Question about Sanyo DS27820 27" TV
New dp 19648 sanyo hdtv no signal detected
Just got sanyo hdtv. no cables included. I do not have antenna or cable service. Just wanted to use my usual four channels. Plugged in, no picture. Used menu to search for signals, analog, one channel detected, however, just static. Do I have to buy an antenna? Do not have a roof antenna and do not want one.
    New Friend:
There's antenna booster's you can buy or build yourself one.
Posted on Oct 24, 2014
You gotta have a way to get signal to the tv . If you don't want a outside antenna use rabbit ears .After you hook them up hide them behind the tv then do a channel scan. If you don't pick up all the stations set them on top and scan again or get satillite or cable hd boxes.
Posted on Dec 29, 2008
Can i use a digital converter on my Sanyo DP 42849
Sounds like you need a stronger antenna or to adjust your antenna. It's pointless to put a digital converter box on your tv as it already has the capabilities of reading digits signals built in.
Jul 25, 2016 | Sanyo DP42849 42 in. HDTV
Why is my TV saying no signal detected when it is in HDTV mode?
You either don't have an HDMI cable connected or it is not connected properly.
Feb 08, 2016 | Televison & Video
Where is the antenne hookup
How to Hook Up a TV Antenna: 7 Steps (with Pictures)
www.wikihow.com > ... > TV and Home Audio > Television
wikiHowHow to Hook Up a TV Antenna. Two Parts:Picking an AntennaConnecting the AntennaQuestions and Answers. Want to ditch your cable, but still like to watch the ...
How to Connect an Over the Air TV Antenna to a Flat Screen ...
? 6:37
https://www.youtube.com/watch?v=9Pq8e57O4zk
Sep 19, 2012 - Uploaded by All About Home Electronics.com
How to watch digital channels without cable TV or satellite for FREE? ... How To BUILD The BEST HDTV ...
How to Connect an Antenna or Cable to Your HDTV - Video ...
www.dummies.com/.../how-to-connect-an-antenna-or-cable-to-your-hdt...
The first step to connect an antenna, is to find the input port on your HDTV. Look for the VHF/UHF input. It's usually on the side or in the back of your HDTV.
Jan 24, 2016 | Televison & Video
Fix tv picture
If the TV is receiving its signal from a cable TV box or DVR then you need to find out if the problem is in the TV or the cable box/DVR. Connect a different source to your TV such as a DVD or Blu-ray player and play a DVD movie. If the problem occurs again it suggests the TV needs repair. If the TV works OK when playing a DVD movie then that suggests that your cable box/DVR needs repair or replacement.
If your TV is receiving its signal directly from an antenna or cable outlet on the wall then you should try replacing the cable wire from the wall to the TV with a new wire. If that doesn't help then your TV probably needs repair or replacement.
Dec 29, 2015 | Sanyo Televison & Video
Can't get the antenna to pick up the local channels
Hi Leslie, since you didn't disclose the brand or model name and number to the antenna you are using, I'll do my best to help you with your dilemma.
1.) double check your physical (wire) input connections
2.) make sure you have selected the proper input from you t.v.'s menu screen
HDTV aerial (outdoor mast) antennas are your best investment to receive free air wave digital transmissions...as opposed to the smaller indoor antennas...and the clarity is phenomenal; it cannot be matched by cable or satellite signals that compresses and decompresses the audio and video signal.
Why? Because, digital t.v signals are line-of-sight signals; meaning they need an unobstructed path between the sending source (t.v. station transmitter) tower and the receiving (home) antenna.
Hills, trees, walls, buildings, and any other obstruction- bends, deflects and weakens the signal as it is...placing an HDTV antenna in an attic weakens the signal by at least a 1/2...
So, if you are using an Indoor omnidirectional antenna at the set; the signal will be even weaker...it won't be good enough to pick up the digital signal that requires an accurate line-of-sight reception (just like satellite dishes.)
As a side note: I had an outdoor HDTV mast installed professionally; including signal filter and signal booster- [they'll know the proper type antenna to use for your area (see http://transition.fcc.gov/mb/engineering/dtvmaps/ for more details.)] And it was so worth it; whenever we have storms that knocks out cable power, we rely on the air-wave stations...and their sub-stations, lots of choices; and it's phenomenally clear...much clearer than cable or satellite signals can ever be.
As a matter-of-fact, we watch our local news and entertainment stations normally via our antenna rather than our cable service provider's system for that very reason of clarity and detail. Too bad we couldn't get the quality "pay for" stations that way, too - we'd drop our cable service and save a lot of money! :)
Mar 10, 2015 | Televison & Video
Sanyo gxba
u cant.......the antenna gets only over the air signals while the cable are actually wire transmitted signals meaning if its cable transmission u want u will have to consult the broadcast provider to hook u up with there particular signal cable to your tv thats what is called cable tv a reason ya antenna cant receive cable signals is compartibility
Jul 19, 2013 | Televison & Video
Cable in my area has switched to digital cable. I own a Hitachi HDTV about four years old. When I scan my channels it will only scan analog channels...the digital channels are an option but I don't...
Unfortunately, you need a set-top box. The Hitachi 65F59 has an ATSC (digital OTA) and NTSC (analog) tuner. It doesn't have a clear-QAM (unencrypted digital cable) tuner.
There are a few DVR set-top boxes with QAM tuners that you can buy separately. (You will need to make sure a given model is compatible with your service. FIOS uses a different option on the Cable Card than other providers.) Alternatively, you can get a cable box from your company.
Retrevo has the manual for this Hitachi TV here: http://www.retrevo.com/support/Hitachi-65F59-TVs-manual/id/371ci977/t/2/ . You will need to enter a code to access the PDF.
If you want OTA HD, you will need to determine the correct antenna for your area and the direction to the transmitters. (External antennas pick up more stations. In some areas amplification may be needed to get a good signal.) See antennaweb.org or tvfool.com for searches on the appropriate antenna to get a signal and where to point the antenna. Antennaweb assumes an external antenna but is very conservative in the received channel list. You would need to set the TV signal input to Air and rescan for channels if you choose to go with the OTA signal.
I wish that I had better news for you.
Sep 06, 2011 | Hitachi 65F59 65" HDTV
I know this tv has digital capabilities, so i don't need to get the digital box, what do i need to watch my local channels? i have directv but does not include local channels (ie. fox, abc, nbc).
Hello
To tune the local channels do the following.
1 Press the MENU key on the remote control to
display the Main menu.
2 Use the CURSOR "UP" or "Down"
keys to highlight
Manual Channel Search. Press ENTER.
3 Use the CURSOR "Up" or "Down"
keys to select Cable,
Air (Antenna), or Digital Add-On.
After the search is complete, the HDTV will exit the
menu system and return to normal TV viewing.
IMPORTANT FACT: This HDTV maintains only one database
of digital channels. Therefore, when you search for
cable channels, the database of antenna digital channels
will be deleted. You will only be able to receive those
ClearQAM channels your cable company provides.
NOTE:"Not available" will appear on the screen
when an option is unavailable.
TUNING MODE UNAVAILABLE MENU OPTION(S)
Analog RF Digital Caption
Digital RF None (all Menu options available)
Video 1 Manual Channel Search, Channel Scan
Memory, Digital Caption
Video 2/3 and Manual Channel Search, Channel Scan
HDMI 1/2 Memory, Digital Caption, V-Guide
OK.
Feb 08, 2011 | Sanyo DP32648 32 in. LCD TV
I'm not sure how to connect my Toshiba SE-R0346 to my Sanyo TV. I plugged the cable line into the "Antenna in" port & then another cable line from "Antenna Out" to my TV. If I...
Exactly as you have done is fine all you need to do now is play the tape, (so you know what to look for when it is displayed on the screen), decide which channel you want to view the vVCR through, say 9, select the channel and set the TV to search tune on that channel. Store it when your taped programme appears.
Alternatively, have the set up as you have described and press auto install. That will retune the whole of the TV and include the VCR.
Hope this helps.
Nov 03, 2010 | Toshiba Televison & Video
Sanyo DS27820 27" TV Logo
554 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
