Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
FDW60 flashing 'eco' light error
Hi all, my 18 month old FDW60 has developed an error not described in the handbook. After turning it on selecting a program and pressing start it begins to make all the right noises, but after 10 seconds it beeps and the 'eco' light starts flashing, whilst continuing to make all of the right noises, but that is all it does because no water enters.Can anybody help. Thanks
  • 4 more comments
  • joncom Nov 01, 2007
    Same problem and I tried disconnecting the floater switch but then it started OK and 20 seconds in it clicked and stopped - no flashing lights, just the prewash light still on and silence. 30 seconds later it beeps and continues to beep every 5 seconds or so, still doing nothing. Any ideas?
  • stevethefish Jun 30, 2008
    Eco light was flashing, followed Stevecon's advice, thanks for that.
    Problem now is that after it appeared to be fine, started making a noise like a coffee perculator, the macine stopped and then both Eco and Fast lights started flahing. Any ideas would be gratefully received.
  • thefourwards Aug 04, 2008
    Hi, Have English version of machine and had eco light flashing. Read stevecon's advice and tipped machine up to empty water out - BINGO all working fine - thanks so much - saved me a fortune!!!
  • Ashwick Apr 03, 2009
    Well I can't believe it! I had the same problem of the eco button flashing. You turn dishwasher on thinking it will start but with a beep the eco button flashes and it makes a grinding noise. Well I pulled out the dishwasher, secured the lower water arm that had come unwound. Tipped machine on side. This caused a little water to come out. Hey presto the machine is working perfectly! Thanks so much to the other messages because it saved me so much money, time and extra washing up!
    ps you do not even need to wait for a man - I did it myself easily!!
  • kkopiec
    kkopiec Feb 20, 2012
    Worked perfectly as described by Ashwick.
    btw quite a lot of water came out so be prepared with some drying clothes...
    Thank you ....
  • Stewart Whitelaw Mar 10, 2012
    Brilliant guys I thought jump to the net and see what this issue was, my daughter put a big spoon in and blocked the arm I never noticed. Got the flashing Eco light, found your advice and hey presto it worked. Note keep mop and bucket handt :)
I had this problem and discovered it was due to a leak. The float switch attached to the bottom panel was operating. Pull out the mains plug, tip the machine on it's side (water will escape so get a mop ready), remove the bottom panel, 3 screws front and back, disconnect the connector from the float switch. Tape the connecter up out of the way and stand your machine back up. Try running it now. If you have a leak somewhere then you will get a puddle under the machine. If no leak, then I would suspect the float switch itself.
Posted on Apr 13, 2007
  • lucysubs Feb 27, 2011
    Many thanks to Steve for his excellent advice - I unplugged machine from electric only
After the flashing Eco light and refusal to do anything apart from run the pump..
I placed my dishwasher on its side and then righted it again after half an hour, it's now working again!
I have also had the two flashing lights in the past as well, solved by running dishwasher empty with a bottle of dishwasher cleaner.
Posted on Jul 23, 2008
  • Ant29 Oct 31, 2011
    I had the "Eco" flashing light syndrome, read the comments and solutions and it "WORKED" just by tipping the machine on it's side....thanks all :)
Just want to say Thanks for saving me £90 and loads of time. 'Eco' light was flashing and discovered lower spray arm had become obstructed by cutlery slipping down through the basket during the cycle, and had come off. Fixed the arm back on okay but flashing continued. Tried the above solution but didn't even have to take the bottom panel off, Hubby just tipped the machine over and all the water came out of the base. Put it back up and tried it and it's fixed! Easy.
Cheers :)
Posted on Dec 11, 2007
I love the internet! Had the same prob... Disconected the water in-pipe, tipped backwards for about 1 minute, had quick panic as I had totally forgotten to get towels to clear up the obvious amounts of water that were about to flood out. And hey presto, all working again. So dish washer fixed and dishes done all before wifey gets out of bed... Brownie Points!!!
Posted on Feb 13, 2010
Exactly the same issue, tipped the dishwasher forward and mopped the floor. Started the dishwasher and it worked perfectly, my only issue is do I let my wife know how easy it was to fix or do I get extra praise for making out it was a more complex issue
Posted on Feb 12, 2011
  • rmedia Apr 13, 2011
    Didn't tip the unit forward, did think about making out it was hard work but got brownie points in anycase, the waste pipe was blocked full of 2yrs roasting fat so flushed through with a baster full of hot water to draw the excess water through from the bottom of the dishwasher. Genius. worked a treat, the eco and fast error lights both went out and normal service resumed.
Yep same here eco light flashing, tipped it up for 3 mins, again no towels (men eh!) , works like a treat
Posted on Aug 15, 2010
Absolutely fabulous! Same issue, followed the advice and hey presto a woring machine!
THANK YOU
Posted on Jan 25, 2010
I tried this fix and it worked perfectly despite there being no apparent leak and the float & switch in full working order. Many thanks to Stevecon for the solution.
Posted on May 21, 2007
Just worked for me and the Mrs thinks I am the bees knees! Thank you all
Posted on Aug 28, 2011
I'd just like to say that I had exactly the same problem after my kitchen was flooded by the storms and in 5 mins....hey presto....it's working again. Thankyou very much for putting your expertise onto this page. It's saved me a shed load of money (not to mention washing up which I truly detest!)
Posted on Aug 03, 2007
    New Friend:
I just wanted to add also that I followed the instructions here as I had the same problem and my dishwasher is working again! The only difference is, I tipped it back and just a trickle of water came out, so I moved the towels and tipped it forward instead which did the trick, however for some reason the water flooded out the back anyway which meant a quick switch of the towels again! But, thanks everyone who posted!
Posted on Aug 16, 2013
    New Friend:
Tipping the machine on outside and drying the base after removing solved this problem.
Posted on Mar 04, 2013
    New Friend:
Fast forward to 2015.... and the suggested solution worked perfectly - thank you!
Posted on Jul 02, 2015
Forest are the best
Posted on Aug 26, 2008
3 Suggested Answers
SOURCE: fdw60 starts but stops soon after
In my case it was the pressure sensor on the side of the short hose between the main (circulatory) pump and the bottom jet arm (which spins inside the machine)
Remove it and test resistance on terminals while blowing into the tube.
There is another pressure sensor on a hose attached to the waste assembly but appeared to be working correctly.
Posted on Apr 21, 2009
  • 195 Answers
SOURCE: when I select start on my FDW60 the pump starts running but no water is coming in to the machine. After about 10 seconds the eco light starts to flash. Meanwhile the pump continues to run but no water
first make sure you have water going in , then if you d have water the next thing the water valve needs to be located , it will have a hose going into it and a hose coming out of it and two wires on it , when the dial is set to fill with water you should have 120 voilts on the two wires , if you hve th epoawer then the water valve is not workingthis is a easy fix and cheep aso same valve is used on washers , get back to me after you have done some more research
Posted on Dec 06, 2011
How to reset a Kenmore model 2661532210 washing machine
try this.if it does not work then go to this link and see if it helps you out...... Programmable Washing Machine Certain programmable washers have a reset function. This function clears an unintentional "Delay Start" command and resets controls in the case of a program error when the machine won't start. The method of resetting varies by make and model. In certain models, turn the knob to reset with the power button "Off." Select the desired program. Press the power button to restart the washer. In other cases, if the machine has a "Cancel" button, push it to clear the error and then push the "Pause" or "Stop" button to reset it. Consult the handbook for the washing machine for the correct procedure that applies to your model. You can often find washing machine handbooks or troubleshooting instructions on the manufacturer's website............
Reset Buttons for Washing Machines
Dec 08, 2016 | Kenmore Washing Machines
Hhello, I have a freeview bush record. Bu11fvrsd50/x, when I try to fast forward a program it keeps changing to a channel either 5 or 7, is there anything I can do to resolve this problem or can I buy
Hi Lisa, when you are trying to fast forward can you keep your finger on the button do not release till the place is reached you want to start playing again!
Oct 26, 2014 | Televison & Video
Not working
The pcb will be damage , check to see if you have 5 years parts all hotpoints have them it will be cheaper to fix.
Dec 14, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint Dishwasher not working - FDW60
unplug it for an hour this normally fixes this problem on my machine
Jul 28, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Hi. i have an LG 42inch plasma, approx 18 months old. about 2 months ago, a green stripe developed down the right hand side of the screen, approx 1.5 inches wide. last week a 2nd stripe the same width...
Sadly, the plasma screen is failing. The green strip is no longer functioning properly and the failures will continue to progress.
If still under warranty, get it exchanged.
Jun 12, 2008 | Computers & Internet
FDW60
Tom, If your dishwasher is still under warranty, best thing will be to contact Hotpoint's service center for repair the problem.
Aug 29, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Selecting cycle and starting
I'm assuming the programs are all selected electronically...then your pc board is on its way out. In this case you would have to replace the board...most electronic boards have "service programs" which you can check functions, but I'm not familiar with Hotpoint.... Oshie
Jun 22, 2007 | Hotpoint 24 in. FDW60 Free-standing...
FDW85 Dishwasher
turn on your dishwasher and press and hold the start/reset and on/off buttons simulaneously until the display shows d.of this turns off the demonstration mode.
May 12, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Monitor goes blurry, colours/pixels start shaking across screen
Do you have your screen saver enabled, i so turn it off and se if it still does it. Secondly boot your pc in safe mode(pressing F8) on boot up and select start windows in safe mode. See if the monitor still does it, if so a monitor fault or loose/faulty vga lead. If it is ok then your graphics driver may be corrupt and need re installing.
Dec 30, 2006 | BenQ FP71E 17" LCD Monitor
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
10,473 people viewed this question
Top Hotpoint Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
