I HAVE A SHARP TV MODEL 70FW-57E . PICTURE IS OK I GET AUDOI AT THE SOUND AT THE TIP OF THE SOUND IC BUT THEIR NO T.V SOUND
    Scholar:
  • 141 Answers
Maybe the amplifier, did you check transistor and diode on the line to the speakers?
Did you try the spekers individualy and together with another source?
good luck
Posted on Dec 24, 2008
Sharp 20v-w70m speaker and IC ok but no sound
Check the input voltage to IC. If it is absent, the IC won't work. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 31, 2013 | Sharp Televison & Video
No picture. Sound is OK on Philips DPTV345 model 51PW9303/17F
I would check the solder on the Vertical output IC as ofetn the soolder will crack and the CRts will shut down to prevent damageing the CRts when vertical drops out. If the solder looks good I would try replaceing the vertical IC very inexpensive and you can get the vertical IC from www.tvrepairworld.com
Feb 10, 2013 | Televison & Video
No sound picture ok adio output ic good sharp tv model 21V-FW150M
If this is confirmed the fault seems to be in the preamp section or the SIF- sound intermediate frequency section. If you have confirmed that the output is workingg by conneccting an input to the audio input then it should be confirmed that there is no output from the audio line out.
If so you will need to trace using a AF- audio frequency- signal to confirm the area of loss of the AF.
Sometimes this can be some coupling stages or an OP-Amp.
Please trace using a signal and a voltage test. If not get help.
Sep 02, 2011 | Sharp Televison & Video
No sound
Hello
You haven't mentioned about the picture at all. Assuming that, picture is ok I suggests. Ok
If the picture is Ok and there is no sound output from the speaker, your TV has either speaker problem or output Ic problem. To assure where is the fault, you just place your ear very near to the TVs speaker side, and switch on the TV. If you hear a "thumb" sound or a "HUM" sound, your TVs output ic has blown out. If you did not hear any sound at all, the speaker of your TV has gone.
If you have a little knowledge in electronics, you can do it by yoursef. This is a minor mistake. Opwen the back cover of your TV, locate and note the type and number of the audio output Ic, go for that and get it replaced; if the fault is related to Ic. You can do the speaker replacement also by this way. I have given this much advice, assuming that picture in your TV is Ok. Otherwise the fault may be different.
Oct 20, 2010 | Bush Televison & Video
I have a Phillips FLATTV model ... Problem with the Philips Flat Panel Televisions I have a Phillips FLATTV model 42PFL7662D/ 05 I have no picture, the audio is OK, I have had a hissing noise for about 2...
Try with that...
http://www.filestube.com/3c4e959f7e53ba6703e9,g/PHILIPS-42PFL7932-LC420WU5-V2-CIRC.html
Symptom:
Sound but no picture.
Cure:
Master or Slave inverter is defective.
It can be that the driver IC is defective or MOSF
inverter transformers, or 470uF 35V C
Replace driver IC BD9897FS or MOSFET's.
996500046243 IC BD9897FS
996500046242 Mosfet FDD8447L
996500046241 Zener KDZ100V
Oct 18, 2010 | Philips Televison & Video
My sharp t.v 20v-j70m lost power when turn on from red one standby when remoted the yellow will turn off on the screen whats the matter with this?
yung sharp na tv ko 20v-j70m isa no picture but have sound umiinit nang konti yung ic x2933ce ok posibilidad ba po na sira ito
Jul 04, 2010 | Televison & Video
Picture but no sound
main pcb needs to be cleaned were audio ic is. there is black gunk
Jun 01, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Sharp Tv 25E-M50
WELL FIRST U HAVE TO SEE WHETEHR THE SUPPLY FOR VERTICAL SECTION IS OK.IF ITS OK THAN.CHECK FOR SOME DRY SOLDER AT VERTICAL SECTION.OR ANY LEAKAGE CONDENSER ,AT LAST REAPLACE THE IC VERTICAL.IT WILL BE OK'
May 21, 2008 | Sharp 25N-M100 25" TV
Sony tv there is sound but no picture only horizontal line
hi there, one horizontal line means a vertical section prob., check some resistor with low value and a defective diode, possible ic part is defective. do some test and check up. ty
Feb 25, 2008 | Sharp 27C-240 27" TV
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
