Question about Hitachi 46UX24B/25K 46" Rear Projection Television
Convergence circut I have a 46" hitachi rear projection screen tv. I know that it is the conergence that is out but I need schematics or part number to figure which one it is before I start taking it apart ant thoughts?
STK4274 IS the correct part number. 3 18 pin chips mounted to the right (looking in from the back) on heat sinks. Cross reference is NTE7187 available from www.mouser.com
Posted on Feb 20, 2010
  • raptorperf Feb 20, 2010
    sorry, 3 ea, 15 pin not 18
  • 398 Answers
Usually there are 2 convergence IC's, labeled STK392-110. Each IC has 3 channes. Each color needs to be corrected 2 ways, vertically and horizontally, so 6 channels are needed. usually one IC does red, red and haf of green while the other IC does the other half of green, blue and blue. If the red colors are off, change the IC closest to the red jack. If the blue is off, change the IC closest to the blue jack. If the green is out, you have a 50/50 shot at replacing the correct IC. It is recommended to use the STK392-150 when replacing the IC's so it might not be a bad idea to go ahead and replace both with the newer numbers.
Posted on Jun 26, 2007
Hitachi 46f500 46 in problem double picture end two collor
This is symptom of convergence output chips failure in rear projection tv, replacement of convergence output chips will fix the problem.
Chips/ IC replacement requires soldering work in circuit board, if you are not familiar with electronics stuff fixing an soldering work, call local tv repairman to help you.
Thanks.
Oct 26, 2010 | Hitachi 46F500 46" Rear Projection...
Hitachi sp-46w - picture is fuzzy, ran magic focus and stops 1/2 way in the green. A code appears at the bottom right "5" any clue?
Ur convergence,it dead,need it replaced,Know how to solder?Buy a convergence kit,tries Tv repair World.com,Tv repair kits.
Nov 24, 2009 | Hitachi 46F500 46" Rear Projection...
Conergence issue
The convergence output IC's need to be replaced. This is a very common problem for all projection sets as those amps are high current devices with a fairly high failure rate. The job can be done in the home. Depending on where you live the cost is around $200 to $300.
Jun 11, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Hitachi rear projecton tv
your model uses two STK392-110 Convergence ICs. Hitachi also recomends replacing the feed resistors which are two 2.2 ohm 1watt, two 1.5 ohm 1watt, one 3.3 ohm 1watt and one 1.8 ohm 1watt resistor. You can get repolacement ICs and resistors at the following link and they provide step by step installation instructions with pictures. Heres the link.
http://servicemanuals.vstore.ca/
Sep 30, 2008 | Hitachi 53FDX01B 53" Rear Projection...
Samsung sp42w4hb Rear projection
needs new convergence ships, part number stk 392-040, there is 2 of them, replace them both, also check fuses on the board, you probably need a tv repairman to fix this.
Apr 09, 2008 | Hitachi 46F510 46" Projection HDTV
Color out of line
Sounds like a convergence problem. First, try using your set's user convergence mode.
Mar 25, 2008 | Hitachi 46UX24B/25K 46" Rear Projection...
Hitachi 50ux22b has dark screen and general CQ adjustment issues
is the convergence off?
bad convergence amp ic's
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 05, 2008 | Hitachi 50UX57B 50" Rear Projection...
Color convergence?
Can anyone give me the resistor values for location RK 42, RK 46 and RK 62? Hitachi 46F500 TV. Or can I be pointed to the location of a service manual?
Tony
Sep 13, 2007 | Hitachi 46F500 46" Rear Projection...
Televison & Video Logo
178 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
