Question about Sony NWZ-E438F Digital Media Player
I cannot charge my player
I kept being told that I need to charge my player, but when I plug it in I keep being told that it's fully charged. when I unplug it it says AGAIN to charge battery. What do I do?
Happened to me too... the thing is... you cannot charge the walkman or mp3 on a computer that has been modified.
I charge my walkman on my ps3
its the only way it works for me
Posted on Dec 27, 2008
My portable rca dvd player will only keep a charge when plugged in
-Battery is too old. All charge able battery last only 2-3 year or maybe even less than that depend on how you use.
-If just a little low and keep charging then it life is short.
-If let it fully empty (dead) before charge the it last longer.
Good luck
Mai
Oct 04, 2016 | RCA DRC6309 9 in. Portable DVD Player with...
All of a sudden it will not turn on....nothing...when plugged into the usb...it say fully charged....but if you disconnect..and try to turn it on.....nothing happens..
If you can turn your player on while being plugged to your PC/Laptop or USB charger, then your internal Lion battery is most likely gone past its useful life (some 500 charges or 18 months usage) and may need replacing. Most MP3 player may show 'fully charged' when plugged in either when the battery is truly fully charge or defective battery is no longer taking a charge: e.g. minimum or no current flow situation.
Dec 20, 2009 | RCA M4204 MP3 Player
THE BATTERY DOESN'T RECHARGE.I USED TO KEEP THE PLAYER PLUGGED CONSTANTLY WHEN SWITCHING IT OFF SO THAT THE BATTERY WOULD NOT RUN OUT OF STEAM..
by keeping the player constantly plugged in when of will have seriously shortened the battery life, rechargeable batteries ( exept the very latest ones) perform best by charging then using until fully discharged and charging again. this will ensure your battery lasts a long time, constantly charging a half charged battery will shorten the batteries life.
Nov 23, 2009 | Audio Players & Recorders
I plugged in my sandisc player to my computer to charge the battery and when I unplugged it fully charged it still just says connected?
Sep 08, 2009 | SanDisk Sansa e250 MP3 Player
Need help charging my mintek dvd player battery
The way the battery is usually charged is by plugging it into the player and plugging the player into the a/c outlet. Do not use the player, Just allow the player to charge the battery. The way you tell if the charging is working is the light on the front will usually be a red color and it will be steady color or blinking while charging. When the battery is fully charged, the light will turn green or turn off . This lets you know that the battery has fully charged.To test this try using the dvd player on the battery only. Play a dvd or cd and see if the battery is working properly. I hope this information helps you with your problem.
Apr 01, 2009 | Mintek MDP-1770 Portable DVD Player
YP-T9 constantly charging?
if you recharg it too much it could be wearing down, I'm guessing. unless oyu just got it.. you should take ti back because that's just messed
Jul 02, 2008 | Samsung Yepp YP-T9 Digital Media Player
Charging
Hello kings_park,
I would agree with what the tech support agent(s) told you. What you are describing sounds like a bad battery. The Insignia® Piliot MP3 players have a one year limited warranty. For service you should take the MP3 player into your local Best Buy™ store with the receipt. The store will be able to assist you in diagnosing the problem and if needed having the item serviced or replaced.
Best Regards,
Ken
"Go Ahead. Use Us."
May 29, 2008 | Insignia Pilot MP3 Player
Philips mp3 player sa6045
This player shows the "Do not disconnect" message when it is doing something critical such as transferring tracks or updating firmware, which could corrupt the player if disconnected part way through.
The player shows the "OK to disconnect" when it is idle. As the message says, it's ok to disconnect, as the player will not corrupt if disconnected when it is idle.
These messages mean that the player does not need the "Safe to remove" procedure.
It is ok to disconnect part way through charging. Also the player will condition the battery once it is fully charged, so it's ok to leave it charging.
Occassionally batteries can "memorise" when constantly disconnect and reconnected without fully charging and discharging. To help prevent this, fully discharge the player (leave on until dead) and fully charge and condition (leave charging for about 12 hours) every couple of weeks or so.
Feb 11, 2008 | Philips GOGEAR SA6045 MP3 Player
Charging the Sansa Clip player
If you leave your Sansa plugged into your charging source (wall charger, computer, car etc.), your player might still remain fully charged and just on. If you can, you may want to just leave it plugged into your charging source until you want to use it, so it stays fully charged.When its done, it will say fully charge...it should take a couple hours to charge the device....
Also, does your player have an auto power off or idle sleep setting? You can use this setting to set the amount of time you want your Sansa to automatically turn off after you don't use or listen to music on it.
Jan 01, 2008 | SanDisk Sansa e250 MP3 Player
F505 Battery Question
The Sony battery for the F505 is the info lithium type from Sony. Since its lithium you don't have to worry about the memory effect of the older technology. The battery has a chip that will regulate the amount of charge the battery needs. It will stop charging if the battery is full, so you can charge it at anytime. You should store it fully charged from what I've been told, if it for extended period of time. For short interval it should not matter.
Sep 11, 2005 | Sony Cyber-Shot DSC-F505 Digital Camera
Sony NWZ-E438F Digital Media Player Logo
128 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
