Question about Amana AGDS902SS Gas Kitchen Range
Oven not lighting on Amana model agds902ss
I have an Amana model number AGDS902ss. Just this week my oven stopped working. When I turn the oven on in bake or broil mode, nothing happens. I don't smell gas and nothing to seems to engage(click) in the oven. The stove top is working fine and the clock is working fine. where do I start on the eve on christmas eve. thanks for your help.
  • greeleys Dec 26, 2008
    I have the same problem. I went to heat it today and it warmed up to 400 degrees and then promptly dropped to 270 in about 10 minutes. I don't smell gas and the stove top and clock are functioning. Thank goodness we had our holiday dinner last night. I'll call a repair person later this week.
  • 750 Answers
Helloemauldin Welcome to Fixya
My name is Huum,
When you turn the thermostat on your range on it sends 120 volts to the bake valve and ignitor. The bake valve and ignitor are wired in series and the ignitor draws all the current and heats up. As the ignitor heats its resistance changes and when it is cherry red the current switches to the gas valve and it opens. The amp draw on the ignitor needs to be 3.2-3.6 amps for the gas valve to open. The gas valve has gas to it at all times. The gas valve should open within 40 seconds after the ignitor starts to glow.
If the ignitor is glowing red and the gas valve doesn’t open the ignitor is usually the problem. Sometimes the ignitor will glow red but the resistance doesn’t change and the gas valve doesn’t draw the current.
This is not a do it your selfer!
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Posted on Dec 24, 2008
    Problem Solver:
  • 6 Answers
SOUNDS LIKE YOUR ELEMENT CONTACT MODUE IS BAD YOUR AMANA IS MADE BY MAYTAG AND THE PART # FOR THE MODULE IS Y0042123 AS TO WHERE YOU WILL GET ONE TODAY NO IDEA JUST TRY YOUR LOCAL REPAIR DEALERS IS ALL I CAN SUGGEST
I have a AGDS902SS oven and I get F8 after turning the oven. What is the problem?
Amana Appliance Fault Codes I think I would call a repairman the list I find is really vague mostly refers to clock or main control board .
May 20, 2015 | Amana Kitchen Ranges
Amana AGDS902SS, need the ovenpressure regulator
Pressure regulators can be found at http://www.johnstonesupply.com/ or at http://www.grainger.com/ . you just need to know the type of gas (LP or Natural) and the size of inlet and outlet.
Note, make sure it is a pressure regulators problem. this is not a common problem
Jun 25, 2014 | Refrigerators
Amana oven AGDS902SS started beeping and showing a F1 error.
F1=Electronic range control failure
It is telling you may have a fauilty control...need to replace control or EOC.
If you are an novice working over the control board. please do take the help of an authorised technician doing that.
Mar 02, 2010 | Amana AGDS902 Gas Kitchen Range
Amana AGDS902SS Gas Range Oven. Replaced ignitor.
Hi not that i can think of try google the range see if they have problem with this range
Feb 08, 2010 | Amana AGDS902SS Gas Kitchen Range
The sensory board has gone out three times and the stove is 5 years old
I don't think the boards are your problem / look for power problem like low voltage / voltage surges / -- because this is 120 volts you could use a suruge control at the plug .. don't use a cheap one .. board arn't cheap .. make sure the electrical gorund is a good on.. poor grounds cause other problems in th house ..ck it good. **** ..
Dec 04, 2009 | Amana AGDS902SS Gas Kitchen Range
The control buttons on my Amana AGDS902SS are breaking off. I have three of them broken now. Don't know if it's the kids or the cleaning person, but I now have to use a bamboo skewer to cancel the oven or...
if the buttons are for the clock . then 1/2 of the button stem is inside the clock . you may damage the clock ( e g r ) buy poking inside it . they cost a lot .. remove old stems and buttons / replace all / they get brittle from oven heat . m m
Nov 20, 2009 | Amana AGDS902SS Gas Kitchen Range
Amana gas oven not working
The ignitor may be too weak to open the gas valve. If you have a volt/ohm meter capable of reading AMPS you can hook up to a ignitor wire and turn the oven ON. If you read less than 3.5 amps replace the ignitor. If 3.5 amps or more are read,replace the gas valve.
Aug 30, 2009 | Amana ARGS7650SS Gas Kitchen Range
We have an older Radarange over-stove microwave oven with touch pad controls. Whenever I boil something without a lid for a longer period, some of the buttons stop working. Usually, they begin working...
Call Amana customer service. Microwave ovens should be able to handle the high humidity you are talking about.
Here's the contact information:
Have your complete model number ready. You can find your model number and serial number on the label located on the upper or lower
front facing of the microwave oven opening, behind the door.
For assistance or service, call 1-800-843-0304.
If you need further assistance, you can write to Amana with any questions or concerns at:
Amana Brand Home Appliances
Customer eXperience Center
553 Benson Road
Benton Harbor, MI 49022-2692
Aug 05, 2009 | Amana Radarange Microwave Oven
Oven slow to ignite and come to temperature.
Change the igniter.
As they age, they often times will no longer draw enough amperage to allow the gas safety valve to open. Increasing the line voltage would help, but that's a little impractical.
Jul 18, 2009 | Kitchen Ranges
Oven will not light
Most likely your oven igniter is faulty. When they get worn they will heat up but not get hot enough for the gas to turn on.
Part number is 7432P062-60
May 18, 2009 | Amana RanARG7302 Gas Kitchen Range
Amana AGDS902SS Gas Kitchen Range Logo
491 people viewed this question
Top Amana Kitchen Ranges Experts
Sal De
Ismael Rodriguez...
Oloyede Monsuru
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
