Fan on Graphics card is making noise - Computers & Internet
  • jaeymonkey54 Jan 21, 2009
    were is are the bearing at .. i took of the sticker but dont know were the bearibg are
    Scholar:
  • 97 Answers
I am assuming the noise is an abnormal squeel or such as opposed to the normally annoying fan noise that most cards have. If so...depending on the fan and card model, it can be replaced. But if you are like me, you want it fixed now. Most Fans are sealed and if the bearings go, well thats it for that fan, but some have a sticker on the center of the fan. i you peel that sticker off you might see the bearing, and if you are lucky enough to see that, drop ONE DROP of 3-in-1 oil, or such. if you cannot see a bearing and you cant find a replacement, you should still be able to remove the fan (Carefully). with the fan off, you can soak it in either wd-40 or light oil. after this you must be sure to clean off all excess oil (compressed air is best) before reisntalling.
Posted on Dec 24, 2008
3 Suggested Answers
map9966
  • 2351 Answers
SOURCE: Fan Noise
No it's not normal. Send it back to where you bought it.
Posted on Jun 30, 2008
Vaio Tech
  • 166 Answers
SOURCE: the fan on my graphics card makes a loud humming
the only way is replaced and if is not in the garantye you going need to buy from a retail site and install youself go here ( http://www.directron.com/vichfa.html ) and see the one that fit your bujet thanks
Posted on Nov 11, 2009
Asus essentio pc fan noise issue
The fans generally are not controlled by the user. If you post the model number, I can check, Noise means that it is either becoming dry on the spindle or it is becoming very dirty.
Jul 14, 2013 | Computers & Internet
Humming noise when volume is reduced...also, when turning on tv.....how do you get rid of the noise?
thats the noise you can ignore, it comes from every graphics card...more fast is your card, more is the noise you get (mostly because of fan)
Apr 08, 2011 | Computers & Internet
I have fan noise on my new ecs elitegroup GeForce GTX 460, a simple tuch on the fan and noise immidiatly goes away? HELP !!!
Hi samohtpfeffe, i've been having the exact same problem. if fan making noise because you video card is over heating, or you fan is about to die, if the fan stops spinning and this will cause video card to overheat and damage and system lock up or crash, i recommend you replace video card fan as soon as possible, to solve this broblem.
Good Luck!
Dec 01, 2010 | EliteGroup Computers & Internet
Loud gpu fan makes a buzzing noise that is very annoying
How long have you have the graphics card? The fans turn at a very high RPM, and when they start to wear out they can become imbalanced and make a buzzing noise. Replace the fan if possible, otherwise you'll need a new card.
But first, I would try blowing out the fan with some canned air. Sometimes an accumulation of crud or a piece of debris on one fan blade can imbalance the whole thing.
Mar 19, 2010 | Computers & Internet
My vaio VGN-FW390 fan make noise.
The fan makes noise in high preformance windows like windows vista&7. So it is normal, because the windows uses motherboard,ram and graphics card with high preformance so they get hotter, so the fan get stronger to cool them or they will be damaged.
This noise also exist in windows xp, but only when opening high graphics game, or being working with the laptop for along time.
Jan 31, 2010 | Sony VAIO VGN-FW390JFB Notebook
Loud noises
it is very possible that that fan is mulfunctionning overheating the videocard. replace the fan. (you can by the fan seperate from radioshack or some local computer store. (sometimes it is cheaper to replace the video card since it comes with it's own fan.) but of course it depends on what card you have.
Jun 18, 2009 | Compaq NVIDIA TNT2 M64 (32 MB) AGP Graphic...
When i turn on my pc, there is beeping noise none stop, my screen show NO SIGNAL. Is this due to graphics card damaged.
This could be many things, graphics card, memory, etc. Try opening the case and checking to make sure everything is seated in its respective slot, including the processor, then turn the computer on and make sure the processor fan is running also.
Also, does this computer also have onboard video? Get back to me and let me know.
Mar 16, 2009 | Acer Computers & Internet
Cooling fan makes noise
peel back the sticker on the middle of the fan, and use a graphite based lubricant on the bushing.
Also there are smaller stick-on type fans that can be used. Normally for cooling chipsets.
Jan 18, 2009 | Nvidia G-Force FX5200 256M DDR 8X AGP...
Fan Noise
Jun 29, 2008 | VisionTek ATI RADEON HD2400 Pro Edition...
Card Fan
Without the fan your card may burn. Go to your nearby Pc junk store and get a graphic card fan of same size and voltage. To remove your fan from the card try to push the plastic pins located on the corners of the fan's body. Hope it works .Don't forget to vote me. Tell me again so i may fix your problem. Thanks
Mar 28, 2008 | ASUS EN7800GTX GeForce 7800 GTX, (256 MB)...
Computers & Internet Logo
569 people viewed this question
Alun Cox
David Payne
David Payne
