Question about Sony Cyber-shot DSC-W100 Digital Camera
Sony DSC-W150 power on keeps going to set date/time
Every time I power on the camera it goes into the setup menu to set the date and time. I've gone through the settings and am unable to prevent it from doing this. Everything else seems to work just fine.
  • 7 more comments
  • Anonymous Jan 03, 2009
    Let me know if you found a solution please.
    patrick@patrick-weir.com
    Thanks
  • arthur_tri Jan 04, 2009
    Sony DSC-W150I have the same problem.
    set it up didn't resolve problem of course.
  • kellisgf Jan 27, 2009
    My Sony DSC-W150I have the same problem.
    If you found a solution, send me please
    kellisgf@uol.com.br
    Thanks
  • pompin7 Jan 30, 2009
    I also have the same exact problem. I need help if some one know how to fix this problem!
    please send me to pompin7@gmail.com
  • dmeyer04 Feb 09, 2009
    Has anyone found a solution to this problem of the camera not saving the date and time?
    Please respond if so.
    d.meyer@dts-sd.com
  • gagnewestbro Mar 20, 2009
    have to set date and time every time please help gagnewestbrook@aol.com
    thank you
  • pbhealer Mar 21, 2009
    When I power on the date/time set comes up. Does anyone have a solution to this problem?
  • Anonymous Mar 22, 2009
    Same problem here ...if someone find a solution plz let me know ykro at 2chiflix dot com
  • brailey27 Mar 22, 2009
    Same deal. This sucks.
The date and time settings are displayed after turning on the camera. Solution
Sony DSC-W150 power on keeps going to set date/tim - sp.gif It is normal for the camera to lose time and date settings if the internal battery is left uncharged for an extended period of time; some cameras will default to the time-setting screen when turned on if this happens. Follow the steps below to resolve this issue.
  1. Turn off the camera.
  2. Do one of the following:
    • Insert a fully-charged battery pack into the camera.
    • If the camera is supplied with an AC power adapter, plug the adapter into a working electrical outlet and then connect it to the camera.
  3. Allow the internal battery that retains the time and date information to charge for at least 90 minutes.
  4. After enough time has elapsed to sufficiently charge the internal battery, turn on the camera.
  5. Set the time and date.
  6. Turn off the camera for 30 seconds.
  7. Turn on the camera again.
  8. Check to see if the date and time have been saved.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Posted on Aug 23, 2010
    Problem Solver:
  • 6 Answers
Set it up
Posted on Dec 23, 2008
SETTING THE DATE AND TIME ON Sony Cyber-Shot DSC-H1 Digital Camera
Press the MENU button, select Setup (toolbox icon), select Setup-2, then select "Clock Set".
Apr 16, 2012 | Sony Cyber-Shot DSC-H1 Digital Camera
Error msg E:91:01
I had the same problem with the same model (W30) and was starting to get a little scared with all the threads and posts out there, but I did download the Manual and the instruction was to initialize the camera. Go to Menu > Setup > Setup 1 > nitialize > OK Then set up the date and stuff, you should be good to go. Hope I've helped.
Jun 17, 2011 | Sony Cyber-shot DSC-W170 Digital Camera
Are you taking the battery out for any reason? Taking the battery out for an extended period of time will sometimes reset the time/date settings.
Mar 24, 2011 | Sony USB Cable (D3F01007) for Sony...
HOW DO I CHANGE THE DATE AND TIME ON MY SONY DSC-S750 CAMERA
Press MENU to bring up the menu. Use left/right to select Setup 2 (toolbox with a "2" below it). Use up/down to select "Clock Set". Use left/right to move between fields, up/down to change values.
Feb 02, 2011 | Sony Cyber-shot DSC-S750 Digital Camera
How do i resolve the C:13:01 error on a SONY DSC-W150, "error formatting memory stick" appears on the screen"?
how do you formate memory stick if the camera woke work at all. It keeps saying reinsert memory stick . Must be a w150 problem cause that's what mine is doing too! :(
Apr 21, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
How do I get the date to show on the photo? Sony dsc w150
For DSCW150, you can use the supplied Picture Motion Browser Software to insert the Date and Time on the images.
I'll forward a link to a page where you can view the information about inserting the Date on the images.
http://support.d-imaging.sony.co.jp/www/disoft/int/pmb/feature/edit/attach_date.html
Thank you!
Mar 25, 2010 | Sony Cyber-shot DSC-W100 Digital Camera
Unable to change the time settings
In Sony DSC-S950, press Menu button, go to Setup menu, Clock settings and adjust time and date, press OK, press Menu button to exit.
Thanks.
Sep 19, 2009 | Sony Cybershot DSC-S950 Digital Camera
Camera goes bazerk, the E:91:01 keeps on flashing
Try re-initializing - it's been known to work with same problem.
Go to:
Menu
Setup
Setup 1
Initialize
OK
This will restart the camera. You will then be prompted to enter the date and time settings.
Feb 11, 2009 | Sony Cyber-shot DSC-W30 Digital Camera
Sony cybershot dsc p200 user manual
Press Menu and go to setup, set date and time option to adjust it.
You can download user manual of DSC-P200 by clicking Sony Support. for further guidance.
Feb 11, 2009 | Sony Cyber-Shot DSC-P200 Digital Camera
Sony Cyber-shot DSC-W100 Digital Camera Logo
565 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
