Question about JVC GY-X3 Camcorder
Noise in video while out side
I'm having noise in the video while shooting out side. I noticed it stops if I get the sun behind me.
  • 68 Answers
Check the lens for some hairy scratch or nun seen dusty spots it may cause un wanted reflection by the way are you using the proper db . switch location it should be at minumom at out side regards
Posted on May 03, 2007
  • Joe Simiana
    Joe Simiana Mar 31, 2012
    Also check your External or Both Mic Switch aint on !!
He recently noticed a clicking noise on the left side of the center console. When this noise occurs, his rear lights will not illuminate. Tapping on the console sometimes stops the clicking noise.
its a relay failing will need replacing or repairing. there are a number of relays you need to replace the damaged one with the same number.
Jul 06, 2017 | Pontiac Cars & Trucks
Gridding noise on right side in engine compartment,or possible hub/wheel bearing
If over 100000miles most probable c-v joint needs to be replaced. Very soon. Save yourself the trouble & do both sides. If one goes the other is not far behind.
Aug 27, 2015 | 2000 Nissan Maxima
Here we go, I have a GE side by side about 6 years old... Started with the icemaker not dispensing ice consistently... then the ice stopped all together (even though the bin was full and not froze solid)....
The clicking you are hearing is the relay unit. Now it is for sure that the compressor is not working as the relay keep s tripping off.
So first of all to clear this doubt, let us checck the relay unit which is clicking. remove and check. most of the time the relays need to be replaced as a poor contact will not deliver good voltage to the compressor and it will shut off. So check this out.
One the compressor works and you notice there is cooling the sytem seems ok except that you must check if the thermostat, the auto defrost cut off timer works.
If after the compressor works the cooling is not good then you can decide on a replacement than to spend for expensive repairs
Sep 12, 2010 | Microwave Ovens
Recently noticed when driving over 40mph, I hear a loud humming like tire tread noise, coming from the front. When I'm turning right it gets worse. Turn left and it virtually vanishes. Is this the...
yes.this means the left wheel bearing is bad, because when you turn right the pressure is pushing down on the left wheel causing noise and when you turn left the pressure then pushes down on the right side removing pressure from the left side causing noise to stop.. this is why when you turn one way or the other the noise stops and starts.
Jan 16, 2010 | Chevrolet TrailBlazer Cars & Trucks
Sun visor won't stay in place & A/C knocking noise
Sun Visor:The only thing you can do,besides dealer,is go to a junk yard & find one to match what you have .It should be easy to put on.
Sep 10, 2009 | 2006 Chevrolet Impala
Problem electric daewoo matiz
hi i have a 51 reg daewoo matiz and i have noticed a noise appearing for a few minutes when driving a around 30 to 40 mph then it stops then starts agin a few minutes later ,it sounds like its coming from some where behind the speedometer ,it sounds like a dry spinning noise and i did notice the speedo needle flickering but it orso made the noise when starting from cold
Sep 05, 2009 | 2000 Daewoo Korando
Loud Intermittent Droaning Noise
rear axle to ring gear side bearing is loose due to weak preload. might be able to locktight is its not to late. was in bmwmoa memeber mag this month december08
Nov 30, 2008 | 2004 BMW R 1150 RT (ABS)
the fan behind the ice maker is iced up poss fault defrost heater gone try total defrost faor a list 36 hrs restart it noise come back then you need to repace the defrost heater hope this helps
Nov 13, 2008 | Samsung RS2630SH Side by Side Refrigerator
Maytag refrigerator clicking noise and stopped working
How long a period of time have you noticed this noise? If it just started and the refrigerator just stopped it could have entered its defrost cycle. When the defrost heaters come on you may hear the heat causing some expansion. After a few minutes(18-22) the defrost cycle ends and the refrigerator will restart.
May 30, 2008 | Jenn-Air JCD2389G Side by Side...
JVC GY-X3 Camcorder Logo
146 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
