Question about NetGear WGR614 Wireless Router
How do I find out what the key is for my netgear router?
I had a netgear wireless router hooked up about 2 years ago, for christmas I bought my son a labtop and we are trying to log him into my network but dont have the key!
    Scholar:
  • 97 Answers
You have two methods of finding or restoring this key.
1: log into the device. If you have a PC already working through this device, go to that pc, click on Start then RUN. Tpe CMD and hit enter. this will opena black window. type ipconfig. you should see an entry for the Gateway IP address. this should be the IP address of that router. Now open Internet explorer and enter the ip in the address field (not a search filed). hit enter and see if you end up with a menu. if so, you will be able to navigate to the wireless security and adjust or find that security key. If prompted for a password, you are in trouble. You'll then need to do option 2.
2: If you cant get intot the device configuration as described above, you can reset the unit to factory defaults( usually clearling the key altogether). This can be done by presssing the reset button for about 10 seconds (small pin or paperclip actuated button on the device.
Since you did not specify the model, I cant previide more details.
Posted on Dec 24, 2008
  • Rick Davis
    Rick Davis Dec 24, 2008
    actually I see the model but I dont know the firmware verison. however resetting the unit should work (be sure to disconnect all users first)
My Rangemax wireless wndr3000 is not working properly, though it has in the past. The problem seems to be that I'm hooked up to the wireless network (ex. I can print wirelessly), but with no internet....
Same situation here. Wired connection from modem works fine. I can also log in to the router via routerlogin.net. However, the router does not detect an internet connection.
Jul 12, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
My son gave me an older computer and wireless Linksys-G model WRT54GS router. I bought my wife a ipod for christmas and in the setup of the ipod it is asking for a password for the router. My son does not...
Reset the router to default....the default username and password is usually on the bottom of the router..then open a web page on your pc and connect the router with a network cable..type 192.168.0.1 or 192.168.1.1
Use the generic name and password to logon....once logged in, configure username and password and wifi...once setup..save and exit..disconnect and connect router to internet modem...log onto pc and look for your wifi neteork name..cheers
Jan 24, 2018 | Linksys Wireless-G WRT54GS Router...
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I cant connect thru my netgear router model wgr614v7
If you hook your PC directly to the router using an Ethernet cable you don't need the key. You can log into the router and change the WEP Key to anything you want, but u have to be directly connected to the router not going through the wireless.
Jan 25, 2009 | NetGear WGR614 Wireless Router
How to connect maxg with a my netgear broadband router
Try to turn off the DHCP server in the secound router, that way it'll be a swich technically, and set the secound router's fix ip address to something different, because I'm quite sure that both routers have the same 192.168.0.1 IP address and that's nogood.
Set it to anyting from 192.168.0.2 to 192.168.0.254
Nov 26, 2008 | U.S. Robotics MAXg USR5421 802.11g/b...
Wireless router netgear
Is it possible to download the drivers for Netgear wireless router & Voice adapter WGR613VAL
Nov 02, 2008 | NetGear WGR614 Wireless Router
Lost connection on laptop
I would reset the router most of those linksys will have a small hole in the back of them that say reset push it and let it go back to factory default see it that does not fix your prob
May 10, 2008 | Linksys Wireless-G WRT54G Router
Hi!
Try these:
1. Go to CONTROL PANEL > MANAGE WIRELESS NETWORKS
2. Remove all the preferred networks
3. Restart your laptop
4. Reconnect to your network
Hope this helps!
May 04, 2008 | NetGear WGR614 Wireless Router
Get booted off
Ok. i have the exact same problem, but i use linksys. I have has geeksquad and they dont know. I have only one option i havent tried. try to just hook up the modem to your router only. Buy a wireless adapter for your home computer. If it doesnt work, return it for a refund. I feel for you guys because i have been going through hell and it drives me crazy that even geeksquad doesnt know. (By the way dont buy that garbage when the people say you need a new router, because they just want more money.)
Mar 22, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
NetGear WGR614 Wireless Router Logo
49 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
