Question about Intel SuperMicro SUPER Motherboard - 810 (370SEAO)
My motherboard BIOS is not starting
I bought a new motherboard and a new power supply, and when i turned them on my power supply blew, but nothing happened to the motherboard. I've tried a new power supply and it worked. Now the motherboard turns on, everything that is connected to it works, but BIOS doesn't start. Normally when it does it sounds a beep, but there's nothing happening, and it doesn't even turns the screen on. Please help!!
  • Anonymous Mar 12, 2014
    no beeping and no video out from motherboard, i tried to replce all parts but nothing changed. motherboard was working before. only thing i did no try was start with cd/dvd mounted in.
    President:
  • 2,961 Answers
Look for the CLRCMOS or CLR or JBAT1 terminals. These are the cmos settings and may need to be cleared, so refer to your motherboard manual for which one you have. Although what has probably happened is that when the PSU blew it may well have shorted the cmos chip which cannot be repaired, or damaged the graphics.
Posted on Apr 12, 2007
I HAVE AN HP PAVILION P6310Y WITH 6 GIG OF DDR3 1 TERA HD NVIDIA GEFORCE 9100 INTAGRATED GRAPHICS RUNNING WINDOWS 7 MOTHER BOARD IS A PEGATRON M2N78-LA QUAD OK PROBLEM IS COMPUTER TURNS ON I GET...
Did you test the power supply with a power supply tester? You may only have partial power or very low power. I would try a power supply from another pc, Then I would check the ram in another pc if possible one stick at a time or if no other machine :
I would try removing all the ram and try one stick at a time in a different slot each time till it boots and then try a different stick the same way. You could have a bad memory stick and or slot.
I think its the power supply first, a bad stick of ram second or a bad ram slot third and the motherboard last. I would try all my parts in another pc first before a buy another motherboard
May 09, 2011 | HEWLETT-PACKARD HP Pegatron M2N78-LA ASUS...
Computer is dead. When I press the on button, nothing happens. It is plugged in. I opened it up and saw a green LED on.
It is entirely possible that your power supply has died. FYI, I just got a similar computer in the shop. Same symptoms. Turned out the power supply had failed and it also blew out the motherboard. Hope that yours is just the power supply!
Oct 06, 2010 | E-Machines T2893 PC Desktop
First Hello. Before few days,when I turn on my PC(but I was unpluged my machine from electricity) and on monitor displays CMOS wrong set date/time,cpu frequensy.I hit BIOS set up sittings and Windows xp...
Replacing the bios battery was the correct thing to do. Answer me this. The Asus motherboard should have a green LED light lit (Standby power LED), when the system is turned off. Also keep the power cord for the power supply connected at all times. Though it is possible the replacment bios battery was all ready low on voltage or dead. When you're system is turned off the power supply continues to send 5volt DC to the motherboard which maintains the bios 3volt DC.
If the green LED is not lit than there is no power charging the bios battery and every time you boot the system the bios will have lost its settings. If the green LED is red in color, than the problem is within the standby switch built into the motherboard. The standby circuit can not be repaired. Double check all power connectors from the power supply to the motherboard. If everything has a good connection and you're bios settings continue to reset you should consider replacing the motherboard. At this point you have nothing to loose. Install the latest bios update,
(Beta Version 1010.005). 2006/02/14 update.
http://www.asus.com/product.aspx?P_ID=d2Gi3Hr6quXOk51C&content=download
Mike
Jan 23, 2010 | ASUS A7V880 Motherboard
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Jun 20, 2009 | Gateway Computers & Internet
Will not turn on.
Did you try bypassing the switch?
To do so:
  1. Remove the case
  2. Follow the wire from the power switch to the motherboard
  3. Remove the wire from the 2 pins
  4. Use a screw driver and touch both pins at the same time, creating a connection
That would be the equivalent of switching the computer on, if it powers on then you know the switch is bad and just need to replace it. If it does not turn on I would be 99% sure it is the motherboard as you already swapped the power supply.
Feb 24, 2009 | E-Machines T2984 PC Desktop
Emachine W2047 No BIOS Start Screen
Replace motherboard. Processor socket burnt out, contact me for further support at compdoctor2005@btinternet.com
Dec 07, 2008 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Turn on computer fans run a second shut off i unplug cpu power supply then run
may be the connection to the smps is not right
or may be the fan blew out
Sep 06, 2008 | Gateway 310S (2900621) PC Desktop
Computer will not start
When handling motherboards and any sensitive ICs you really have to be careful and discharge any static electricity you may be carrying by touching the case before handling even with the power off. Double check all your power connections and especially the logic cables going to the harddrive. It seems to me that one of those connections is not quite right. Good luck. and God bless.
GA-K8VM800M and GV-N76G256D-RH compatibility
Perhaps your power supply is not powerful enough for the new card.
Mar 01, 2008 | Gigabyte GA-K8VM800M Motherboard
Not booting up.
can you get into the bios?
Nov 01, 2007 | Gigabyte GA-K8NF-9 (890552602964)...
Computers & Internet Logo
53 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
Computer Links
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
