Question about Brother DCP 115C All-In-One InkJet Printer
Magneta ink leakage
After last changed of magneta, the ink leakage down in few hours.
The stain was appeared close to right side in the middle of casing.
After fast leakage low level of ink (to allow black print and a little colour)) was kept long time. And now printer calling to change magneta.
I'm afride about repeated and lost ink without printing like last time
In maintenance mode I have found
MACHINE_ERR: A1,82, A1,82,ETC.
Do you have any suggestion
Best regards
SOURCE: Duplex Printer prints one side upside down
If it's the same as the Brother 4070 you go into printer proerties (press properties next to printer selector after sending a document to print).  Choose the advanced tab, on this tab near the top are five buttons with icons on, the second one shows two pages with A and B on, press this to access the duplex and binding options.  In there change from "flip on top edge" to "flip on left edge"
Posted on Apr 30, 2009
  • 7 Answers
SOURCE: printer won't print black ink
From multiple online sources, this appears to be a fairly common problem with this model. As a matter of fact, my 490CW is experiencing the same exact issue. Called tech support and they're issuing an exchange. I'd advise that you do the same.
Posted on Oct 12, 2009
cene765
  • 787 Answers
SOURCE: MFC-490CW two ink colours just not printing, it
Powerful cleaning is: Press menu, then start black copy, then four times arrow-up quickly after another.Machine will be in maintenance mode (all lights will flash).
press 7-6-4 and OK (or start-black-copy).
When finished press 7-6-3 then start black copy,
printer will do a power purge.
Leave maintenance mode by pressing 9-9.
If this not help better think about new printer, because cost of repairing this one is profitable.
Posted on Nov 10, 2009
Sebin
  • 712 Answers
SOURCE: black ink will not print. Colours ok
Get a syringe, remove the needle, remove the ink cartridge and use the syringe to blow air GENTLY through the hole the cartridge connects to. Make sure you have a cleaning cloth to remove ink dislodged from pipe connected at the print head, do this gently to remove any obstruction and there should not be too much mess and can easily be cleaned up.
Posted on Feb 04, 2010
  • 610 Answers
SOURCE: The printer does not want to recognize that the
This is a common problem that Brother is well aware of; in fact, if you call Brother at 1-877-276-8437, they will tell you where to take the machine to get the printhead replaced at NO Cost to you.
Posted on May 25, 2011
Ink absorber full
Ink Absorber Full
This may clear the ink absorber problem. There is ink absorbers located at both ends of the printer where the ink head move.
To dry the ink absorber, power up the printer and open the cover so the ink cartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place it inside the printer over the ink absorber on the far left hand side of the printer to soak up the excess ink. You may need to change the absorbent tissue a few times. Then repeat the same procedure on the right hand ink absorber.
Close the lid and the printer should now function normally.
Jan 19, 2013 | Canon PIXMA MP150 All-In-One InkJet...
Ink absorber is full. What to do? Someone help! Thanks!
Oct 03, 2012 | Office Equipment & Supplies
The waste ink absorber is almost full.
This mayclear the ink absorber problem. There is ink absorbers located at both ends of the printerwhere the ink head move.
To dry the ink absorber, power up the printer and open the cover so the inkcartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place itinside the printer over the ink absorber on the far left hand side of theprinter to soak up the excess ink. You may need to change the absorbent tissuea few times. Then repeat the same procedure on the right hand ink absorber.
Sep 01, 2011 | Canon PIXMA iP90 InkJet Printer
Ink absorver full of Canon iP 1900
Sep 01, 2011 | Office Equipment & Supplies
Canon ip 4500 ink absorber problem
Aug 26, 2011 | Canon Pixma iP4500 InkJet Printer
Ink absorber full message
Aug 13, 2011 | Canon PIXMA MP460 All-In-One InkJet...
Ink absorber full on canon full on canon ip2700
This mayclear the ink absorber. There is ink absorbers located at both ends of the printerwhere the ink head move.
Aug 02, 2011 | Office Equipment & Supplies
My dcp165c printer print quality prints black & yellow colour. i clean print head through maintance 76 but problem cannot be solved
How is the printer printing black and yellow color? Is it a smudge?
When I print, the pages are smudged with ink. What should I do?
Description:
- If smudged stains appear at the top center of the printed page:
  • Make sure the paper is not too thick or curled.
    Also, verify that the appropriate paper is being used and that the paper type set in the machine matches the media used.
  • Make sure the paper is not curled when you print on the back side of the paper with the Print Odd Pages and Print Even Pages settings.
- If smudged stains appear at the right or left corner of the printed page:
- If smudged stains appear on the reverse side or at the bottom of the page:
NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
  • Make sure the printer platen is not dirty with ink.
    How to clean the machine's printer platen
    1. Unplug the machine from the AC power outlet.
    2. Lift the scanner cover until it locks securely in the open position.
    3. Clean the machine's printer platen(1) and the area around it, wiping off any scattered ink with a soft, dry, lint-free cloth.
    4. Close the scanner cover.
  • Make sure you are using Genuine Brother Innobella™ Ink.
    > Brother Genuine Supplies information
  • Make sure you are using the paper support flap.
    To use the paper support flap, pull out the paper support (1) until it clicks and unfold the paper support flap(2).
Aug 03, 2010 | Brother Computers & Internet
Brother MFC 7820N Smudging Concern
  • Make sure the paper is not curled when you print on the back side of the paper with the Print Odd Pages and Print Even Pagessettings.
  • Make sure you are using Genuine Brother Innobellaâ„¢ Ink.
Sep 11, 2017 | Brother MFC-7820N All-In-One Laser Printer
Ink cartridge error
Get a new magenta cart, but make sure you buy a genuine one, not a compatible. The chip on the cart in question may be faulty (approx 30% of compatibles can be faulty).
If the error does not go when a genuine cart is installed you may have a faulty main board or carriage.
Aug 26, 2008 | Epson Stylus Photo R320 InkJet Printer
Brother DCP 115C All-In-One InkJet Printer Logo
41 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
