I let my friend borrow my laptop and he used another charger to charge it, when i tried to tturn it on everthing seemed to come on straight but the screen never came on and it hasnt been dropped or anything. What could it be
  • 679 Answers
He could have blown your power circuit if it wasn't the same exact power supply as yours
Posted on Dec 24, 2008
My lenovo a10 tab wont charge at all. What action can i take to fix this
Is the charger working? Try measuring its output voltage with voltage meter. Borrow one from a friend if you don't have one. It is usually between 18 and 20 volts.
Dec 27, 2014 | Lenovo Computers & Internet
Telecom r100 battery
It could be one of these three things.
1. Bad port. Often in laptops these ports become loose.
2. Bad battery.
3. Bad charger.
Borrowing either a universal power charger, or the charger from someone with a similar laptop, can eliminate some of the possibilities unless it is indeed your charging port.
If after plugging it in, the battery charges you know you had a bad charger. If the battery fails to charge, you know its time for a new battery. Again this only if the port itself is not bad.
Universal chargers can be expensive. You can find batteries and chargers on Ebay for a decent price.
Mar 01, 2014 | Dell Computers & Internet
My charger was damaged a couple months ago and i finally got a replacement. Now when i tried it, the light comes on on the charger, but the computer will not charge or turn on.
HiHow was the charger damaged? maybe the battery was also damagen.... try to borrow a friend's charger or battery and try them with your laptop.
If they dont work try taking your laptop to a service center.
Good luck.
Aug 24, 2011 | ASUS Eee PC 1000HE Netbook
The charging light remains red and never show green. Even when left for days to charge, it will say 83o/o left every day and i don`t no what the cause is.
Either the charger is damage or the battery is damaged and need replacement of any one of it.
But try to borrow first the charger if you have a friend and check if it is charging?
Mar 05, 2011 | Acer Aspire One PC Notebook
Charger not working. Not charging at all. moved to an outlet i know works but no charging
toad Try to locate a friend or someone who also has a off-board charger you could borrow. Then contact your provider to see if they can order you a charger It doesn't have to be a Pride charger any good 4 amp charger will work.. Also try e-bay for any good used charger Hope this helps
Oct 18, 2010 | Jet 3 Ultra Power Chair
Samsung sgh m600 wont charge and does not hold a charge
try these steps..
1. try borrowing the same charger from a friend and use it to your phone.
2. try using your charger to a friend's phone.
if any of the two above won't work, go to your nearest service center they will tell you and help you fix your problem.
Feb 20, 2010 | T-Mobile Samsung T429 Pay-As-You-Go Cell...
Laptop will not charge
Bad charger. Try with another charger you can borrow from a friend.
Nov 19, 2009 | Computers & Internet
Batteries won't hold a charge
Are the batteries really gettin a full charge or is your charger faulty. If you can borrow a voltage meter you can see what your battery is putting out and check the charger (plugged in) to test how much voltage it is putting out. If the Razor is 12 volt you can hook up a car/motorcycle charger to pump up those batteries. I don't think your batts are not holding a charge, i think they're not gettin a charge....good luck to you...Tim
Apr 18, 2009 | Razor MX500 Dirt Rocket
Unable to start up laptop
Make sure that your batteries are fully charged. Also the most likely problem is that your laptop charger needs a checkup. try using another charger of same model (Probably u can borrow one from your friend who uses similar version), if charger change doesnot work, repeat the same with batteries too. This should fix the problem. if step 1 & 2 does not help, probably u have a hardware level problem with your laptop and need a technical support from your vendor / service company. All the best.
Mar 23, 2009 | Computers & Internet
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
