Question about Lexmark X3470 All-In-One InkJet Printer
How do i scan to my computer
How do i scan information from my scanner to my computer
    President:
  • 1,179 Answers
Install the software that came with the printer. There should be an ocr program included. That is the program to use to scan. Hope this helps.
Posted on Dec 24, 2008
I have a Jujitsu Scan Partner 3091DC and would like to know how to use it with a Mac Version 10.7.2
Hi Dwight,
To use your Fujitsu Scan Partner 3091DC scanner with Mac v10.7.2, you need theMac driver for the scanner. Please be informed that this model is discontinuedand no longer available with Fujitsu. Also, the manufacturer has not yetpublished the Mac driver for Scan Partner series scanners. For moreinformation, please visit the following link:http://www.fujitsu.com/us/services/computing/peripherals/scanners/support/drivers-downloads_index.html#Hope the above information is helpful.Thanks & regards,ScanCare
Dec 03, 2011 | Fujitsu ScanPartner 3091DC Path-Through...
Tip
How do I read Barcodes in Microsoft Excel?
<p>Bar code symbols are composed of a number of adjacent bars and spaces of different widths of pre-defined codes. A barcode scanner is used to read or scan the bar code symbol to represent the information to decode. Once the symbol is scanned by a handheld reading device or another, can then be used by computer software to track inventory and perform other functions. Microsoft Excel is a computer application that use bar code information can make the business perform. <br /> <p><br /> <p>1. Insert bar code scanner to your computer using the "interface cable keyboard wedge". The keyboard wedge interface cable looks like the printer port of your computer, and differs only in that a connection between the scanner bar code and serial number of your computer or USB port. The cable is provided as a peripheral pattern with hand-held bar code scanners. <br /> <p><br /> <p>2. Open Microsoft Excel on your computer after the bar code scanner connected to your computer. <br /> <p><br /> <p>3. Links on the Excel cell to the bar code to enter and bar code scanning to load it into Microsoft Excel. <br /> <p><br /> <p>4. View the data in Excel file is translated into a vision of the bar code information. <br />
on Jun 26, 2011 | Computers & Internet
HOW DO YOU SCAN
Hello pjbenven!
To use the scan features, your device and computer must be connected and turned
on. The printer software must also be installed and running on your computer prior to
scanning. To verify that the printer software is running on a computer running
Windows, look for the device icon in the system tray at the lower-right side of the
screen, near the clock. To verify this on a computer using the Mac OS, open the HP
Device Manager, and click Scan Picture. If a scanner is available, it will launch the HP
ScanPro application. If it is not available, a message appears to let you know that a
scanner was not found.
To send a scan to a program on a computer from the device control panel (direct
connect)
1.
Load the original on the scanner glass. For more information, see Load originals.
2. Press the left arrow or the right arrow to select the Scan function, and then
press OK.
3. Press right arrow to select the program that you want to use (such as the HP
photo and imaging software), and then press OK.
4. Press Start.
You can find more information on the serivece manual
http://h10032.www1.hp.com/ctg/Manual/c01368573.pdf
Jul 16, 2010 | HP OfficeJet J4580 All-In-One Laser...
I need to scan
I would like to inform you that scanning involves bi-directional communication between the All-in-One and Computer, to check if the All-in-One is able to communicate with the Computer, please follow the steps below to scan a document or image from Windows Imaging Acquisition.
1. Verify that the all-in-one product power is turned on and the printer cable is properly connected.
2. Click Start.
3. Click All Programs.
4. Click Accessories.
5. Click Scanner and Camera Wizard.
6. Follow the Scanner and Camera Wizard instructions to scan images to the computer
Jul 16, 2010 | HP PSC 1410 All-In-One InkJet Printer
I need to know how to scan documents.
If you are using a computer with a Windows Operating System (XP, Vista, etc., ) I can help. Just follow these directions: (From beginning to end)
1) Make sure that the power to your scanner is On but do not plug your scanner into your computer until instructed to do so by the software.
2) Place the CD that came with your scanner into the CD drive of your computer. Install the software for your scanner and plug your scanner into your computer.
3) Re-boot your computer.
4) After re-boot, place a document you want to scan under the lid of your scanner.
5) Go to:
Start > All Programs > Accessories > Paint (and click on the Paint program.
6) When Paint opens, go to the upper toolbar in the program and click on, 'File' then scroll down and click on, 'From Scanner or Camera.'
(a window will open)
7) Click on the icon for your scanner and then click, 'OK".
8) Choose the type of document you wish to scan and click, 'Scan".
9) Note: Some scanners take a moment to 'warm up' before scanning. If your scan doesn't begin immediately, just be patient.)
10) Your document will be scanned and automatically imported into the Paint program.
11) When you can see the scanned document in Paint, (again) go to the upper toolbar and select, 'File' > scroll down and select, 'Save As' > (your Pictures Folder will open) > type in a name for your document > and click, 'Save'.
12) You can now exit the Paint program and go to your Pictures folder. There, click on your scanned document to view it.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
Feb 07, 2010 | Office Equipment & Supplies
I HAVE A NEW COMPUTER AND I WANT TO SCAN A PICTURE BUT I CANT REMEBER HOW TO DO IT. WITH THE EPSON PRINTER
5) Go to:
Start > All Programs > Accessories > Paint (and click on the Paint program.)
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!!
Feb 06, 2010 | Office Equipment & Supplies
I have a Canon Cano Scan 4200f. It worked in the
First, try unplugging and re-seating the USB cable in your computer. I am assuming your scanner is not making any noise when you first turn on the computer. If that is not the case, respond back with more information. This is the most common solution to this problem with these scanners though.
Dec 21, 2009 | Canon CanoScan 4200F Flatbed Scanner
I can't scan. "gathering required information" massage loops.
i went into the control panel and opened scanners and cameras, right clicked on my scanner, and clicked "get picture using scanner wizard", from there i followed the instructions, and bobs your uncle.
Oct 22, 2009 | HP LaserJet M1522nf Multifunction Printer...
How can I scan from my scanner to my computer
Of course scanner have it's own freeware software provided with driver & software for your scanner with all operating system required.
Run the Disc to install a program with the drivers also to let you scan documents, pictures, & etc...
All the setting are there to know how to scan.... First Preview it then scan and it will send to your driver (destination folder) where it saves the files.
Sep 19, 2009 | Epson Perfection 2400 Photo Flatbed...
Problems scanning to PC from DP-180
  • scan your computer using norton 360
  • if you dont have upgrade it
  • www.antivirusware.com/norton-360/
Jul 19, 2009 | Office Equipment & Supplies
Lexmark X3470 All-In-One InkJet Printer Logo
41 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
