Question about AEG 23 in. Favorit 50750Vi Built-in Dishwasher
Ontegrated dishwasher door fitting
I am fitting a kitchen for a friend. She has a AEG Favorit 35085 VI Integrated Dishwasher and a new door (matching the other units) to fit to the front of the dishwasher. There is a fixing kit which makes no sense. Help please. Thanks Chris
Just fitted on of these & found the door very easy to fit.
The instruction sheet is actually a template as well. Attach it to the back of the door & where indicated drill 2mmø holes to a depth of 14mm. Firstly then screw in the 2no. screws that go into the door slots, the actual screws are easy to spot as the screw thread finishes approx 5mm from the head.
Once that is done you need to offer the door to the front of the dishwasher & slot it into place. Once done you have to fix the door in place with the 6no. longer screws. To do this you must remove 4no of the screws which are holding the front of the dishwasher together, the other 2 screws go through empty positions at the bottom of the dishwasher door.
To help with this process I would recommend you use a soft jawed clamp to hold the door in place whilst you screw it in place.
There are also 2no. angle brackets that fit into 2 slots on the top of the dishwasher which are then used to hold the dishwasher in place under the work top.
Hope this helps.
p.s. one last thing, the thin strip of steel that comes with the kit fits onto the underside of the worktop in the position shown, I believe this is a steam deflector to protect the underside of the worktop
Posted on Nov 10, 2008
Wash your dishes by hand
Posted on Jul 05, 2007
New AEG dishwasher wont fit in existing space that housed our old Favorit 44050 VI
The space underneath the dishwasher, or cabinets, is referred to as the kick space. It is where your toes fit under the edge of a counter and they are typical of cabinets and dishwashers alike. You should not expect a wood trim piece to fit underneath the dishwasher and not all dishwashers will accommodate one. It is fair to say that all dishwashers will come complete with a trim piece to cover this area, since some have venting and others do not; some have a door that extends down further and some do not. Generally speaking the variation people concern themselves with is in dishwasher's width and not in the door configuration. So having said and in consideration of your (assumed) desire to retain the wood trim, I suggest you retool the wood trim piece to work/fit with the dishwasher you decide you want. This is what I did rather than use the provided black metal panel. I have attached photos.
d8c6be34-1c2a-482c-8f06-f609e72b619c.jpg 9cc1da12-62a1-4b9c-9bc2-5a2b06e4845b.jpg
Mar 11, 2014 | AEG 24 in. Favorit 44050 Built-in...
AEG Favorit Integrated Dishwasher failing to heat the water. has the element gone? and how do you get at it?
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Mar 23, 2011 | AEG 23 in. Favorit 50750Vi Built-in...
Ikea Whirlpool integrated dishwasher door front
how do i take door off to fix handle back on dishwasher
Jan 03, 2010 | AEG 23 in. Favorit 50750Vi Built-in...
Aeg favorit 86070 vi fully integrated dishwasher started bleeping with 3 short bleeps 2 months ago. I followed instructions internet and shook dishwasher to one side and it worked for about 8 weeks. Now...
This is typical of the anti-flood circuit that opperates once it detects water on the base of the machiene and is a polystireen float that activates a micro switch. This puts the machiene in pump out mode only. You need to determine if the water at the base of machiene is caused by a small leak or is it a customer spillage. Clearing the water (tip to side) or dry with paper towel and inspect for leaks. Rectify the leak and this should solve the problem.
Sep 09, 2009 | AEG 23 in. Favorit 86070Vi Built-In...
Cant fit door to dishwasher
You would need to tell me which fixings are supplied with the DW. There are a variety of different ways to fix the door to the appliances, some have 2 white spacers which you would need to fit to the lower part of the door and others screw directly to the appliance.
Jul 10, 2009 | AEG 23 in. Favorit 50750Vi Built-in...
Integrated dishwasher door fitting
open the front door. On each side of the inside of the door are various long screws, unscrew these and the old door will fall off. discard the old door and follow the same steps in reverse to put the new door on. It took me 10 mins to do. Hope this helps
Apr 12, 2007 | AEG 23 in. Favorit 50750Vi Built-in...
AEG 23 in. Favorit 50750Vi Built-in Dishwasher Logo
1,889 people viewed this question
Top AEG Dishwashers Experts
Paul Carew
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
