Question about DFI LANParty UT RDX200 CF-DR Motherboard
Motherboard won't boot up
When I boot up my computer, four red led lights come on above the "debug" located in the right hand corner of the motherboard. The computer has power, but won't boot up.
  • Anonymous Feb 09, 2009
    i have same problem right now. but i saw that one 5V transistor have burned. i think the position is Q50, and i saw mark there A203, but i need full name to buy same new one and soldering it. anyone have qlue what the fullname of this component.
  • Tyler Wallace May 11, 2010
    I will need the computer name/model number, im guessing a Dell if so whats the model #?
    Scholar:
  • 56 Answers
Hey there,
This causes if you havnt connected the power cable coming from th power button to proper jack or pin.
Check out the pin in which ur power button cable is inserted.
Does your system boot when u press the restart or shut down icon from ur windows (OS). If it is not letting ur system to boot then you've been attacked with the Worm viruses. These viruses dont let ur system to boot because they keep their process running untill ur power is off.
Gimme ur acknowladge by rating me.
Thanx.
Romy
Posted on Dec 24, 2008
    Problem Solver:
  • 5 Answers
Also check the board for blown capacitors. I have brought several machines back to life be replacing capacitors that had popped. The attached image shows what you should look for.motherboard won't boot up - 11_23_2012_3_00_31_pm.jpg
Posted on Nov 23, 2012
New computer build will not POST
Check your hard drive and weather or not you have the drive set to IDE or ACH
Feb 09, 2014 | Micro-Star MSI A55M-P33 Desktop...
Debug LED code AA - computer errors and tries to restore every boot and never completes and shutsdoiwn
What is the make and model of the motherboard? The LED code means nothing without this information.
Aug 04, 2013 | Computers & Internet
No debug LED show on my flaming blade gti
If your PSU give wrong voltage it produce same problem with 2 solution:
1-test your PSU
put a wire between green and black and voltage must be:
yellow 12V, red/purple/gray 5V, orange 3.3V.
If your PSU give under voltage (more than -10%):Buy a new one and test your motherboard(mb) with it (in this case there aren't a lot of chance that your mb and/or your CPU are dead)
If your PSU give good voltage:(-10% / +5%):There are a lot of chance that is you mb or CPU
If your PSU give over voltage:Buy a new one and test your motherboard with it (in this case there are a lot of chance that your mb or/and your CPU are dead)
Nov 19, 2012 | Foxconn Computers & Internet
Need a wiring diagram for a rs780m03g1
http://www.ebay.com/itm/FOXCONN-RS780M03G1-8EKRS2HM0D-DDR2-HDMI-PCI-MOTHERBOARD-/250896178535
1) http://support.gateway.com/s/MOTHERBD/Shared/4006272R/4006272Rnv.shtml
2) Product Views;
http://support.gateway.com/s/MOTHERBD/Shared/4006272R/4006272Rtc.shtml
B - Processor Core Power Connector;
is the connector on the motherboard for the 4-pin ATX +12 Volt power cable.
Located close the motherboard top edge, left side. Yellowish 4-socket hole square connector.
General example of connector, and power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
2) D - CPU Fan Connector,
The Processor fan connector is white in color, 3-pin, and above the processor socket.
3) F - Main Power Connector,
The 24-pin ATX main power cable connector on the motherboard, is to the Right of the Ram Memory slots
4) N - Front Audio Connector, (Front Panel audio ports)
Red in color, 9-pin header, and is located below the white No.2 PCI slot, at the bottom of the motherboard.
5) P - System Fan Connector, (System Fan = Computer case fan)
White in color, 3-pin header, located below the No.2 PCI slot, at the bottom of the motherboard.
6) Q - IEEE 1394 Connector,
For the front panel Firewire (1394) ports.
Black in color, 9-pin header, located at the bottom right corner, of the white No.2 PCI slot
7) R - USB Connectors, ( Front Panel USB ports )
F_USB 1 through F_USB4.
Located at the bottom of the motherboard, and these four separate headers support TWO USB ports each. Yellow in color.
8) S - Front Panel Connector,
located at Bottom/Right corner of motherboard.
Pin 9 is N/C also.
Not Connected. Used for +5 Volt power for the factory.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 27, 2012 | Gateway E-4300 PC Desktop
I have 3 wires on my pc and i dont know where to connect them on my motherbaord - the wires have writen on them "HDD LED" "PWR LED" "PWR S/W" can any1 help me?
Hi Dan,
The wires are from the front panel. HDD LED which causes an led (usually red) light to turn on when the Hard Drive is active. The PWR LED turns on an LED light (usually green) when you turn on your computer. The PWR S/W turns on your computer when you press the on button of your computer. The front panel connector riser is usually located on the bottom right of your computer. They fit on little pins. Unfortunately there is no standard, so connections vary. Sometimes the pins are labeled on the motherboard. . Check your manual. For more info do a google search for "Motherboard front panel connectors". Hank
Mar 12, 2010 | Intel Computers & Internet
My motherboard have four leds in red light, d0 dled2,dled3 and don`t start up
Hi ntamayo,
Here is the description of what the four leds indicate:
d9c5d26.gifSystem Power ON-The D-LED will hang here if the processor is damaged or not installed properly.
1d08ad7.gifEarly Chipset Initialization
14ff182.gifMemory Detection Test
- Testing onboard memory size. The D-LED will hang if the memory module is damaged or not installed properly
1719312.gifDecompressing BIOS image to RAM for fast booting
1cab634.gifInitializing Keyboard Controller
3b994fe.gifTesting VGA BIOS
- This will start writing VGA sign-on message to the screen
2b36bf2.gifProcessor Initialization
- This will show information regarding the processor (like brand name, system bus, etc...)
f53faac.gifTesting RTC (Real Time Clock)
9ec1db5.gifInitializing Video Interface
- This will start detecting CPU clock, checking type of video onboard. Then, detect and initialize the video adapter
4f7c881.gifBIOS Sign On
- This will start showing information about logo, processor brand name, etc
6a25253.gifTesting Base and Extended Memory
- Testing base memory from 240K to 640K and extended memory above 1MB using various patterns
1bef2e1.gifAssign Resources to all ISA
e664b69.gifInitializing Hard Drive Controller
- This will initialize IDE drive and controller
c3b6c58.gifInitializing Floppy Drive Controller
- This will initializing Floppy Drive and controller
3afd28f.gifBoot Attempt
- This will set low stack and boot via INT 19h
24b95b0.gifOperating System Booting
When your motherboard is stuck on any of these signals, that's a clue that something is wrong with that particular device on the board. Replace it and try again.
Good Luck
And don't forget to leave a rating,
Thanks
Mark
Sep 16, 2009 | MSI MB INTEL E7520|E7520 Master-S2M RTL...
Gateway / eMachines 4006149R, D102GGC2 Motherboard
Their should be a 9 pin header at the bottom right corner of the board. Between the sata headers and the corner. There are two rows of pins in the header, one row has 5 and the other 4. The row with 4 pins has the power switch and the power led pins : : : : . They should be color coded red for the switch and green for the power led. From left to right the first pin is for the led (+) lead, the second pin is for the led(-) lead, the third pin and fourth pin are for the power switch. Also there is a 2 pin header above the 9 pin header that is an alternate power led header, the left pin is (+) and the right is (-). I hope this helps you.
Aug 26, 2009 | Intel Computers & Internet
No start up, no bios boot , only "no signal "on screen
Is the CPU fan spinning? if not, check the coolant between the CPU and the cooler (ensure it's not dried up, and replace it if it has or if there is very little there).
May 31, 2008 | AOpen AX4B-533 Motherboard
Powers on, but no video
try new/different video card
Dec 13, 2007 | SuperMicro X6DH8-G2 Dual...
Red and blue power wires
you can see this markings in the mother board if you have manual you can also this
Dec 01, 2007 | Mercury P4VM800M7 Motherboard
DFI LANParty UT RDX200 CF-DR Motherboard Logo
416 people viewed this question
Top DFI Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Steve Frost
Steve Frost
Are you a DFI Computer and Internet Expert? Answer questions, earn points and help others
