Question about Frigidaire GLER331A Electric Dryer
Screeching sound when dryer is running
We do not see how to get at the drum to look at the bearing. The back does not appear to come off. Any ideas on how to look inside. Elecrolux GLER331A
This is a bit of a job. The dryer needs to be in the open. The top swings up by pushing a flat blade screwdriver in the seam between the top and the front panels about two inches from the sides to release the latches. With the top up and supported, Remove the two screws that hold the front panel to the side panels. These are inside the cabinet and near the top of the front panel. Disconnect the door switch wiring and remove the front panel. This is when you find all that lent that the filter missed. Remove the small louvered panel on the back near the bottom of the left side and reach inside and disengage the belt from the motor and idler pulleys. Remove the three phillips screws arraigned in a trangle on the back of the drum near the hub inside the dryer. Remove the small plastic spacer? located in the center of the cabinet where the top and front panels come together. I never could figure out what that thing was for. Now the drum will come out the front of the dryer. Go slow as to not mash or cut a finger. The rear bearing is now accessible for lubrication or replacement. It's not that hard, it just takes a while. Good luck.
Posted on Dec 28, 2008
My bravos dryer sounds like metal on metal screeching while it runs.
Most likely, the drum suspension has failed. It's probably a worn rear drum bearing, drum roller, or drum slide.
Feb 26, 2017 | Dryers
I have a stacked Frigidaire FEZ831CA washer/dryer combo and when running the dryer it makes a very high pitched (AND LOUD) screeching sound. Any ideas as to what might be the problem? Thanks, Sean
screeching sound
Sean, Bad felt gasket body to drum, if belt drive on dryer, it could be worn and slipping, making a screech, or if not the belt, the drum may have a worn bearing on its hub allowing it to run crooked and rub where it should not.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Disassembling reassembling stacked clothes dryer
Frigidaire Stacked Laundry with Noisy Dryer
How to Replace an Electric Laundry Center Dryer Drive Belt Kenmore...
Mar 29, 2016 | Frigidaire Washing Machines
I have a frigidaire stackable washer/dryer model number FEx831cs0. The washer is working just find but the dryer for a few weeks has been making the worst screeching sounding in the world. I am not sure if...
A loose belt often makes a squeak that pulsates with the clothes hitting the paddles in the drum. It's probably the upper drum glide or rear bearing. If it's a constant screech coming from the front, it's probably the glide. If the noise seems to be in the back, suspect the bearing. You might check for a sock or something small that is stuck somewhere between the drum and the dryer.
Glide: http://www.repairclinic.com/PartDetail/Drum-Slide-or-Glide/916658?modelNumber=FEX831CS0
Bearing kit: http://www.repairclinic.com/PartDetail/Drum-Bearing-Kit/1851?modelNumber=FEX831CS0
Neither are very difficult to repair.
Other parts for your machine:
http://www.repairclinic.com/Shop-For-Parts?s=t-%20FEX831CS%20-%3d%3d
Good luck.
Feb 28, 2011 | Frigidaire FEX831CS Top Load Stacked...
Drum is making some really nasty banging then screaching sounds when entering high spin - any ideas??
sounds like main drum bearings not common but if the bearings are worn you get the banging noise and as it slackens the drive belt you get screeching noise as the belt slips.
Nov 21, 2010 | AEG Lavamat 16810 Front Load Washer/Dryer
My Frigidaire is Screeching. How can I make it stop? I have tried to grease the idler assemble and that is it.
If the dryer is constantly screeching it could either be the belt (if it's stretched) which would be slipping from not grabbing the drum tightly or the drum bearings could be going bad. I would start with the replacing the belt as you do not need to pull the drum out for that, for the bearings you do because they are screwed into the back of the drum.
May 01, 2010 | Frigidaire FDE546RE Dryer
My dryer makes a loud screeching noise coming from the fan at the end of the motor, any ideas
the belt runs off the drum with a tensioner attached. It sounds like the bearing in the pulley is locked up causing the noise
Feb 04, 2010 | Dryers
Screeching noise
rear drum bearing needs to be replaced
Sep 25, 2009 | Maytag Dryers
Screeching noise when running the dryer.
Most likely source is the idler pulley. Secondly, is the drum support roller closest to the motor. If the screech is a slower frequency it's likely the roller because the support roller travels at slower speed than idler pulley. Both are replaced by raising top and removing front. Caution: Pull plug before starting and draw diagram of how the belt travels around the idler roller. You will need it to get this back on properly.
Aug 18, 2009 | Kenmore Dryers
LG DLE7177WM began making loud RuMbLiNg sound.
I have the same problem; pulled it apart and discovered the drum was cracked at the seam where it was welded. the noise occurs as it passes over the wheels the drum rests on. called LG's Cusomer Diservice and nobody was interested. found the same problems by others while searching myself so its clearly a manufacturing problem.
Jan 24, 2009 | LG DLE7177 Dryer
ED55 dryer making screeching noises
sounds like the rear tub bearing has worn out that would explain the noise and if it got too bad the bearing can break causing the drum to stick and not be able to turn
Nov 26, 2007 | Fisher and Paykel DG05 Gas Dryer
Frigidaire GLER331A Electric Dryer Logo
650 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
