Question about Dell Dimension 8400 PC Desktop
Cannot use reader 8.0,cannot remove it or install 9.0
I have had problems with acrobat pdf and reader 8.0. I tried to remove it in favor of 9.0. Then it tells me 8.0 is still there and 9.p will not install.I get 1714 errors which will not resolve either whatever the 'net recommends. EVERY PDF FILE OPENED FREEZES THE COMPUTERS
  • 238 Answers
Sir, I will give you 4 solutions for your problem with adobe pdf and reader. Here are :
  1. Select the MSI file from the original installation files.
If the error message allows you to browse to the .msi file, then complete the following steps:
In the error message box click Browse.
Navigate to the original installation files for the product and version you are trying to install and select the .msi file
The installation should now be able to continue.
     2. Remove all previous versions of Acrobat and Adobe Reader using Add/Remove programs.
From the Control Panel, choose Add/Remove programs.
Select the most recent version of Acrobat or Adobe Reader in the list and click Remove. Restart the computer. You should now be able to install the application.
     3: Attempt to repair Acrobat from the installation disc or cached installer files.
Important: If you do not have the cached installer files, and you have a downloaded version of Acrobat, then you must download the installer again. This information also applies to the tryout edition of Acrobat.
To repair Acrobat:
Insert the Acrobat disc, locate the downloaded installer package, or navigate to the cached installer files.
Note: By default, the cached installer files are located at x:\Program Files\Adobe\Acrobat 7.0\Setup Files. If the cached installer files are not available, then you must use the original media.
Start the installation again from this location.
Follow the onscreen instructions, and choose to Remove Acrobat.
Complete the onscreen instructions.
     4: Use the Windows Installer CleanUp Utility (stand-alone installations of the previous version only).
Sir, use the Microsoft Windows Installer CleanUp Utility to remove it.
Get the Windows Installer CleanUp Utility from the Microsoft Support webpage at http://support.microsoft.com/default.aspx?scid=kb;en-us;290301
Run the executable to install the software.
Note: On Windows Vista you might need to right-click on the downloaded installer and choose the option to "Run As Administrator".
Choose Start > All Programs > Windows Install Clean Up.
Highlight any previous versions of your Acrobat and Adobe Reader, including patches, and click Remove.
Once all versions of Acrobat and Adobe Reader have been removed, Click OK and then exit the software.
*You can now able to install acrobat and reader successfully.
Posted on Dec 24, 2008
    Scholar:
  • 97 Answers
Oddly enough, you may find that updating the version 8.0 you have to 8.x will then allow you to remove it (or it will work correctly) can you open the reader manually in the programs list? if so open it, then go to help and check for updates. apply the updates. If they work you should be in good shape.
My adobe acrobat reader was working yesterday but today it said the adobe acrobat reader that is running can not be used to veiw pdf files adobe acrobat reader 8 or 9 is required but that is what i have on...
Ensure that you only have one version of Adobe Acrobat installed. I've found that often enough, if Reader and the full version of Acrobat are installed at the same time, it can cause problems like these.
If that is the case, try uninstalling Reader, so that only Acrobat Standard remains.
May 05, 2011 | Adobe Computers & Internet
What is acrobat reader?
Adobe Acrobat is a family of computer programs developed by Adobe Systems, designed to view, create, manipulate and manage files in Adobe's
Plug-in from Adobe. It reads documents in PDF format on any platform.
A program from Adobe that lets you capture a document and then view it in its original format and appearance
Adobe has changed the names of the products in the Acrobat family regularly, also splitting-up, joining, or discontinuing products. Between version 3 and 5, Standard and Professional versions were one product simply called Adobe Acrobat.
As of October 2009[update], the current main members of the Adobe Acrobat family are:
64px-adobe_reader.svg.png magnify-clip.pngAdobe Reader 8/9 Icon
  • Adobe Reader 9 (Windows, Mac and Unix)
  • Adobe Acrobat 9 (Windows & Mac only; no Unix version)
    • Adobe Acrobat 9 Standard
    • Adobe Acrobat 9 Pro
    • Adobe Acrobat 9 Pro Extended (includes Adobe Presenter)
The latest version
Version 9.0 Adobe Acrobat 9.0 was released July 2008:[10][11]
  • PDF version 1.7 (and prior) supported. There are Adobe extensions to PDF 1.7 for Acrobat 9.
  • Product Family includes: Acrobat Standard 9 (Windows only), Acrobat Pro 9, Acrobat Pro Extended 9 (Windows only).
  • Pro Extended Version includes Adobe Presenter and the features of Acrobat 3D.
  • The ability to create Acroforms was restored to Acrobat Standard in this release (in versions 6 through 8, Acrobat Professional was required).
  • Enable real-time collaboration of PDFs with synchronized document views and chat.
  • Improved Web Capture for capturing entire web pages or just some parts into PDF.
  • Integration with acrobat.com to enable storage and sharing of PDF files.
  • Personalize a PDF Portfolio with customizable templates for navigation and branding.
  • Compare and highlight the differences between two versions of a PDF document.
  • Insert FLV (Flash) or H.264 video for direct playback in Adobe Acrobat and Adobe Reader.
  • Convert a variety of video formats to FLV for playback in PDF.
  • Create PDF maps by importing geospatial files that retain metadata and coordinates.
  • OCR PDFs (Paper Capture) using ClearScan. Adobe ClearScan technology creates custom Type1-CID fonts to match the visual appearance of a scanned document after optical character recognition (OCR). ClearScan does not replace the fonts with your system fonts or substitute them by Type1-MM (as in Acrobat 8 and earlier versions), but uses these newly created custom fonts. The custom fonts are embedded in the PDF file (this is obviously mandatory). If the OCR does not recognize a word with enough confidence, then the image (bitmap) of the word is shown in the PDF and the text is put above but hidden (same as what is made in "Searchable Image" mode).
  • Adobe Reader 9 drops support for Adobe Reader Extensions 5 and 6 which permit Adobe Reader client software to save changes to filled-in forms in PDFs. Adobe Reader Extensions 6.1 and newer are still supported. Legacy PDFs will still be viewable, however they will open with the warning "This document enables Reader capabilities that are no longer enabled in this Reader version."[12]
  • On March 10, 2009, Adobe Reader 9.1 was released which addresses a number of customer workflow issues and a critical security vulnerability while providing more stability.[13]
  • On May 12, 2009, Adobe Reader 9.1.1 was released which addresses two critical security vulnerabilities.[14]
  • On June 9, 2009, update version 9.1.2 was released which addresses a number of critical security vulnerabilities.[15]
  • On July 31, 2009, update version 9.1.3 was released which addresses a number of critical security vulnerabilities.[16]
  • On October 14, 2009, Adobe Acrobat 9.2 was released (added support for Windows 7 x86/x64 and fixed many security issues).[17]
  • On January 12, 2010, Adobe Reader 9.3 was released which addresses a number of critical security vulnerabilities.[18]
  • On February 16, 2010, Adobe Acrobat 9.3.1 was released which addresses two critical security vulnerabilities.[19]
  • On April 13, 2010, Adobe Acrobat 9.3.2 was released which addresses several critical security vulnerabilities.[20]
Jun 03, 2010 | Adobe Computers & Internet
Everytime I try and install adobe reader 9 it freezes my computer I am running windows XP internet 8
Make sure you have unistalled any previous versions of Acrobat reader first. reboot after uninstall. then install Acrobat 9. Also disable all antivirus application services before you install.
Jamil
Nov 18, 2009 | Adobe Computers & Internet
I am unable to open pdf's
Go to Adobe's web site and download the latest Adobe Acrobat "Reader".
Sep 24, 2009 | Adobe Acrobat 6.0 for PC
My computer not open pdf file
You need a PDF reader to open PDF files., Make sure that you have a program like ADOBE READER 9 installed which you may download from EN_US-H-GET-READER
or get FOXIT PDF READER from http://www.foxitsoftware.com/pdf/reader/
Jul 06, 2009 | Computers & Internet
MANUALS SENT AS PDF.
Adobe Reader is free to download from here:
http://www.download.com/Adobe-Reader/3000-2378_4-10000062.html
or view online here:
http://www.pdfmenot.com/
Hope this helps
Chris (ziraffa)
Dec 28, 2008 | Samsung YP-T7JX (1GB) MP3 Player
I am using vista and have adobe acrobat, when i click on an online link to a pdf file it says 'acrobat not found' i have added the program to the list of accepted programs in the firewall but still no joy.
try downloading adobe reader 9 or 8 and install it over you existing adobe reader, adobe acrobat is an old bit of software which is obsolete now
Nov 15, 2008 | Computers & Internet
Cant download pdf files.
- Let me know the full details of your problem?
- Check also the Version of your acrobat reader?
- If you have installed Version 5 in your PC then you open the file Version 8 or 9 then the version 5 cannot open.
Sep 25, 2008 | Dell InspironTM 600m Notebook
Dell Dimension 8400 PC Desktop Logo
177 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
