Question about Refrigerators
My Sub Zero Refrigerator won't turn on.
I accidently left the refrigerator door open on my Sub Zero for about a half hour. I walked by and saw the light was off and the door was open.
I thought the refrigerator was shut off (and the noise I heard was just the freezer part) so I pushed the on-off button. The refrigerator turned off and now it won't turn back on when I push the button to on.
  • 3600 Answers
SOURCE: Sub zero refrigerator has stopped cooling but freezer still works
is this a side by side?
Posted on Jun 20, 2009
  • 327 Answers
SOURCE: freezer is working but refrigerator is not :(
Hello, you need to find out if the evaporator fan in the freezer is working. or if the evaporator is all iced up. If the fan is not working you will need to replace it. If the coils are all iced up you have a defrost problem and that will need to be resolved. Once a evaporator is all iced over air can not pass through it and you will loose your cooling in the refrigerator first. Check the heater and the terminator to make sure they are good. You can use a hair dryer to clear the ice off the evaporator. Once you find the bad part replace it and the unit will function normally
Thanks
Posted on Jul 12, 2010
  • 109 Answers
SOURCE: ice maker
verify the water supply to the valve first, second verify valve to icemaker works(unit has dual valve at rear bottom of fridge, switch plugs, then press water dispenser and see if icemaker fill with water ) if fills icemaker is bad , if not valve is bad. replace one or the other.
Posted on Mar 28, 2008
abhishek33
  • 1239 Answers
SOURCE: sub zero refrig - ice forming inside
HI This component is a heating element located on the evaporator coil. When the refrigerator or freezer switches to the defrost cycle, the defrost heater is turned on to melt the frost in the compartment. Failure of the defrost heater causes failure to defrost.Test the element with a VOM set to the RX1 scale. To gain access to the heating element, remove the compartment's wall panels. Clip one probe of the VOM to each element terminal. The meter should read between 5 and 20 ohms. If it doesn't, the heating element is faulty and should be replaced. Replace the heater with a new one of the same type and electrical rating. Connect the new heater the same way the old one was connected.
Posted on Oct 12, 2008
  • 71 Answers
SOURCE: sub zero 550 refrigerator light not working
first try to tightin the bulb, it has a seal and it's hard to drive it home. otherwise it could be the door switch.
Posted on Dec 24, 2008
LCD panel and lights not working
On your Sub-Zero 642 Your display will not work unless your refrigerator lights work.
1st. Make sure your light bulbs are good.
2nd. Check your refrigerator door light switch.
3rd. The subzero uses a thermal overload to kill your lights if the door is left open to long.
http://www.on-timeappliance.com/subzero.html
Mar 26, 2012 | Sub-Zero 642
Suddenly making noise from above the refrigerator behind the vent
Almost certainly there is an ice build up which has eventually migrated to the fan blade. Do a 12 hour defrost to ensure a proper "defrost", then try again. Very possible the door was left open slightly by accident.
Jun 08, 2010 | Sub-Zero 695/O Side by Side Refrigerator
Refridgerator light out, panel out, freezer fine
It's probably the swtich (the one on the left at the top of the door opening).
Sep 25, 2009 | Sub-Zero 680 / F
Left door open on Sub zero model 650
It went into self protection mode. Just leave it closed and when the compressor cools down enough, it will start. Once the ref starts to cool, the lights and such will come back on.
All of this assumes that no failure was caused by the long run times when the door was open
Sep 02, 2009 | Sub-Zero Bottom Freezer Refrigerator
Sub zero stopped working after door left open
whe n you left the door open the fridge have a sensor. and turn the LIGHTS OFF. close the fridge let it cool again.
Aug 09, 2009 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Sub zero 550 refrigerator light not working
Dec 22, 2008 | Sub-Zero 650 / O Bottom Freezer...
Left Door open now it wont power up
you can un plug it for 30 minutes to an hour and plug it back.
hope it would run normally.
tnx 4 using fixya,
drcool
Sep 27, 2008 | Sub-Zero 650 / O Bottom Freezer...
Refrigerator light goes out
look like door switch
HTML clipboard http://www.SubZeroLosAngeles.com
________________________________________
Sub-Zero Service Experts in LA Metro
Aug 13, 2008 | Sub-Zero 632 / S
Sub zero 690 the control lpanal light does not come on
If the refrigerator is working fine, you may have a bad door-switch. Open the refrigerator door, you will see two switches on top, the one on the left is for the lights; try to tweak it may just be stuck. If this does not work you have to replace it. You can double-check this by shining a flashlight behind the control panel and you can see the temp. and the other info. This means the panel is fine. You can also try to contact Sub Zero customer service, they may send you a new switch for free.
Good luck and I hope this help.
Byron12020
Jul 30, 2008 | Sub-Zero 690 Side by Side Refrigerator
Refrigerators Logo
1,674 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
