Question about SanDisk Sansa e250 MP3 Player
My sansa won't turn back on
It's black and has 1 GB i had it hooked up all night on the computer and now it hasn't turned on i just got it yesterday. i hooked up to a phone charger for almost 4 hours but it still doesn't turn on.
  • 8,596 Answers
Hold in the power button for several seconds first.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + (REC button for Sansa e200 series) button, and reconnect the player to the computer while holding the volume + (REC button for Sansa e200 series) button in. Keep holding the volume + (REC button for Sansa e200 series) button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Dec 30, 2008
Hi. I have a paragon 4001-00 timer hooked up to my pool filter. It's worked great for the last 25 years but recently it has become finicky. It will always turn off, but sometimes it won't turn...
If new X2772 tripper hasn't solve problem, it might be time for new timer.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
4001-00 is 120Volt single pole single throw timer in Nema1 indoor enclosure
Wiring terminals 1 2 3
Black Hot wire from breaker connects to terminal 1
Black wire going to load connects to terminal 2
White neutral wires connect to terminal 3
Crossover Intermatic timer is T101
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Wiring terminals A 1 2
White neutral wires connect to terminal A
Jul 06, 2011 | Paragon 4001-00 24-hr Timer Control 120v...
If i connect my sansa pmp 4 gb player my pc cant intall it
When I plug in my Sansa pmp to my computer, it is not being recognized?
Jul 18, 2009 | Audio Players & Recorders
My 8 gb sansa
Does the charging sign show up? It could be a bad cable. Also make sure you have the right software You can get it here at: http://www.sandisk.com/sansa
Go to Support\product support\sansa view\ thenlook in the right column
Try it with different usb ports as well.
Go to Device Manager and look for "?'s" or "!'s"
Sep 11, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
Cannot upload music to my sansa c200
Try plugging in the player(turned off) before you turn on the computer.
Feb 10, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
My sansa
pull the menu button 30 sec it should turn it off .. then turn it on again .. look so you dont got the lock button aktivated..
Jan 14, 2008 | SanDisk Sansa e250 MP3 Player
Sansa c200 froze.
Pop the back cover off and take the battery out...when you place the battery back in and restart you should be ok.
Jan 02, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Won't turn on.
Fixed my "dead" Sansa by opening the back, removing the battery then putting it back in. This appears to have rebooted the system and now it's working fine. No files were lost.
(I did try holding down the on/off button prior to this but got no response at all.)
Dec 27, 2007 | SanDisk Sansa E280 MP3 Player
HELP ME PLZ
That's a pretty weird problem. The only suggestion I can give you is to check to make sure the music you put on was 1) in mp3 or wav format and 2) if this is music you have purchased, to ensure you have the rights properly set to play the music
Aug 06, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa e250 MP3 Player Logo
122 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
