Question about Rowenta Commercial Garment Steamer - White
IS8100 Commercial Steamer is leaking water
When used the steamer leaks enough water to where I have to keep a pan under the unit to trap the water. The leak appears to be between the back of the water tank and the main unit. How do I solve this problem? Is the tank defective? The unit was purchased in February of 2008.
  • pamaurelli Apr 19, 2009
    I have the same problem. The tank lid had a gasket that does not work. They have a new tank and lid you can purchase however I am now dealing with them because it does not fit my machine even though they say it is a replacement for the old tank. I had to send a pictures to the replacement parts store and am still waiting a response will follow up with them on Monday 4/20. The store is smallappliance.com this is who Rowenta referred me to.
  • Anonymous May 08, 2009
    IS 8100 Garment Steamer leaking water...driving me crazy. Called for new tank at Smallappliance.com and he said replacement one would work but just looking at it I know it is not the same water tank? Wants me to send a picture. I think they were all defective when origianlly bought...now what????
Try "cleaning it" with vinegar. It could be clogged with calcium carbonate. Replace the water with a potent solution of white vinegar and water and operate the unit until the vinegar solution is used up. I use 100% of the supermarket white vinegar and avoid breathing in the "steam." Repeat the procedure once or twice with plain water. If this works, let me know.
Posted on Dec 30, 2008
My rowenta steamer is not producing steam but tubing getting hot when I turn on steamer. Suggestions?
see this causes and fix it. God bless you
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle.
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Feb 03, 2013 | Rowenta Commercial Garment Steamer - White
Rowenta Commercial Garment Steamer - Silver Mod. IS8100
So is difficult to say. The best way is to take the electrical iron and see with the person, What can they do . Otherwise you must investigate in Internet if there are some catalogue or parts available with photo and take it , and get it as sample for the repair shop.
God bless you
Jan 25, 2013 | Irons
I have the vertical commercial steamer model IS 8100. Machine lights up, no steam. The cord doesn't even get hot. I've tried to demineralize it by allowing vinegar to sit in the well of the base. Thanks...
My unit did the same thing. There is a temperature fuse attached to the heating chamber. If the unit overheats it will blow this fuse. It is not re-setable and must be replaced. Radio Shack carries these items.
Check your chamber for crude. Mine was pretty bad and I ended up filling it up with white vinegar over night. If you can get it to work, boil a solution of 1/4 white vinegar and DISTILLED water. Let it run through a whole tank of it and then run it with just DISTILLED water until you don't smell vinegar anymore. Do this every few months with heavy use.
Jan 10, 2011 | Rowenta IS8100 Iron
A PIECE BROKE OFF OFF THE MAIN BODY WERE THE
Try filling the hole with some fibreglass resin ( the stuff that motor car shops sel for fixing car bodies). This would provide a quick setting, hard filler.
Dec 14, 2009 | Rowenta Commercial Garment Steamer - White
Need replacement water tank due to a crack that leaks for the Rowenta 8050 steamer
krups bought out Rowenta. contact them at http://www.krupsusa.com/ to see if they have the parts or know where to get them
please take a moment to rate this solution. thanks
robert
Nov 23, 2009 | Rowenta Commercial Garment Steamer - White
Conair steamer leaks water and wets my clothes.
When I use mine I hang the hand held part from my closet door, while I am waiting for it to heat up. When the hose gets too much condensation, from the steam, it leaks out... This will also happen if you try to use in the motion of an iron. The hand held part needs to be at a vertical position at all time to prevent leaking.
Jan 24, 2009 | Conair Compact Garment Steamer Iron
Rowenta commercial steamer
got this off the manual for the IS 7800
CLEANING
Remove water container and clean the main unit with a damp
cloth. To maintain maximum performance, your steamer must
be descaled occasionally. The descaling intervals will depend
on the water quality and the frequency of use. The unit should
be descaled at least once a year or every 100 hours of use.
For descaling proceed as follows:
1. Unplug the unit and remove water container from main unit
by releasing container lock and pulling up.
2. Fill it with fresh water and shake vigorously to remove any
scale. Pour out the water and repeat if necessary.
3. Purchase a quality decalcifier agent and follow the instructions
of the manufacturer for the proper ratio of the mixture
to water and use.
4. After filling the water container turn it up and down to
descale.
5. Attach reservoir to unit, plug in and switch on.
6. Let the appliance run until the water container is almost
empty and do not steam any clothing with this mixture.
7. Unplug and detach the water container. Rinse it with fresh
water.
8. Fill water container with fresh water and repeat steps 5 and 6.
Note: If after descaling you believe that there is still buildup in
the boiler, repeat steps 1-8.
Jul 22, 2008 | Rowenta Commercial Garment Steamer - White
Rowenta Commercial Garment Steamer - White Logo
1,153 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
