Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
Place a dvd in and comes up disk error, and this is also a clean disk
  • Anonymous Jan 10, 2009
    when I try to record it will not record I get erro disk not readabule
  • 141 Answers
Have you tried using a lens cleaning disk, the laser optics might be fouled up, also check your disk again for fingerprints, as that can also give out a disk error
Posted on Dec 26, 2008
My dvd player is jammed. making a funny noise. will not open sayes opening then closing then disk error. SD 3750
Disk Errors are commonly caused over time by buildup of dust and dirt on the laser lens inside the player, which may prevent the laser lens from being able to scan the digital information encoded on the DVD. You will need to purchase a cleaning DVD and follow the instructions that come with it. Hope this helps Good Luck!
Mar 10, 2011 | Toshiba SD-3750 DVD Player
FUNAI SV2000 WV10D6 DVD recorder Recording errors on new DVD +RW discs
HI,
You can try cleaning the dvd lens with a commercialy available cd/dvd cleaner.
Aug 27, 2008 | Computers & Internet
My notebook has disk read error
Its time to change your Harddrive.
Oct 29, 2010 | Computers & Internet
Hi, i HAVE A 2003 HONDA ACCORD COUPE. MY TOUCH SCREEN WAS SAYING DVD DISK ERROR SO I UNPLUGGED THE BATTERY AND NOW IT IS SAYING CHECK DISK. PLEASE HELP HOW DO I GET MY TOUCH SCREEN BACK UP.
Dvd disk error and check disk error both are same error.The name is different.In both cases the lens in the dvd unit needs to be checked.The lens is either moved from its position or getting blocked by any dust or any dirty stuff got stuck up on the thin lens glass internally.
In some cases the lens is cracked so the lens assembly needs replacement.But first try cleaning the lens with a dry tissue.You can also try blowing air from air blower first.Blow air in the unit where the disk is inserted/placed.Then check.If still same then the unit needs to be removed out to disassemble to clean the lens manually and also this will help to know if lens is cracked or faulty.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Jun 11, 2010 | Car Audio & Video
Won't play dvd's
Try buying a Laser Lens Cleaner Disc from Wal-Mart, FYE music store, or any other place that might sell DVD players. Your Laser Lens that reads the DVD'S is full of dust. Try using the laser lens cleaner disc i mentioned to clean the laser lens.
Aug 12, 2009 | Philips Magnavox DVD/VCR Dual Player
LG DVD RECORDER MODEL DV7711P
I have had this on a number of other players. First try the disks in question on another DVD player after giving them a thorough clean. If they work there then you know the problem is not with the disks.
After that (assuming the RH299 is actually working in every other respect e.g. on HDD), run a laser cleaning DVD/CD in the machine to clean the laser lens. If your machine is out of warranty then you can try opening it and cleaning the laser lens with rectified spirits/pure alcohol. Then try the disks again. If they still don't play, then it's off to a local electronics expert to see if realigning or replacing the laser and transport mechanism is economically viable, or buy a new machine.
Jun 30, 2008 | LG RH299 DVD Recorder/VCR
Mintek tv
OTREBLA36:
Alberto, your english is fine!
If your TV\DVD player is not damaged, then u have to look to your DVD disk. A smouge, a finger print, your or anybody Holding disk the wrong way prevents the light that comes out of the DVD to hit or touch the disk, causes it not to work or FREEZE.
1ST CLEAN ALL YOUR DISK with a DROP!!! of liquid soap in a small cup of water.Place a clean towel [NO LINTS on towel] in cup,squeez water out and clean GENTLY from LEFT to RIGHT, UP and DOWN.
Alberto, Its important that you DO NOT clean in a circle!!
[up and down, Left & right]!!
Question:: " all disk freeze "??
Get a different disk NEVER used in that machine.( try it!)
May 12, 2008 | Televison & Video
DVD will not load/format new disk
I have got exactly the same problem. Thought I had found some discs that worked as the first one formatted, since then all have come up with that crappy error protection message. Samsung really should sort this out.
Mar 25, 2008 | Samsung DVD-VR330 VCR and DVD Recorder
Dvd copying
This works alot of the time. Just wash the dvd and dry it.
Hope it works
Jan 12, 2008 | Computers & Internet
DVD-CP67 Multi-disc DVD Player
Normal 0 This solution is most likely being submitted way too late tohelp "dingo 1295", but perhaps it will help others who run into thesame problem.
Just this past week, in January of 2009, I ran into the very same problem witha Panasonic DVD-CP67 DVD Player. The player would no longer play disks anddisplayed the H07 error. Now, I can't answer the question about what exactlythe H07 code is suppose to mean, but I can offer one possible solution for theDVD Player's inability to play disks and the subsequent display of the H07error. What happened in my case is that a film of dirt had built up between theelectrical contacts that are suppose to form a closed circuit when the player'sdisc drawer is closed. The two metal plates that make contact rub againsteach other and the abrasion eventually both creates and traps dirt where theplates touch. Therefore the player could no longer tell that the disk drawerwas closed because the dirt blocked the fragile electrical circuit from beingclosed. Since the player could not tell the drawer was closed it would not spinup and play any inserted disks. I'd also like to note that before the playerquite playing disks and started displaying the H07 error I was watching a DVDand did see the picture quality degrade until the video finally cut out and thedisk stopped.
The Solution in this instance was to carefully remove the cover from theplayer, after removing seven screws found on the back and sides of the player's case,and to clean the metal contacts with a non-abrasive eraser. The pink eraser ona NO. 2 pencil works perfectly.
On the back of the disk drawer, on the right side is a silver metal plate andat the back of the player, mounted on the plastic frame work around the platterthat picks up any disk placed in the player, is a folded copper plate held down with ascrew. Simply unscrew the copper plate and clean it with the eraser were itnormally touches the silver plate on the drawer when the drawer is closed,being sure you do not get any eraser dust inside the DVD player. Although thecopper plate will most likely be the plate with the most dirt on it you canalso clean the silver plate without removing it. Once cleaned, you can reattachthe copper plate with its screw.
Testing... You must place the cover back on the player before it will playdisks. The cover must be fully seated, but does not necessarily have to bescrewed on. You may have noticed when cleaning it that the copper plate has anupward folded tab that presses against the player's metal cover when the coveris closed. Without the copper plate touching the player's metal case throughits cover the previously mentioned electrical circuit won't be closed and theplayer won't play disks. With the cover properly back on the player go aheadand try and play a disk. If it works then the problem is solved and you canfinish screwing the cover back on. If the player still doesn't work thensomething more serious may be wrong and I would suggest contacting a servicecenter.
I hope this helps.
Oct 18, 2007 | Panasonic DVD-CP67 Multi-disc DVD Player
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
188 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
