Question about NEC LT70LP Projector Lamp for LT17
I have an LT170 proj. i bought on line but it has no lamp .
Want to design a led driven lamp in place of lt70 lamp house. im an electro
electrical engg. stude. i cant stop thingking that it is possible. could you help me with my project?
  • Anonymous Jan 22, 2009
    How is your project coming, if you can figure this out I would be very interested.
  • 211 Answers
You are looking at two hurdles here: 1) The lumen output of an LED light is nowhere even close to the output of a high voltage lamp in a LCD projector. 2) The color temperature of the LEDs, even if they were bright enough, will likely not match that of the lamp. This means the colors will not display correctly.
While it is a very ambitious project, I think you may be better off replacing the lamp with the proper model.
Posted on Jun 16, 2009
Where can i get a replacement lamp uv-145 2.5w
Sealand Replacement Bulb for Green Killing Machine - Petco
PetcoWater flows in direct contact with UV lamp, making it extremely efficient. The zigzag flow are designed for maximum sterilizing time. Totally self-contained replacement bulb assembly for AA 9Watt UV Sterilizer Kit. .... 2.8" L x 2.5" W x 16.5" H
UV light sources - Norland Products
The Norland collection of long-wave, ultraviolet light sources have been carefully ...LED UV Curing System emits a consistent and repeatable 2.5 W/cm squared ... lack of liquid light guides and replacement lamps brings to the forefront of UV ...
[PDF]MultiPole LED UV Curing System - Electro-Lite
Dec 10, 2015 | Honeywell Air Purifiers
Gu10 led light bulb are energy saving led Bulbs
Yes Gu10 led bulbs are energy saving led bulbs please check out the link below to know more about how much Gu10 led bulbs save energy
Sep 08, 2015 | brianydeal 3w Gu10 16 Color Rgb Led Light...
How to retrofit fluorescent tube with led tube lights
First, corrosive or solubility chemicals will destroy the protective shell of lamps.
Second, the normal ambient temperature is -20 ° C to 40 ° C, if beyond the scope of this provision, it will make adversely affect on the lifespan of the product.
Third, before installing, do not connect high-voltage power supply, if there is damage to the external of lamp, switching to the engineers with qualifications for the repair and replacement; otherwise,the bulbs can not be replaced; take care of the the discharge of fire and shock.
Replacement Procedures Information:
First, the LED tube is generally a double-ended conductive LED lamp containing professionally designed built-in power supply, which can be directly input voltage AC100-240V,it can be mounted directly on a dedicated LED T8 tube light shelves, do not need to add other drives.
Second, the LED tube can directly replace fluorescent tubes, the user can remove the original fluorescent tubes and install LED tube, then double-check the configuration of lighthouse, following the figure A, B, C three installation diagram for installation.
Third, cut off the power for the installation, repair, maintenance and demolition work to avoid accidents.
Installation Guide:
led-tube-light-installation-instruction.jpgA, connect the power cord on the lighthouse to the external power lines, no need to distinguish neutral wire and line of fire fit with LED lamps , then rotate 90 °,then connect the power to light up.
B, if there is starter on light house , take out the starter, then just repeat the A
For more information about LED tube,just visit
May 21, 2014 | Acclaim PIXEL TUBE w/ 15 RGB LEDs
I recently replaced a 915P026010 bulb for a MiTSUBISHI WD-62628 tv and it gives me a blinking yellow light in the lamp led indicating that the lamp housing is not installed properly. I have re-installled...
Make sure lamp cover is also fixed on tv cabinet after lamp installation.
If lamp cover has not been put on its place, tv wont turn On due to safety switch inside that place that gets press with lamp cover.
Jun 24, 2011 | Televison & Video
I have the model TLP WX 2200 and doesn't turn on and after a few minutes, the ON led is green, is blindnig and a bip is heard. After a while, the two of three leds ( on and lamp ) are getting red. What...
It seems lamp is dead/ broken in projector, please check lamp and replace it to fix the problem.
There is lamp cover at bottom side of projector, remove lamp cover to take out lamp.
Detailed procedure of lamp replacement is written in user manual page-45
Click Toshiba Support link to download user manual free copy, if required.
Nov 10, 2010 | Toshiba TLP-WX100U LCD MOBILE PROJ WXGA...
Wondering how to change the third brake light (one located in back window) on a 2006 hyundai sonata
High Mounted Stop Lamp Removal & Installation To Remove:
  1. Disconnect battery negative cable.
  2. Disconnect high mounted stop lamp electrical connector from inside trunk.
  3. Remove package tray.
  4. Replace bulb from package tray.
To Install:
  1. Install package tray.
  2. Connect high mounted stop lamp electrical connector from inside trunk.
  3. Connect battery negative cable.
Oct 12, 2010 | 2006 Hyundai Sonata
Getting a message that my lamp is nearing the end of it's life. I have 4 questions: 1. How long do you think I have until it will burn out. 2. Is there only 1 bulb/lamp that will need to be replaced. 3....
Hi, my same Sony KDF 50e2000 has been giving me the "proj lamp near end of life" message for approx 6 months-and we watch a lot of tv/play wii. I just ordered a repl lamp on line
Sep 01, 2010 | Sony KDF-50E2000 50" HDTV
Our Sony 50" LCD Proj TV turns on and off every 2 minutes or so.
If you have never changed the lamp that's probably the cause.If it has been replaced already suspect the lamp driver(ballast)
Aug 25, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
NEC LT170 diplays annoying line
Hi there
This is a common Mainboard failure - you'll have to get this repaired or replaced !
Must warn you that this is quite expensive
Mar 28, 2008 | NEC LT170 Multimedia Projector
I have read that OEM compatible LCD Rear Proj bulbs don't typically last as long as the OEM name brands... is this true? I have a Sony Grand WEGA KF-50WE610 I see bulbs w/complete housing units at...
The answer is yes and no. Typically OEM compatible or OEM equivalent lamps last as long as the original, but you have to remember that since it isn't the XL2100u that it's not guaranteed to work the way the OEM lamp does.
Every reseller doesn't use the same specs when they put the lamp and housing together, some of the bulbs aren't always going to be up to the specifications of the OEM, but it will fit in and work.
The best tip I can suggest is to buy a lamp from a store with good warranty, so if something does happen after you bought it, you have some recourse.
Jan 25, 2008 | Sony XL-2100U Projector Lamp for...
NEC LT70LP Projector Lamp for LT17 Logo
65 people viewed this question
Top NEC Office Equipment & Supplies Experts
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
