Question about Averatec 3200 Notebook
Averatec 3200 Laptop turns on for like 2 seconds then shuts off
I have an Averatec 3200 laptop computer. One day i went to turn on the computer and it turned on for like 2 seconds then just shut off. I tried again and again but to no avail. Finally I bought a new power jack and installed it. I know it works because the battery charges when i plug it in plus i can still charge my ipod via the USB port. After that someone told me that my hard drive might be fried. This seemed like a likely solution because i did have a virus in my computer. So I bought a new hard drive. This time it turned on for like 10 seconds then shut off. The screen worked because the Averatec sign came up.No problems with the screen working.No time to even get into the setup. I had someone who works with computers look at it and she wasn't sure either. Then someone suggested that perhaps it might be the motherboard. But i decided i would try to find out for sure before i put any more money into it. Any assistance would be greatly appreciated. Thanks.
  • Lepke Mar 29, 2008
    mine problem is the same try reload the whole system but now even with the recivery cd just shot off i dont even get to 5% and then off agan..pls help
I don't have a solution, but have experienced the same except that it seems to be intermittant and would like to share this for the next victim who may be looking for an answer to this problem. I will try the dirt/dust option which seems to be the most likely given I just reinstalled XP which rules out virus. This unit is several years old so that also serves to point in the dust arena. I just went through an episode of getting it to turn on and it doesn't have any particular place that it cuts off. Sometimes after serveral seconds and sometimes I'll hear the Windows welcome music or anywhere inbetween or beyond. I'm on the laptop now after nine hours of trying to get it up. I haven't done a thing put gave it time. It may work fine for a month before the next episode and it may only happen once and then work fine. There seems no rhyme or reason.
Posted on Dec 09, 2007
Check ribbon cables on keyboard and pointer pad. make sure they are securely clamped in place. Also make sure ground wire near heat sink is grounded properly.
Posted on Oct 30, 2007
I have had the same problem with my Averatec 3200. It happened a few months ago (as the summer heat here in Athens began to take hold) and I took it to a computer shop. The guy opened it up, cleaned the fan area and cleaned around the processor and put some sort of flim, or wax over it and put it back together. It works perfectly now, I was also worried about a virus, but apparently it was a combination of heat and dirt. He said that he has seen this happen a few times and that it is particularly common if users smoke or work in dusty environments as it tends to clog the fan.
Posted on Aug 24, 2007
I guess I had a similar problem with my Averatec. in short, it was overheating. Initially I raised the top of the laptop by about 2 cm (using a book) to facilitate a better air flow - it improved the behavior of the unit; later I bought a cooling pad ($30. on sale at Staples) and it worked great Ingo
Posted on Apr 13, 2007
    President:
  • 2,961 Answers
Im sure the virus would have stopped a boot up unless is was a bios virus which is rare. It's sounds to me as if it's a processor problem, it seems to work at first which suggests the motherboard is working, but then as soon as the pc starts to work hard which is on start up its either getting too hot then shutting down or simply damaged. I assume you cannot get into the bios as it shuts off too quick, but you may still be able to clear the bios by locating the cmos battery and flipping out, as the bios may not be seeing your hard drive and crashing,this will make your laptop pause in the bios first, so trying to get in the bios may be a step forward so as to get the laptop to see your new drive.
Posted on Apr 12, 2007
My Averatec 3200 keeps shutting itself down. The
A common problem with all laptop is dust. Sounds like you have 5 years worth of dust stuck in there. You should get a can of compressed air and blow though every vent you can! You want to loosen the dust that's in there and possibly try to blow it out and/or get it closest to the vents.
After that you should take a vaacum cleaner and **** out all the dust you can!
Dust inhibits air flow, alot! Its the number 1 killer of old computers.
Apr 18, 2010 | Averatec Sotec 3200 Series Fan with...
I need to know how to reformat my laptop. I have an averatec 3200 series
Hi there, please watch the video below in the link & you get a full knowledge of how to format & install a laptop/ computer.
Setp 1 - How to format.
Step 2
Hope all these very helpful for you.
Thanks & waiting for your feedback.
Feb 14, 2010 | Averatec 3200 Notebook
I have some problems with the display on laptop averatec 3200 the computer is working fine, but i cant see anything on the display. the display is compleately white wen i turn on the laptop.
Problems are possibly due to wires running through the hinges on the laptop which may cause a connection problem/short. Your right. Over time the hinges which house the wires from your screen to your motherboard can wear out causing the monitor wires to have shorts. You may need to contact a professional to replace the screen or to rewire the set.
Apr 04, 2009 | Averatec 3200 Notebook
Averatec 3200 Series Laptop
If you have access to another machine you can create a disk to fix the ntldr issue. Please see the following website. http://www.tinyempire.com/notes/ntldrismissing.htm
Mar 18, 2009 | Averatec Sotec 31100 and 3200 Series...
Fan/Overheating issues averatec 3200 series Laptop
Fans on laptops run when the CPU is taxed. The more its taxed the louder it will be due to higher fan speed. The laptop over the years has gotten bloated with programs and stuff that gets in and stays on your hard drive. The more programs running in the backround the more the CPU is taxed. Try uninstalling useless programs first, empty your recycle bin, delete temporary internet files and cookies, run the disk cleanup utility then perform a scan disk and a deframent. Also you may want to add more memory to your system if it needs it. I use crucial's website (crucial.com) to scan the computer and tell me what memory I can use in my machine. Hope this info helps you out.
Sep 17, 2008 | Averatec 3200 Notebook
WLAN switch button does not work
Locate your wireless card compartment on your computer. It is probably on the back of it. Your computer manual should tell you where it is. Open the compartment and locate your wlan card. Remove it from your laptop for about 30 seconds, and then reinsert it and make sure that the proper connections to it are firm and secure. Close up the compartment. Turn on your laptop. Your laptop should search and recognize it. If it doesn't, then your wireless card probably quit working on you. If your computer is still under warranty, and if it doesn't recognize it after you have tried this, then you can contact your computer manufacturer and explain to them what happened. They should replace your wireless card at no charge. If you bought the wireless card from some other store, then take it to them and explain to them, and ask for a replacement wireless card.
Sep 04, 2008 | Averatec 3200 Notebook
My Averatec turns on to the logo screen but keeps resarting
dude heres the deal the blue screen is from a lack of ram simple as that. just add more ram and you shouldn't have that problem anymore. then when the computer starts up reset the page file to double the amount of your ram. that should get rid of the blue screen and you should have a running unit. if this doesn't work then you are best off reinstalling the OS.
Apr 24, 2008 | Averatec 3200 Notebook
Installation cd
The installation cd is on a seperate partition of your hard drive. If you are wanting to reinstall everything follow these instructions
I have the same computer.
You dont need a disk- but do the following:-
1) Turn on your computer. 2) Press F4 repeatedly until you see the recovery program 3) Click - application on the left pane 4) then follow instructions on screen. That it.
If you need a file off the cd let me know!
Jan 21, 2008 | Averatec 3200 Notebook
It won't turn on!
Flashing green battery means it is in suspend mode. Pushing the power button should bring it out of suspension, however, one of the reasons I deactivate both suspend and hibernate mode is because the seldom work right. I would disconnect your A/C power cord and remove your battery from the laptop. After about 30 seconds plug them back in and your commuter should start again. Let us know how things go.
Dec 31, 2006 | Averatec 3200 Notebook
Averatec 3200 Notebook Logo
794 people viewed this question
Top Averatec Computers & Internet Experts
Steve Allison
Steve Allison
General Systems...
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
