Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
F11 and f dl errors
Seems to stop cycle at 12 mins (before spin cycle ) reset comp and you can run spin cycle ... this machine has been nothing but trouble this is 5th problem...had other washers that went years without a service call!
  • Handyman7 Dec 26, 2008
    My wife says it is 20 minutes or so, but it does pretty much the same thing. Stops right before rinse, push the "cancel" or reset button, and it will continue.
    Whirlpool, Duet Ht Washer. Any help is appreciated. Thank you.
    New Friend:
  • 88 Answers
I hope that you have a serivce contract or something on this unit you need a main control board f11 means that there is communication error between the 2 computer boards the fdl means that there is is door lock problem. But that is incorrect that is how you know which board has the problem the door lock is controlled by the main computer board. it's just playing tricks on you I have tried changing the door lock with those codes and it did nothing. that board tends to be alittle pricey .good luck.
Posted on Jan 11, 2009
We have a Kenmore Elite Quiet Pak 4 Washer that we have had for 5 years. It has been flashing F11 and DL back and forth for months. We had a tech come out (not sure he knew what he was talking about) and...
The symptoms are pretty specific for the F11 code on the Whirlpool Duet front loaders and clones (Kenmore Elite and KitchenAid):
If the washer starts to fill but the drum NEVER moves, your MCU is bad
If the washer runs through most of a cycle and then gives the F11 before (or during) a rinse or spin cycle, then you have the CCU relay problem.
If you are interested in having me repair your CCU for you, I offer that service on eBay (website coming soon). My username there is "jhagner"
Thanks
Aug 19, 2011 | Kenmore Front Load Washer
Stops on spin cycle and gives a f11 error code
F11 is a serial communication error. Communication between the main board and the motor control board is not being sent correctly. This could be a bad main board, motor control board or motor itself. The testing can get pretty involved. Try putting the machine in a self test mode and see if the error clears. Press Cancel, then by pressing the drain spin button once on the left side then move to the spin speed button the the right. Press this button until no-spin lights. Press the prewash button 4 times. C00 should appear in the display. Let it run it's tests, there will be 8 of them and end up on C08. If this doesn't work, it's best you wait for the service tech.
Mar 29, 2010 | Kenmore Elite 45986 Front Load Washer
Bosch 1200 classixx not spinning
bosch 1200 classixx not working properly. On 12 min spin cycle it starts then after 1 min timer reads 0:01 and it stops. washing cycles run but doesn't seem to be any spin action
Oct 12, 2009 | Bosch Washing Machines
Duet GHW9160PW0 F11 Issue
not related to shake, issue, but hte f111 and dl issue def sounds as if the connection between the 2 has been compromisdd, in my experience it has been a faulty CCU, losing communitcationsd with the door latch thus the f11
Dec 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
How do i find what an error code means?
if that is a whirpool or kenmore remove bottom panel look for tech sheet in plactic bag codes are in it
Sep 02, 2008 | Washing Machines
Sears kenmore elite he4t
Shaking is caused by poor distribution of clothes causing an imbalance. Try the machine empty. If it works well, be aware that you'll have to redistribute your load to stop the shakes.
Dec 31, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Error F11
Plug off the wall. Shaking & vibration of your washer causes circuit board connections to become loose; due to faulty manufacture. Remove the 3 or 4 screws from the back & take off the top cover to secure the connections, make sure they are tight. This applies for the F11 & F dl codes. Works for certain machines, dont see why it wont for yours.
Dec 10, 2007 | Kenmore 46462 Front Load Washer
Electrical problem
Teecee, F11 is a communication error between the main board and the motor control board. The main board is on top and the motor control board is behind the lower panel. Sometimes the harness to these boards become loose causing this error. You would have to get at them and reseat the connections. F dl has to do with the door lock mechanism. You might of just had the door open when you reset the machine. To get at the main board on top you have to remove the 3 screws in back for the top. It will then slide back and off. To get at the motor control board, you will have to remove the bottom panel. The board will be in the back. Catriver..post back.
Oct 25, 2006 | Whirlpool GHW9150 Front Load Washer
Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
132 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
