Question about DISH Network ViP622 DVR DTV Receiver / 180-Hours Video Recorder
Adding tv to a dish network dvr
I have a dish network dvr. the tv down stairs is hooked up directly,and the one upstairs is hooked up wireless. can i add another tv upstairs. I don't mind if the third tv matches the same channels as downstairs
  • 374 Answers
Your upstairs tv is connected via a coaxial cable and you can do a few things to get programming to the third room.
The first is to locate the wire that enters the upsairs room that currently has tv and insert a splitter by cutting the line to that room and running the out ports to the rooms and the in port to the other end of the wire that you cut. This will give you the same picture in both rooms.
If you have a system that does not use diplexers to backfeed the second TV you can backfeed the 3-4 cable going to the TV1 by cutting the line and adding a splitter with the inport running to the 3-4 port on the receiver and one of the out ports going to your tv1 and the other outport going into the UHF side of a diplexer. You will need to cut the Satellite feed into the back of the receiver on the back side of the seperator and connect the seperator to the SAT port of the diplexer. The IN/OUT port of the diplexer will connect to the end of the sat feed cable that goes to the wall plate. This will allow you to go into the attic of outside of the house and find the sat cable that feeds the TV one and break it there and put the IN/OUT port of that diplexer facing the TV1 room and the SAT port connecting to the other end of the cable you broke. The remaining UHF port will be the feed for the new room that you wish to connect. This set up will allow for viewing the same program as that at the TV1 location however you will need to change the channels at the TV1 location or buy an IR to UHF converter to allow you to be able to work the system independently from the receiver. Hope this answered your question. IF you need further assistance please contact me and thanks for using Fix Ya.
Posted on Dec 31, 2008
How can I hook up my insignia lcd tv model ns-32lb451a11 to dish network with dish remote?
Is the remote capable of controlling other items check the handbook for the dish system for TV control set up if possible
Dec 24, 2015 | DISH Network Televison & Video
Mywifiext net
Netgear never gives a defined range in metres.
Will the WiFi adapter work with the TV, as it is designed to be controlled by a computer not a TV?
The USB socket on the TV is designed for being used as PVR, video recorder, not to connect to the internet.
You need to consult your TV manual, as I don't think it will ever work.
May 24, 2013 | NetGear Universal WiFi Internet Adptr...
When my TV is being used downstairs, the remote will not work upstairs. They share a dvr.
Hi my nameis Mike Houston of DISH Network and I see the remote will not work upstairs andit's a Dual DVR. You will want to makesure the DVR is in Dual Mode, I will send a link that will help with thesesteps; http://www.dishnetwork.com/SupportSection/same-video-2-tvs.
Jun 04, 2011 | DISH Network Televison & Video
How can I move a receiver to another room that has . For example, downstairs i have my two receivers with 1 DVR that controls 2 TVs the one downstairsTV#1, and 1 upstairs TV#2. The other dish, controls TV...
Hey there! Becki Barned from Dish Network customer service here!!! If you want to do this! You would need a tech to come out and install the DVRs in the new rooms. If you try to move the reveivers, you will only get an Acquiring Satellite Signal message. If this has not been resolved, you can find us on Twitter, or blog back!
Nov 28, 2010 | DISH Network 311 2-Room System DTV...
We have a tv upstairs and one down stairs, they
Since the antenna is on the roof the signal has further to travel to get to the downstairs antenna and as a result the signal is weaker. Install a device on the antenna line before the first TV called a signal booster. This unit plugs into the wall and gets connected to the antenna wire too. It will improve the signal for both televisions.
Aug 14, 2009 | Televison & Video
Dish network UHF remote works intermittently.
If you extend the small antenna that is on the back of the receiver by using a short cable and a barrel connector to get the antenna out of the entertainment center or out from the TV this will help alot
May 30, 2009 | Universal Remote Control DISH Network...
Hooking Up Panasonic sc-ht670 home theater to Dish DVR 625 and Panasonic TH-42PHD7UY Plasma TV
You will need to run a set of audio cables from the TV1 output on the rear of the 625 directly to one of the three audio inputs on the surround system. Thanks for using Fix Ya.
May 13, 2009 | DISH Network DVR-625 DTV Receiver /...
Recording on my Dish 625 dvr
Okay, we can do this. Go to the menu on the satellite at either TV locations. and press 8 then 5. You are now at the Record Plus screen. Move the highlight to the record preferenceand toggle up or down to the desired record preference.After this ensure that you select enable on the activation side of the screen. You will then need to select done. Now you are in business! Thanks ffor using Fix Ya.
Mar 23, 2009 | DISH Network DVR-625 DTV Receiver /...
2nd remote has trouble changing channel
hook up a 6 foot peice of coax cable to the remote antenna port and then attach a barrel connector and then use a larger antenna "bunny ears" basically to extend distance of uhf signal for remote
Nov 27, 2008 | DISH Network DVR-625 DTV Receiver /...
Wavy lines and jogging TV picture
it could be any of the things you listed, the coaxial output on the dvr, where it says channels 3-4 out, the cable , or the coaxial input port on your tv. the dvd player is probably hooked up with rca cables (red white and yellow) so the reason you dont have the issue with it is because its on a different port, one solution would be to hook your receiver up to the tv using this kind of cable, this would also get you stereo sound, you would then watch dish network programming on a video input channel,
if you want to narrow the problem down, i would suggest hooking a vcr up with the cable thats connected to 3-4 out, play a tape and see if the issue continues, if not the issue is with the dvr, if so try a different coax cable, if this resolves the issue, the issue was the cable, if not unfortunately the issue is your tv
Feb 20, 2008 | DISH Network DVR-625 DTV Receiver /...
DISH Network ViP622 DVR  DTV Receiver / 180-Hours Video Recorder Logo
445 people viewed this question
Top DISH Network Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
matt martin
matt martin
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
