Question about Sony PlayStation Portable (PSP) Console
Firmware 4.01 is not installing in my psp
When i downloaded the psp firmware 4.01 and its eboot.i copied the update folder to game folder and renamed eboot.pbp as 401.pbp and then i copied it into the game/update folder and disconnected my psp and went to game option/memory stick and opened the file psp update ver 4.01.and after pressing x it gave me"the game could not be started(80020148)
  • Anonymous Dec 24, 2008
    bought this psp 4.01 but it cannot be modify yet since according to them theres no program yet for this version. When do you think it will be available. find this version horrible since umd is so expensive. Im dying to play my psp.
  • Anonymous Apr 21, 2009
    I have psp phat.. with 3.71 m33-2 version... can i upgrade directly to 4.01 m33-2? what's the step by step?
    Problem Solver:
  • 6 Answers
I think you are trying to install a CFW update on an OFW PSP. Just rename 401.PBP to EBOOT.PBP and get rid of the other EBOOT.PBP.
Posted on Dec 24, 2008
I was adding a game in my psp version 6.60, but when i opened the games in memory stick, there was no game, just a message came "There is no games...". I failed to find its proper solution so please help...
I had this problem (same firmware), and this is what I did. It works a treat. You need to downgrade from OFW (Official Firmware) 6.60 to 6.20, and then install CFW (Custom Firmware) 6.20. This guide shows you how to downgrade and gives you the program to do it:
Here is the 6.20 official firmware:
When both of those have been downloaded, extract them to X:\PSP\GAME, where X is the drive your PSP is in.
Disconnect your PSP and turn it on. Then go to your memory under the Game section on the XMB. Run the downgrader (you need at least 75% battery, otherwise the program will kick you off). When the update's at about 85%-90% you may get an error, but don't worry about it. After it's installed, it should boot and show you a blue screen. Press circle. When you load up again, feel free to delete the update files from your memory stick. Then reconnect your PSP.
Now that you've downgraded to 6.20, you'll be able to permanently mod your PSP with custom firmware.
Download this and extract the folders to the root of your PSP (don't worry about overwriting; the folders merge):
Disconnect your PSP again and head to the memory stick section under Game in the XMB. Run the Pro Update program.
Your system should reboot.
Go back to Game > Memory Stick Utility, and then click on the permanent patch. It'll ask you if you want to install the patch. Press X.
It'll tell you that it's saved a file. Run it on the fake vshmain.prx. Connect your PSP to your computer and copy the file (vshorig.prx) to your desktop. If your PSP bricks (unlikely), putting that file back on should unbrick it.
After that, run the permanent patch again on your PSP but this time press circle to go past saving the file and install the custom firmware.
Now, if you're trying to put PSP ISO files on your console, you need to create a folder called "ISO" without quotation marks in the root of your PSP. When you download a PSP ISO, they go in this folder.
If you want to play PS1 games on your PSP, you'll need to create EBOOT files from the disc images you download. Just follow this tutorial and you should be fine.
You can download emulators and run those, too. Happy pirating! ^_^
Jan 27, 2013 | Sony Psp 3000 Hdwe System Portable Gaming...
How to eboot your psp i cannot open
in order for your PSP to be able to play eboot files, it needs to have custom firmware installed. if it does, go into "PSP" folder in your memorystick, the go into "GAMES" folder. after you do that, just create a new folder and name it whatever you want, or the name of the game, then just place your eboot file into the folder that you just created . you should be able to play the game now...
Jul 08, 2011 | Sony PlayStation Portable (PSP) Slim...
Hello. It is very simple do to this. You should only follow my steps:
First of all, you have to download a file name called EBOOT.PBP (psp upgrade) which is located HERE
Save it on your desktop and do not rename the file.
Plug in your USB cable and go to your PSP's System Settings and on the second from the top press X on USB CONNECT. Go to "My Computer" and click on Removable disk. Here it should be a folder named PSP followed by a subfolder called GAME. Enter this folder, create a new folder and name it UPDATE (in caps without spaces). In the folder you have just created, move (copy - paste) EBOOT.PBP here from your desktop. Also, if there is no GAME folder, you have to create it in the folder "PSP". Be carefully! Remove your hardware and fully charge your PSP and plug it on the wall. Go to Games Area and choose Memory Stick by pressing X. You will see now PSP Update version
*. **. Press PSP Update version *. ** (it will only clear your screen for a couple seconds). Press Start if you want to upgrade. Go to User Agreement and start the upgrade process. While it's started, do not touch your PSP. Leave it somewhere until the upgrade is done.
I hope I helped you!
May 21, 2011 | Sony PlayStation Portable (PSP) Console
How 2 upgrade
It depends what firmware you are trying to upgrade to. If you want to install custom firmware on your PSP, check this YouTube channel:
If you want to install official firmware, you can find a list of downloads here:
When you select the firmware you want to install, download it. You will get a .zip file with a file inside called EBOOT.PBP. Follow these steps to update:
1.) Connect your PSP to your PC. 2.) Open the PSP folder and then the GAME folder. 3.) Right click INSIDE the GAME folder, and click New Folder 4.) Name the new folder UPDATE 5.) Place the EBOOT.PBP file you downloaded into the UPDATE folder. 6.) Disconnect your PSP from your computer, and select the MEMORY STICK ICON in the GAME section. 7.) Find the PSP Update Version.. and run it, complete the on screen steps to install the new firmware.
May 16, 2011 | Sony PlayStation Portable Slim Black...
My psp have "CHICKEN" software, when the games are hang my psp shutdown and the games are hiding,how do i upgrade my psp?
1. To get firmware upgrade data . you need to download a file form PSP official website . File name is EBOOT.PBP ..
2. connect your pc with psp . now move to the settings and the secound option from the top press X .
3. Now click the removable disk and there would be a foldr name PSP , inside it there is another folder GAME . inside it create another folder name it as update . now paste EBOOT.PBP in that folder
4. Remove your PSP
5. On your PSP press "X" on *.**, which means an update . just install it on your psp
Mar 22, 2010 | Sony PlayStation Portable (PSP) Console
How do i update my psp
well if you want to update with legit firmware then just go to your network update connection and it will update the psp to the lastest OFW, if you want it modded then you need to tell me the series of the psp!! if you dont have wireless the you have to download are higher firmware for ur psp and then put the eboot.pbp file inside a folder called UPDATE all caps and then put that in the PSP/GAME the game folder is the folder you put it in then simply go to ur games list on your psp and update it! ALL WAYS HAVE YOUR CHARGER HOOKED UP YOU CAN CRASH UR PSP IF YOU DONT HAVE THE CHARGER HOOKED UP
Dec 26, 2009 | Sony PlayStation Portable (PSP) Console
How do i upgrade my psp2001?
for you to upgrade your psp, you'll have to connect your psp to your computer and download the update from sony's website., visit the lik and update your psp.
Oct 27, 2009 | Sony Video Game Consoles & Games
You just connect the psp to your computer using a usb cable.Then create a folder in your Memory Stick Duo named “PSP“, under this folder, create a sub-folder named “GAME“, under this sub-folder, create another sub-folder named “UPDATE” (Note: all folders name must be CAPITALIZED).Download the PSP 5.51 update file via this link: the file as “EBOOT.PBP” to your desktop then inside the UPDATE folder copy the EBOOT.PBP.Then go to games>memory stick and hit the x button there should be an game press x again to upgrade.The udpate process will take about 10 minutes.Thats all.
Aug 22, 2009 | Sony PlayStation Portable (PSP) Console
Ps1 games won't play on my psp
You will need a emulator or if you have downloaded the ps1 game of sony themselves for psp contact them to get your money back
Jul 20, 2009 | Sony FORMULA ONE 2000
Can i play eboot.pbp on psp?
yes you can if you have a custom firmware. the psp will not recognize the eboot file itself unless you put the eboot file inside of a folder with the name of the game as the folder name. then you save it to psp/game. iso and cso files are placed in the iso folder of the root.
Feb 27, 2009 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
297 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
