Question about Pioneer DEH-2000 CD Changer
Install RCA Plugs for Sub
Anyone have install RCA Plugs in the rear of the radio ?
On the radio board there is the mark for those RCA plugs,
as well mark for capacitors and jumpers.
As I was interested in using this radio as a source to run together
with amps, any help is welcome.
Best Regards
John
SOURCE: Sub Woofer Won't Work
mbruno did this work? I have the same issue
Posted on Jan 16, 2008
Duncan
  • 219 Answers
SOURCE: 2 Subs running together
If they have the same impedence (like 4 ohm) then you should be able to run two different model number speakers as if they were the same model number. There might be a slight difference in the way they sound, but I would not expect it to be enough to be noticeable. Good luck.
Posted on Mar 27, 2008
  • 74 Answers
SOURCE: Pioneer DEH-P3000IB... Hook up RCA
Here are the directions according to the manual:
1 Use MULTI-CONTROL to select
SW CONTROL.
2 Press MULTI-CONTROL to display the
setting mode.
# Press BACK to return to the previous display.
3 Press MULTI-CONTROL to select the segment
you wish to set.
Press MULTI-CONTROL repeatedly to switch
the segment in the following order:
REAR SP (rear speaker setting)—PREOUT
(RCA output setting)
4 Use MULTI-CONTROL to select the desired
setting.
Turn to change the setting.
When REAR SP (rear speaker setting) is selected.
REAR SP:SUB W(subwoofer)—REAR SP:FULL
(full-range speaker)
When PREOUT (RCA output setting) is selected.
PREOUT:SUB W (subwoofer)—PREOUT:REAR
# When no subwoofer is connected to the rear
output, select REAR SP:FULL.
Hope this helps.
Posted on Oct 13, 2008
  • 5 Answers
SOURCE: Hook an ipod to Pioneer DEH-16
The RCA jacks on the rear of the head unit are rear pre-amp outputs. (google it if you need an explination on what purpose they serve or see the installation guide) With that said, I am able to play my mp3 player through them but since they are 'rear' pre-amp outputs my mp3s only play on the rear speakers. see this post for more...
http://forums.creative.com/creativelabs/board/message?board.id=dap&message.id=45149&query.id=194369#M45149
installation manual:
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/35572505Installation%20Manual%20DEH-1600.pdf
owners manual:
33399012operation%20manual%20deh-1600.pdf
Posted on Mar 25, 2009
SOURCE: Pioneer indash stereo/cd player DEH-7500MP,no internal amp output
some cars have internal amps for the speakers try connecting the remote wire it's the blue wire with a little white on it worked in my moms van.. if that does not work try testing it with a speaker from your house
Posted on Mar 31, 2009
Installing a sub into 08 dodge caliber factory radio
Check for female RCA line signal output.
I don't think factory radio will has RCA output.
It does not hurt to check.
Jan 18, 2014 | Cars & Trucks
How do i make this woofer work with my polroid tv
OK, it looks from what I can tell you need a 1/4" stereo plug for the input to your speaker system. The output from the TV is either RCA jacks or maybe a 1/8" sub mini stereo jack. You can likely go to Radio Shack or an audio store and purchase a cable that has the 1/4" stereo plug on one end and a 1/8" sub mini stereo plug on the other. That cable would mute the TV internal speaker or if you do not want to mute the TV speakers you can get a cable with the 1/4" stereo plug on one end and the L and R audio, RCA (phono) plugs on the other. That would give you both. RCA plug and 1/4" plugs are pretty easy to install if can not find the correct cables. Good Luck. The Yamaha unit looks to be self powered so impedance matching or load on the TV audio amps should not be a problem.
Sep 02, 2012 | Yamaha YST-SW012 Subwoofer
Is there a way that anyone can tell me where the fuse panel is on a RCA Model #: R52WH74 television?
There is one fuse on the AC filter board which is where the power cord is located. Just trace the power cord back to where it plugs into the circuit board on the right side when looking in the rear you will see the fuse located right next to where the cord plugs in on that board.
Nov 16, 2011 | RCA Televison & Video
Im not sure which plugs I should plug my RCA cables that come from my amp to the reciever. I dont know if its the "back RCA output" or the "Front RCA output" or the "subwoofer...
First of all get yourself a Y-LINK cable. (single male RCA on one side/ double female RCA on the other side) Connect the Y-LINK to your head unit sub woofer output with the stereo RCA that leads to the sub woofer amplifier. Now you are connected to the correct output. I do not know what head unit you had connected before to base your comparison, however there is a output voltage difference from one head unit to another, (1.2V, 2V, 2.5V, 4V, 5V) and that is what determines where the gain on the amplifier should be set to. Always match the headunit output voltage with the amplifier gain control to be the same. It is not uncommon for some entry level units to have a single sub woofer output. dreamsystems
Feb 21, 2011 | Pyle PLTS77DU Car DVD Player
Having a low level hum after it starts to be used, then shuts off after a small amount of time, between 5 and 30 minutes.
use a ground loop isolator from radio shack, the device is hooked up to the rca plugs in, the other side has, (of course rca plugs), outs. solved My problem of feedback in the sub and into the processor.....
Feb 09, 2011 | Sunfire True Sub MK II Subwoofer
I have a pioneer car stereo and it outputs power to the car speakers, but not the output jack. When I plug wires into the output jack and test them with a mulimeter, there is no power to them. Also, if I...
yes the rca's behind the radio are shot a power wire must of touched them.there is a small fuse inside the radio connected to the circuit board marked fu located and connected under the plugs in the radio. that must be replaced inorder to work. or if you want to cheat connect a grounding wire to the outside of the rca and it should work.
Sep 02, 2009 | Pioneer DEH-245 CD Changer
Have stock radio # F75F-19B131-AA its in a 1998 F250 need to know how and if i can hook up one Amp for the two door speakers, and if i can hook up an additional Amp for some subs. Ofcourse if radio can do...
You will need a line level converter for starters (takes speaker level signal and converts it to line level/RCA signal) you connect this to the speaker left/right wires and it has a RCA left right on other end to connect and run to your amps, (you need this box because factory radios don't have RCA outputs on them) At that point all you have to do next is run the power/gnd/rem for your amp and then speaker wires to your front/rear speaker and then sub (if using). You can use one of these converters for your front/back speakers so you will still have use of your front/back/left/right fading options. make sure you disconnect th factory plug/harness at each speaker since the amp will be powering them and you will run speaker wires to each speaker. If you only want one converter it will be on your front channel and your sub will be power by the front. (you will fade to front for more/less sub bass unless your amp has a separate volume/bass control). If you want your sub to fade with rear speakers you will need to install another converter off of the rear speakers. Found a site with some photos that may help you with your project.
http://www.redlineforums.com/forums/howto-section/15003-how-sub-stereo-amp-install-factory.html
Aug 18, 2009 | Car Audio & Video
Trying to install a subwoofer on a 97 crown vic
Make sure you are using a 12volt DC system in both units. It may sound simply but an AC sub may need an inverter. Also check grounds.
May 21, 2009 | 1997 Ford Crown Victoria
RCA plugs?
OWNERS MANUAL click here
Usually clarion radios have seperate colors to designate front, rear and sub preamp outputs.
Since youre is grey and black, Assume the grey is front, and black is rear.
If one set is longer than the other, the short is the front, long = rear.
Jan 14, 2009 | Clarion (DB165) CD Player
Car Audio & Video Logo
46 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
