Question about Bosch WFK 2401
Continuation of Drum not Spinning
Thanks for your suggestions. The belt was intact and all pullies looked good. I tried a spin cycle with the back off and it did not look like the motor attempted to turn. It moves by hand so there is no seisure issue that I can see. Where is the motor controller and is there an easy way to test it vs. the motor? Thanks
    President:
  • 1,294 Answers
Test your wall socket, and wash machine plug. Your problem is unclear......
Posted on Apr 12, 2007
Spinning drum
yes it does have belt can you turn drum in side by hand if yes and belt hasent broke must have come of pully belt should be tight on drum
Sep 13, 2013 | Hotpoint TDC32 Electric Dryer
During the spin cycles, the machine makes noise, almost like an airplane ready for take off. It also shakes and "walks". As the spinning increases, the noise and shaking increases. The shaking...
Not an expert but had identical symptoms. Problem was the loosening of the nut 27mm on the main pully. Simply remove lower back panel (16- torx 20 screws ) and tighten same.
If this does not hold over time, the pully hub has been damaged, and a shim, ( shopmade washer ) may solve problem. Remove belt, and pully, look for damage, and install thin shim, so that the nut will not bottem out on bolt before tightening on the pully hub. Good Luck, Lee
Mar 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The drum does not turn.
there are two potential problems. firstis te belt to the drum drive pully from th moter. this is the easiest. take off the back panel an seeif the belt is intact. if so run through a cycle and see if the motor spins or triesto spin. if not this is most likely thesuspect. one plug three screws and about100 dollarsfixes te motor. hope this helps.
Dec 18, 2009 | Kenmore 44102 Front Load Washer
Washer makes alot of noise
time to replace the belt , might need a tub bearing too / tentioner pully might have froze . remove the back panel with the washer unpluged look to see if the tentioner is at its fullest possition if so replace the belt .
Sep 06, 2009 | Maytag PAV2300 Top Load Washer
Belt won't stay on the pulley
These belts are really sensitive. Try messing around with it. Making srue that the belt isnt coming off the big tub pully. You tub pully isnt loose is it. Make sure the bolt that hold the pully onto the tub is tight on. Make sure the pully isnt loose. Inspect it for any small craks where that boltt tightens up. If the pully check out ok. Check the small motor pully as well. Make sure that isnt loose or anything. Pull on it if if its loose then thats you problem.. Inspect both pullys good. I would assume belt is in good shape right? If both pullys check out ok, then i would try to get the belt on and just mess around with it, spin the pully and if you se the belt starting to slip off adjust it as you keep spinning the pully....hope this helps
Jul 31, 2009 | Maytag Neptune Washer
My WBXR1060TAWW GE washer is eating thru belts....I replaced one about 2 weeks ago and the new one is fraying badly. It looks like it's rubbing metal when going through the spin cycle... It all started...
tensioner pully could have bad bearing when ran gets hot and tries to lock up causing premature belt wear. spin all pullys with belt ff any hard to turn or so loose they might fall apart
Jun 21, 2009 | Washing Machines
Serpentine belt slips off idler pulley
The A/C pully is supposed to spin freely until the AC is activated to run.. The cranshaft pully does not. Replace the tensioner pully. The belt has to fit in between the grooves on the pullys.
Apr 05, 2009 | 1994 GMC Suburban
Washer does not turn or spins
the pumps and motor pullys go bad on those.tip washer back against wall and inspect there.motor pulley melts ,the pump pulley breaks loose from its spot welds and then will rub metal to metal.when ordering parts replace belt too if damaged.if worn wont get a good spin and then dryer has to work over time.[power bill up.up,up.thanks for using fixya.God bless,tom
Jan 03, 2009 | Maytag Atlantis MAV7260B Top Load Washer
Maytag washing machine mod # LA882 top loader
HI. thanks for the question. well, not good news for you. the transmission has failed. has broken a gear inside. very costly .suggest buying new. A roper washer. good price. good washer. thanks the appliance doc. please rate my answer thanks.
Oct 08, 2008 | Maytag Washing Machines
Burning smell + Screeching sound but Belt is not the cause, then WHAT is?
A lot of people may be searching for help with horrible sounds and burned belts for Maytag and Admiral washers only a few years old from Home Depot etc. They used a cheap pump that has a corrugated sheetmetal ring that holds the bearings. Well as it runs the vibration and friction cause it to slip down and grind on the pulley as well as not turn easily. If you put the washer on it's back and turn the small pulley and it turns with a gritty feel or you can actually see a loose metal collar type ring thing that looks like a cookie cutte; then you have a bad pump.
There is a small access panel on the back of the washer. Three screws and two spring clips on the hoses and you're done (use big pliers on the hoses). Put the belt back on (just push motor to one side, it's not tight), then check for leaks and reinstall the cover. VOILA! You can find the pump on ebay for $25 or your local GE parts dealers for $50.
Sep 11, 2007 | Maytag SAV5710 Top Load Washer
Washing Machines Logo
94 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
