Question about RCA CC9360 Mini DV Digital Camcorder
RCA 400x Digital Zoom Mini DV Camcorder
I lost the AC Adapter of my camcorder of reference. I don't know how to charge the battery. Please help me
  • kduran May 16, 2009
    Where might I be able to purchase this adapter?
    Thanks for your reply and assistance!
I've got the same problem the only option is to purchase a new cord for 102.50 that I've found.
Posted on Jun 26, 2007
Repair manual
I WOULD LIKE TO TRANSFER VIDEO FOOTAGE FROM MY digital video camcorder pal mv800 mINI dv 400X Digital zoom 20x to my lap top but i have not got the cord for this.Nor do i know what it is called.please please please help me out
Aug 12, 2013 | Canon MV800 Mini DV Digital Camcorder
Canon ZR200 mini DV Digital camcorder power is not coming.
First thing, clean your battery contacts, both on the battery, and on the camcorder. Make sure the battery is charged fully (measure it if you have a voltmeter). Make sure your power adapter is putting out voltage (again, measure it if you can) Try a spare battery, if you have one, to make sure the first one isn't just dead. Other than those things, you could have a faulty or broken power switch on the unit. That's about all I can think of offhand.
Apr 12, 2010 | Canon ZR200 Mini DV Digital Camcorder
SIR/MAM. WHEN EVER I USE MY CAMCORDER GR-DVX9
There is often a small battery inside the unit or accessed from outside that holds the memory that the device was last set. Yours is defaulting to maximum zoom. And in fact it does.
Built-in Clock's Rechargeable Lithium Battery
To store the date/time in memory, the clock's rechargeable
lithium battery is integrated in the camcorder. While the
camcorder is connected to an AC outlet using the AC
Power Adapter/Charger, or while the battery pack attached
to the camcorder continues to supply power, the clock's
rechargeable lithium battery is always charged. However,
if the camcorder is not used for approx. 3 months, the
clock's lithium battery will become discharged and the
date/time stored in memory will be lost. When this occurs,
first connect the camcorder to an AC outlet using the AC
Power Adapter/Charger for over 24 hours to charge the
clock's rechargeable lithium battery. Then perform the
date/time setting before using the camcorder.
Note that the camcorder can be used without setting the
date/time.
Your manual in English. You can use a smartphone with Google translate and the camera feature to read what is shown on the camera in Japanese and change the operating language to English.
http://www.videocamera-manual.com/manuals/jvc/JVC_GR-DVX9_MiniDV.pdf
Nov 03, 2017 | JVC GR-DVX9 Mini DV Digital Camcorder
Problem with Panasonic NV-DS38 Mini DV Digital
I´ve had same trouble, nothing help me to get tape on, then I tried to recharge the battery (new spare battery, only had 2 earlier charge) and voilá, it work´s again. So there was somekind of trouble with the new battery I got, that is not original part I don´t know if that matters,
Nov 06, 2009 | Panasonic NV-DS38 Mini DV Digital...
I had a power surge and my sony dcr-trv350 will not trn on is it worth fixing?
Follow this procedure to troubleshoot if the camcorder will not turn on.
IMPORTANT: If model-specific information is required to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony eSupport Web site.
  1. Remove the battery from the camcorder.
  2. Connect the AC power adapter to the camcorder.
  3. Plug the AC power adapter into a working electrical outlet.
  4. Attempt to turn on the camcorder.
  5. Reset the camcorder back to factory settings.
  6. NOTES:
    • If the camcorder does not operate using the AC adapter, service may be required .
    • If the camcorder does operate using the AC adapter, proceed with the steps below to troubleshoot the battery.
  7. Ensure the battery has been fully charged.
  8. Ensure the battery is properly inserted into the camcorder.
  9. Remove the AC power adapter from the camcorder.
  10. Attempt to turn on the camcorder.
  11. NOTES:
    • If the camcorder does not turn on, then the battery may need to be replaced.
Aug 14, 2009 | Sony Handycam HDR-HC7 Mini DV Digital...
What does this mean c;31;23
The camcorder has detected an issue that may require a power reset.
To perform power reset:
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
If the issue still persits try with different media.
Aug 08, 2009 | Sony Handycam DCR-TRV22E Mini DV Digital...
My jvc camcorder GZ-MG37U will not charge
Camcorder has charging circuit but it could go defective. The repair would be costly so in this situation, you can purchase stand-along battery charger for around $20 and charge the batteries independently. Make sure all the contacts are cleaned and camcorder is working with direct ac adapter. Good luck -James. for furnter assistance by email, go to www.camerarepairjapan.com
Feb 11, 2009 | Canon XL2 Mini DV Digital Camcorder
Lost power cord
See the links below for the part you are looking for.
A/C Adapter (plugs into camera)
Battery Charger (charges battery without camera)
Mar 05, 2008 | JVC GR-D250 Mini DV Digital Camcorder
Jvc digital video camcorder gr-d20ek no power
wipe the contacts with after shave solution or isoprophyle alcohol, this may do some magic
Aug 14, 2007 | JVC GR-D20 Mini DV Digital Camcorder
RCA CC9360 Mini DV Digital Camcorder Logo
515 people viewed this question
Top RCA Video Cameras Experts
Marvin
Marvin
Lawrence Oravetz
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
