I cant get my monitor to work with this mother board
    Scholar:
  • 141 Answers
First be sure that the monitor is working (plug into another computer or laptop).
on you have that try to get a video card, it might solve you problem, if not change the mother board
have a good christmas
Posted on Dec 24, 2008
Turned computer on and monitor instantly goes to sleep,also cant turn off the computer using button.have to use switch on power supply
Try this, unplug everything from the other board except the main hard drive, power connections, and monitor. if it does not come up, remove ram cards, leaving one stick. try again, if it is still bad swap ram sticks. If after all of this it still does not work you have a bad motherboard or processor
Nov 14, 2011 | HP Compaq Presario SR5210NX Desktop PC...
Hp pavilion slimline x3507c pc. when I boot up the monitor remains in standby mode. I have already determined that the problem is in the computer not the monitor. The power supply is good, the fans run,...
very simple bring a new AGP card and plug in it on your pc and plug the monitor pin in new agp now start your computer . monitor will turned on.
if the monitor is not turned on its mean your have problem in your ram or mother board for that pluged out your all rams from your pc and start your computer if cpu ring a beep its mean you have ram problem and the mother board is ok but if you cant hear any beep its mean mother board's problem ram is ok.
Jul 16, 2011 | HP Pavilion Slimline s3700f PC Desktop
Reinstalled windows and sound will not work. i th...
Driverguide.com, or the mother board manufacturer web site.
Make, model, mother board info will help.
May 20, 2010 | SVA-USA SVA VR 15" Flat Panel LCD Monitor
Dear sir, my computer asus sis961 is not working, power is not showing in mother board, technician is telling in mother board short sirkit
Do u know how to assemble a pc
if yes take the mother baord out of cabinet . place the mother bord on an insulating surface with proceesor . then connect smps ... poweron the board by shortin the frnt panel connectors . connect all peripehrals like monitor , kb and mouse etc ..... if this seems to be working try to insulate the cabin whre mother board is fixed ................ SMPS can also cause no power try chekin with another smps too
Aug 05, 2009 | ASUS P4SE Motherboard
Does old mother board supports LCD monitor?
You’ll be fine.
Most LCD monitors either have VGA connection you’ll need or have VGA plus other connections but, all you need is the VGA connection.
Mar 01, 2009 | ASUS LCD Monitor
HCL HCM780M CIRCUIT DIAGRAM
SIR..., regarding monitor...display block characteristics which is operated manually by buttons situated bottom of monitor is anytime coming at the centre of monitor display... The settings block comes on suddenly and we are unable to exit from the same sometimes the block goes off without any action and everything is fine till it is back again and it is come again and again.....by all this i did'nt work on my PC...all result it's useles......please sir giving your suggestion as soon as possible....... This has been happening for the last 1 year and is a real pain Please send some solution
Jan 23, 2009 | Computers & Internet
Hi Colour on my Acer monitor has gone ? Initially everything went green' I've reset monitor settings and some improvement resulted - now the reds are palest yellow Any suggestions tom
most of such cases are not due to problem in monitors... they are problems caused by mother board's or the externally attached graphics/video cards... So in order to make sure which causes problem.. you can try to connect another monitor to your system.. or perhaps your monitor to another system...
If the monitor is faulty colored everywhere.. then the monitor has to be given for repair.. (you cant do it by yourself)
if the other way... any monitor connected to your sys is faultly solored.. then you have to change your video card attached to mother board...
hope this helps your situation..
Apr 14, 2008 | Computers & Internet
White lines going across the screen
THere are two possibilities
1. problem in mother board
2. problem in monitor
To make sure if possible connect your CPU to another monitor and see if all is fine. If the other monitor works fine, then your monitor has th problem
if the other monitor also has lines, then the mother board's video card has prob.
Also check the connection wire between the CPU and monitor that there is no loose contact or any cuts or damages in the wire
Apr 11, 2008 | Computers & Internet
Monitor displays signal cable disconnected
Check if motherboards you connect the monitor into has a video signal frequency range that the monitor supports.
Feb 01, 2008 | Dell UltraScan P1110 21" CRT Monitor
MY PACKARD BELL PIV HAS N1996 MOTHER BOARD and no display is comming
MY PACKARD BELL PIV HAS N1996 MOTHER BOARD I cant see any display on my screen when i turn on my computer. But it looks it has read all the information from harddisk and loaded the operating system. but on screen i cant see any raster i.e. display.
First At this time u observe one thing check the Numlock Status if it is ON/OFF (Glow ) in Keyboard when u pressing the  Numlock key, the system is giving display check with pci vga card.
If not u  remove the Ram module and heard the Beepsound,if Beep is comming Clean the Ram & Ram slot the try it again
If not check with another Ram module.
If it is also not problem u clear the CMOS once and check it
Jan 22, 2008 | Computers & Internet
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
