Question about Haier 5 cu. ft. / 142 liter Chest Freezer HCM050LA
Freezer light flashes
The freezer light on the outside of the freezer is flashing irratically. The freezer is in my garage. I checked the outlet to see if that was the problem, it was not. The freezer seems to be running fine. Just want to know why it is flashing now.
  • kartvines Apr 11, 2009
    flashing power light, otherwise the freezer seems to working fine,is this a pending problem?
  • 55 Answers
If its a neon lamp then the flashing might be normal
Posted on Oct 06, 2009
My Hotpoint freezer FZ150 red light keeps flashing. I turn freezer off then on again and its ok for a bit, then it flashes red again,
the flashing maybe door is not sealing check gaskets on door for folds or tears or door not aligned right
Feb 26, 2017 | Hotpoint Freezers
Hotpoint fzfm151p. Bought a year ago. Worked fine up until I moved this month. My dad placed freezer in garage by mistake. Lights flashed (all) ever since it was in there. I've just moved it into the house...
Freezers have an electric motor within to pump the freezer gas around. Its possible the movement has caused a problem. Get ban appliance shop or tech to check it out.
Dec 29, 2014 | Freezers
Inhave just reurned from a short holiday and found My Miele f1313s freezer has the alarm light flashing. Thoughts?
Make sure you have enough amps in the outlet its plugged into. The kitchen outlet might of had more amps than the garage outlet. Also, try unplugging it for a few seconds then plug it back it which might reset it.
Sep 20, 2014 | Miele 3.7 cu. ft. / 105 liter Upright...
How do you activate the flash defrost function on a Kenmore 16082 model? I can't find any flash defrost button.
Hi
Not all these models were fitted with a flash defrost plunger, if fitted it is inside the lid on the left hand side.
You will need to remove all the product from the freezer and store it elsewhere.
1. Pull out the flash defrost button
2. Put a chock of wood or similar to prevent the lid from closing (if the lid closes it will stop the flash defrost)
3. Wait until all the ice has melted then clean out the casing, some of these models have a drain plug in the base, (put a shallow tray under the outlet to catch the water) others you will need to mop out the water.
4. Push in the flash defrost button and wait for a couple of hours and then you can reload the freezer.
If there is no flash defrost button then follow the above instructions after you have emptied the freezer, all you need to do is switch off and unplug the freezer then go to 2. above. When finished plug back in and reload.
Regards
Gordon
May 05, 2011 | Kenmore Chest Freezer 16082
Nup right freezer model # 2532240210 I defrosted then turned back on and all the lights on outside of door is flashing is there a problem?
Does the unit have a digital control on the door? If so try unplugging the freezer for about ten seconds to reset the control. If they still flash replace the digital control. If you do not have the digital display, and its just an orange light at the bottom, then no worries they sometime flicker
Mar 20, 2011 | Kenmore 13.7 cu. ft. / 388 liter Upright...
My chest freezer shut off (the outside light was
Try to plug somthing that you know it works ,in that outlet ,and if it doesn't work or goes on and off , the problem is in the outlet, but if works without trouble ,the problem could be in the freezer plug , the cord or the cord conections to the freezer.
Sep 13, 2009 | Kenmore Freezer 8.8 cu. ft. Chest Freezer...
Does the light on the outside of freezer stay on . I bought a used freezer. It is a frigidaire commercial upright (frost free) Does the light on outside of freezer stay on all the time? I have no manual....
Normally there is a Green light showing that power is on
A Yellow one for fast freeze and a Red one for under temperature
The outer casing is well insulated from the inside otherwise the freezer motor would run none stop without cooling the contents so the temperature of the outside casing will reflect the room temperature not the intenal
Aug 21, 2009 | Frigidaire 20 cu. ft. / 566 liter Upright...
Flashing red light
red light flashing on servis fridge freezer
Mar 19, 2009 | Freezers
Haier 5 cu. ft. / 142 liter Chest Freezer HCM050LA Logo
950 people viewed this question
Top Haier Freezers Experts
Marvin
Marvin
Dennis Boxerman
Are you a Haier Freezer Expert? Answer questions, earn points and help others
