Question about ViewSonic VE710b 17" Flat Panel LCD Monitor
Ctx lcd monitor turns off after 1 second
Monitor is disconnected from cpu, same problem . . .
    Genius:
  • 2,120 Answers
Your backlight fluorescent bulb is burned out.
Posted on Dec 24, 2008
How to fix No Display on LCD Display Panel at all?
Good day, For you lcd issue you may try doing these steps:
1. Check if the the power cable of properly plugged in.
2. Check the cable connecting your monitor to the tower or CPU
3. If there's no power at all you can try to change the power cord and also the monitor to cpu cable.
4. You can also plug it on another outlet to make sure that its not your power outlet that's causing this problem
If everything above doesnt work for you, you might consider having it check by a technician or just purchase a new one. Hope this information help you a bit. Have a great day.
May 24, 2011 | CTX Panoview 510 (White) 15.1 in. Flat...
I have a ctx moniter says undectected mode
CTX 15"1024x768 TFT LCD-Black Monitor · i have a ctx moniter says ... Answer. i have a ctx moniter and wen i plugnitin to pc tower itsays undeceted mode watdoes this mean. Close Close. ASUS Eee PC 1000H
Dec 03, 2009 | CTX 15"1024x768 TFT LCD-Black Monitor
TURN IT OFF ATER 1 SECOND from turning on
Hello sir/maam, good day, the problem is caused by the power supply board, this board is replaceable, but you may need to disassemble the unit. But first make sure that the CPU is not the problem? to confirm, you should here the single beep (good) or the keyboard numlock led is on and off as you press the numlock key.
Nov 11, 2009 | CTX M Series M730V (Gray, Silver) 17" LCD...
Ctx monitor
try lowering the screen resolution
Oct 19, 2009 | CTX S762A 17" LCD Monitor
Looking for AC power Adopter for CTX LCD monitor
Check it on Radio Shack maybe they got something
Jun 03, 2009 | CTX SV900MD 19" LCD Monitor
Ctx pv 720 lcd monitor backlight drops post plus 30 seconds!
Hi...there,
The problems on the backlight inverter power supply. Open it up and check all the capacitors, it look like a tiny battery cap on the side had writing on it. (Example 1000uf 16v ) if you are lucky you can spot it right away...with a bulged on top of each caps. If not, just replaced all of the caps... Good luck!
Dec 06, 2008 | CTX PV 720 17" LCD Monitor
My hp starts and then shuts its self down after a few seconds
Try disconnecting all the USB and peripheral devices that you have recently attached and restart the machine.
If that doesn't work it's either a virus issue or a cpu overheating issue.
Boot in safe mode and try running an antivitus first. If it detect a virus, remove it.
If that doesn't work. Try to monitor the CPU temperature in the BIOS or by downloading this program
http://www.almico.com/speedfan.php
If you see the temperature over 60-70 that's too high and that would be the reason behind your problem. In this case you will need to fix your cpu fan or buy a new one.
Oct 27, 2008 | CTX S762A 17" LCD Monitor
CTX lcd monitor model s700b is come on 1 second and shut off
this purely the problem with operating system just reinstall windows... u will get rid of it...
ur monitor is in good condition no need to worry about that...
Jan 29, 2008 | Computers & Internet
Monitor turns off
sir\maam i think there something wrong with the power supply of your laptop,,tv kindly check the power supply section,,,hope to help you thnkzz??
Jan 29, 2008 | CTX S762A 17" LCD Monitor
ViewSonic VE710b 17" Flat Panel LCD Monitor Logo
157 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
