Question about Frigidaire ATF6000ES Front Load Washer
How do I run a diagnostic on a Fridgidaire
How do I run a diagnostic on a Frigidaire Model LTF2940es3
  • billyboy100 Mar 29, 2009
    Error code 47 on Fridgidaire Front Load Washer does door switch need to be replaced? Washer just won't high speed spin.
Diagnostic Test: The diagnostic test is performed by using the Program Knob. To START THE TEST: • On non-digital display models, turn the Program Knob to start position, Drain/Spin. • On digital display models, turn the Program Knob to start position, Touch Up. (NOTE: If the model has a timer dial that can be rotated 360°, turn the Program Knob to start position, Drain/Spin. • Press Pause Cancel to turn off LEDs. • Within 5 seconds, press and hold the Option and Pause Cancel buttons until LEDs start sequentially chasing, then release buttons. 1. All the LEDs will sequentially light. Pressing a button below a light cluster will light all the LEDs in that cluster at one time to confirm functionality. 2. Turn the program knob (1) click clockwise from the start position. The hot water solenoid will activate and hot water should enter through the detergent compartment. 3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water should enter through the bleach compartment. 4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and cold water should enter through the softener compartment. 5. Turn the program knob (4) clicks from the start position. The door lock solenoid will activate. 6. Turn the program knob (5) clicks from the start position. The door lock solenoid will deactivate and the loading door can be opened. 7. Turn the program knob (6) clicks from the start position. The washer will fill and tumble. 8. Turn the program knob (7) clicks from the start position. The washer will fill and spin (leakage test). 9. Turn the program knob (8) clicks from the start position. The drain pump and door lock solenoid will activate and the washer will operate in high spin. SAFETY WARNING: If power is removed during this test, the door can be opened. To prevent injury, DO NOT put your hands inside when the tub is rotating. 10. Turn the program knob (9) clicks from the start position. The control will signal the last error code. Exiting Diagnostic Mode There are two options for exiting the Diagnostic Test mode and returning the washer to normal operation: a) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord OR b) Turn the program knob clockwise 2 or 3 clicks after the Start Position. Press Options and Pause Cancel buttons together for a few seconds until wash cycle LEDs appear. If a situation arises where you cannot exit the Diagnostic mode as described above and the bank of 5 LED’s on the right end remain ON regardless of Program Knob position, a combination of pushed buttons may have caused the control to enter a special factory test mode. Disconnect power to reset the control to return washer to normal operation is this occurs. To clear latest stored error code: Place the control into Diagnostic test Mode. • Turn the program knob clockwise 9 clicks from the Start Position. The control will signal the last error code. • Press and hold the Options and Pause Cancel buttons for 3 seconds. The code will be cleared. • Exit Diagnostic Mode to return th e w a s h e r t o n o r m a l o p e r a t i o n .
Posted on Dec 25, 2008
How to reset a Frigidaire front load washer Model LTF2940ES3
Empty the machine. Turn off. Close door. Try pushing simultaneously 2 buttons at a time while powering up. This would reset the machine.
Jan 12, 2014 | Washing Machines
My fridgidaire model #LTF2940ES3 is giving me an error code E47 what is this
Very likely the problem is a bad door lock. It is very common problem with Frigidaire front loaders. You have to measure the resistance of the wax motor in the door lock assembly (the orange piece on the right side of the picture). I don't know why Frigidaire call it PTC. Very confusing. The normal reading should very close to 1500 Ohms. Otherwise verify all wires from the door lock assembly to the control board and, if everything is fine, replace the control board.
showpartimage.aspx?forumimg=ap4455026
If the door switch is bad, replace with this part.
If the control board is bad, replace with this part.
Oct 15, 2012 | Frigidaire ATF6000ES Front Load Washer
Change control board on Frigidaire washer LTF2940ES3
This is typically not a DIY type of job since the entire front, top, panel where the settings are needs to be taken apart to reach the control board and wiring harnesses.
Jul 19, 2012 | Frigidaire ATF6000ES Front Load Washer
My Fridgidaire freezer is flashing E9 , What does
http://www.frigidaire.com/manuals
go to this web site. It has lots of manuals. I found several for your unit. just enter you model number and it shows up with several choices.
Hope this is what you are looking for.
May 29, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
How do i fix an e68 fridgidaire problem on an affinity model
A key is stuck as indicated by the error code E68; enter the service diagnostic mode and perform the key test to determine which key is stuck. Unstuck the key then perform the key test again. The electronic control board (part number 134557201) needs to be replaced if the error code continues to appear. Click here for the diagnostic and key test procedure.
Apr 28, 2010 | Frigidaire AEQ6000ES Electric Dryer
My Frigidaire Model fails to spin after wash
my washer had same problems, turned out to be door lock switch. around $75.00. Washer 2 years old. Questioning quality also.
Dec 17, 2009 | Frigidaire ATF6000ES Front Load Washer
LTF2940ES3--Washer drains, but will not do a final spin.
Hi. You have done a great job diagnosing your unit. This unit is designed to not allow a full scaled spin out, if there are issues with the on-board door lock mechanism. This is standard safety equipment for most units. Once this damaged door lock mechanism is replaced, the washer will operate properly. The full scaled spin out will return.
Nov 29, 2009 | Frigidaire Washing Machines
Frigidaire Front Loader LTF2940ES3 does not fill.
I had to call a service man and he said that it was the Speed Motor that had to be replaced.
Jun 22, 2009 | Frigidaire Washing Machines
Frigidaire ATF6000ES Front Load Washer Logo
4,498 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
