Question about Mitsubishi VS-60609 60" Rear Projection Television
Mitsubishi 60 in rear projection TV 1990 - 'Dead"
I have a Mitsubishi 60 in rear projection TV (1990) that does nothing, no light, no picture, no sound. It was working fine one day and the next... nothing. The wiring diagram says it has 9 fuses but I can only find 3. Any help would be greatly appreciated.
Slinteriors
  • 8617 Answers
SOURCE: my mitsubishi vs 5071
You might have a bad PIP board, When you say NO picture. Is it totally blacked out or blacked out with "blue snow". The PIP has been alot of problems in this chassis and you will experience what your describing. Capacitors are the root of the PIP boards failure. Let me know if I can assist you further.
Posted on Jan 26, 2008
  • 208 Answers
SOURCE: mitsubishi projection tv vs60va2 picture rolls
This unit has chroin bad caps on the 5v, 9v and 12v regulators. If you know circuitry you can check thos caps and replace the weak or open electrolytic caps. If you call on a tech that services mitsu. this is faily common repair for them and should not cost over 150.00 to 200.00 depending on your area.
Posted on Apr 07, 2008
Laurens mom
SOURCE: Mitsubishi WS-55807 parts in a VS-60603?
I own a Mitsubishi WS-55807 55 in. for parts if you are interested. Please contact me back if interested. 727-773-8208 Nicole
Posted on Feb 22, 2009
Ecollier2012
  • 3459 Answers
SOURCE: Philips 60 inch rear projection screen is wacky!!
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Apr 11, 2009
techman
  • 3130 Answers
SOURCE: I have a Toshiba rear projection tv that is 60" shaky screen
if you are using cable try disconnecting the input wire to the TV set from the cable box. it could be a ground loop issue.
Larry
Posted on Aug 10, 2009
Screen resembles 3D look with predoment red and green to images - did the blue blub burn out and need to be replaced?
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all it resistors too.By replacing all these parts on the tv convergence board to fixed it to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Feb 05, 2011 | Mitsubishi VS-60803 60" Rear Projection...
My picture is almost 3-D like and is red, green and yellow.
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 28, 2010 | Mitsubishi VS-60609 60" Rear Projection...
Green light flashing on TV. Cannot get it turned off. No pictur
Did you get yours resolved? I had the same thing. The repair guys called it the "flashing light of death". It indicated the TV is dead.
Jul 13, 2010 | Mitsubishi WD-52525 52" Rear Projection...
52" mitsubishi rear projection tv model vs6051 sound no picture
Not exactly familiar with this model but sounds like the projector lamp is burned out. Hopefully it's a replaceable type. Try calling these people - http://www.purelandsupply.com
Mar 29, 2009 | Mitsubishi VS-60111 60" Rear Projection...
Mitsubishi VS-6071 60" Rear Projection TV Problem
can you give me the number of the manufacture of a 60in mitsubishi VS-60707
Oct 25, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Tv problemsMitsubishi VS-60705 60 in....
My Mitsubishi Model VS-60705 did the same thing a couple of years ago...A TV repair facility replaced the Video card. Any repair facility facility that works on rear-projection TV's should be able to repair your set.
Jul 10, 2008 | Mitsubishi VS-60705 60" Rear Projection...
Mitsubishi Vs-6071 Picture
replace the signal board (one with all the rca's on it) and not the main board if a plain antenna works OK
Jun 05, 2007 | Mitsubishi VS-60719 60" Rear Projection...
Mitsubishi VS-60609 60" Rear Projection Television Logo
171 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
