Question about Hitachi 61HDX98B 61" Rear Projection Television
Hitachi 61hdx98b no pic or sound
Turn on tv,light on front panel goes on,click noise. in back of tv, i see all green led's light up on the dp8x power supply. i also see a red led flashing constantly on the def power supply (that does not have a pulse code, i think?) with a beeping noise. tv has no pic or sound with either cable or a dvd player attached. i do not have the original remote but i do have a directv universal remote. since this tv has a directv installed, shouldnt that work ? i tried to program using remote code 00819. no change. help please
  • stone340 Dec 24, 2008
    ok ,i found rf27(1/2watt 22k ohm resistor) burnt out. replaced it and i got a picture and sound(switch in back for external speakers was on by mistake) using a dvd player. picture and sound goes on and off during play. the same red protect led blinks and beeps of the power supply.what is causing this? also i got the directv remote to work on this. instead of switching the nob to tv to program, i kept the nob on the directv side to program by using the code 00819.
SOURCE: chirping noise and flashing front power light.
hey techman - when you say shorted do you mean shorted in the IC or where the ic solders to the board?
Posted on Sep 26, 2006
SOURCE: TV makes chirping sound and power button blinks, T.V. does not turn on
It is the lamp, you have to change the lamp, it's in the left side of the tv, have a litter compartiment, opened and take out two screw and take out the change and change it. you have to buy a new one. go to google.com and put the model of the tv and find the price of the lamp.
Posted on Jun 25, 2008
Ecollier2012
  • 3459 Answers
SOURCE: Hitachi 50ux58b
If you have Hitachi model number 50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B and you have the following symptoms you may want to grab a repair kit from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix these models. This is a fairly common problem with the above model numbers. It is typically caused by a blown capacitor and pico fuse. Again, you can get a kit from the above address.
Here are the symptoms...
Primary Symptom: No Audio or Video. Power light will come on briefly then shut off.
Other Possible Symptoms : The green LEDs on the circuit board light up for a few seconds then turn off.
Hope this helps,
Posted on Nov 07, 2008
The GQ
  • 32 Answers
SOURCE: Hitachi 61hdx98B picture on screen look like 3-D
Has to do with your convergeance board, the ic(2) die eventually and a good tech will replace them with a cooler running set , a refurbed board is around $240. the repair kit to do it yourself is about $80.
Marc
Posted on Feb 07, 2009
SD Tech
  • 14553 Answers
SOURCE: Hitachi 51UWX20B no sound, no picture, blinking green LED
The 392-150 is a higher current device then the 110---you can use either--this is normal in the hitachi sets---I usually replace both with 150's---check the led that does not light---should indicate which voltage source is bad---if it is one of the 2 voltages for the convergence ic's(one is a positive and the other a negative voltage) then the convergence Ic's may be bad---look for any discolored resistors around the ic's---one way to tell if it is a convergence ic is to de-solder both ic's and see if the set turns on(the convergence will be out the window) but if it comes on change both and do the alignments with the Hitachi remote. By the way----the led should have a location number printed on the top of the circuit board.
Posted on Aug 07, 2009
TV won't turn on, red light flashes on TV and hear a clicking sound in back of unit is it worth fixing?
Yes,the LED power lite on the front panel stable?Yes,mean the DM power supply board is good.LED power like blinking,mean the DM power supply board is dead.DM power supply is good,still making that clicking sound,when turn on.Mean ur Blast board is dead,that the board that help to light up the projection lamp.
Jun 24, 2010 | Hitachi 43UWX10B 43" Rear Projection...
No sound/picture and red power light always on (Hitachi 43FDX15B)
When u turn the tv on,u hear alot of clicking?That mean the Ballast that help the projection bulb to work is dead.Change the Ballast,might as well change the bulb too.U don't know what is the condition of the projection bulb in.
May 29, 2010 | Hitachi 43FDX15B 43" Rear Projection...
61uwx10ba. no power to any boards but power supply.
have you reched around the new soldering area carefully, check for solder spills or drops in the printed circuit, also another thing to look for is some of those replacement stk do not hold their weight, you might want to take them out and try the old ones to see if you recover tv power.
Jan 15, 2010 | Hitachi 61UWX10B 61" Rear Projection...
Aug 07, 2009 | Hitachi 51SWX20B 51" Rear Projection...
TV Want Power up
This tv have different causes for no power.
Can you tell me if any light on the chassis is off?, if so, let me know the location part number.
Common problem is IC output ( short) or convergence STKs ICs.
Thank you
Jul 26, 2009 | Hitachi 43FDX01B TV
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
No picture or sound
Remove the rear panel. With the TV on you should see a red LED near the center of the PCB. There should also be 5 green leds, 3 to the left a 2 behind. If there is no red leds, check the fuses. If there are no green leds or maybe 1 or 2, disconect PSD5. It's a connector on the left side of the power board that connects to the audio board. It's the 3rd on fro the back. It's labled. With that disconected, turn on the set and look for the green leds. If all 5 light, the power supply is OK and you have a problem beyond that. If they don't all light you have a bad power supply.
Jul 21, 2008 | Hitachi 50EX20B 50" Rear Projection...
Hitachi 50UX26B
Good day, seanhanna;
Hitachi has LED’s, green ‘lights’ and a red light to determine what circuit may be the problem; after removing the back of TV, bottom only, plug TV back in and observe which LED’s come on …..BUT most important which LED’s don’t come on; locate and note number, EG; DP37 and etc.
Good luck, big IRISH. Ps let me know.
Jul 12, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Wont power on
Good day, papamotts;
Jun 21, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Hitachi 43FDX10B Power problem
Below is a few possible causes along with verified cures.
Symptom:
Intermittent shut off
Cause: Check auto link and 4 event timer. redress cabling from front control panel away from blue crt-yoke-hv lead
Symptom: NO PIC OR OSD, PWR LITE COMES ON
Cause: CHECK C603 LEAKY
Symptom: shutdown
Cause: T701
Billy
Jan 23, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Hitachi 61HDX98B 61" Rear Projection Television Logo
89 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
