and CP114 need replacement. You can get the repair kit at www.tvrepairworld.com under the RCA reapair kits catagory bottom of the page. The kit contains the capacitors and detailed instructions
Sep 09, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sound
First check to see if your tv is on a fixed mode also ( if you have this feature) make sure your speakers are turned on , you should be able to access these in your audio settings, on the tv. If that does not work try unplugging your tv wait 5 min. and plug it back in. All else fails buy a receiver and hook up your audio that way.
Jul 05, 2009 | RCA P52960 52" Rear Projection Television
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
RCA P52921yx2 WIll not power on only clicks
try to check the h-transistor and test it with 360tr multi tester and if not deffective try to also check the r2m zener diode
Nov 29, 2007 | RCA P52921 52" Rear Projection Television
Television sound
First unplug the unit and leave it for about 5 min.,then plug the unit in and see if you have sound,if not check to see if the speakers are on in menu,if they are on,sounds like the outputs or maybe the e prom.
Nov 21, 2007 | RCA P52930BL 52" Rear Projection...
RCA 52 inch TV (turn on problems and channels rolling) HELP!
Your set uses the 195 series chasis. The only thing I can think of which would make the channels scroll by themselves is a contaminated PC board and pushbuttons behind the buttons on the front of the set. This is usually the case when spray cleaner or some other fluid is sprayed or spilled on the screen, and it drips down onto that board. To prove this, remove the back cover and on the top of the main chassis, where the top of the picture tubes are, is a small PC board with the remote reciever and a couple of jacks. The smaller jack is for the speakers and the larger jack is for the front panel PC board. Unplug the larger connector which goes up to the front PC board and then turn the set on with the remote. If the set works normally, the front PC board will have to be removed and cleaned or repaired (or just leave the jack unplugged and work the TV from the remote only). If you do not have any experience working inside projection sets then allow a qualified tech to handle it for you.
Aug 30, 2007 | RCA P52926 52" Rear Projection Television
RCA P52940 52" Rear Projection Television Logo
549 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
